BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
11-09-2008, 14:56 | #76 (permalink) | |
Freak Poster Join Date: Sep 2007 Location: BanglaDesh
Member: 597570 Status: Offline Sonork: 100.1590733 Thanks Meter: 159 | Quote:
The Following 2 Users Say Thank You to rana_ For This Useful Post: |
11-12-2008, 21:39 | #77 (permalink) |
Junior Member Join Date: Nov 2008
Member: 897836 Status: Offline Thanks Meter: 1 | hello, im traying to find a way to change a cingular 7100g to nextel can anyone tell me if its posible and if it is, could tell plz how to do it, and one more thing i already try to type on sim card option but it wont let me type anything |
The Following User Says Thank You to Morpheusrage For This Useful Post: |
11-25-2008, 16:16 | #79 (permalink) |
Freak Poster Join Date: Oct 2007 Location: Cape Town South Africa
Member: 617428 Status: Offline Thanks Meter: 52 | many thanks for this valuable info but what files do we use in South Africa as we have 2 prominent networks down here. Vodacom SA and Mtn SA is the networks we use here in South Africa. maybe If you have you can post or even better mail me at [email protected] or [email protected] many thanks. |
The Following User Says Thank You to luqmaan For This Useful Post: |
11-25-2008, 16:21 | #80 (permalink) |
Member: 617428 Status: Offline Thanks Meter: 52 | you can use any number for that proveder it will work its just for reference that they use it. |
11-25-2008, 16:24 | #81 (permalink) |
Member: 617428 Status: Offline Thanks Meter: 52 | use magic sim boss it should as it just opens the device to all networks then you can go wild and do all sorts of modifications. |
11-25-2008, 16:29 | #82 (permalink) |
Member: 617428 Status: Offline Thanks Meter: 52 | use magic sim brother it is easier and much cheaper that getting the box then buy loggs to do this magic sim is the best way. |
12-02-2008, 05:55 | #83 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | Unable to reconnect to the device during a multi-stage load operation Quote:
how to solve Unable to reconnect to the device during a multi-stage load operation >> getting this error during flash your blackberry?? --------------------------------------------------------------------- If you got error during flash your blackberry Unable to reconnect to the device during a multi-stage load operation you should be type START to out cal mode then you will see error 507 , after you need to update os again the blackberry to done your job. also you have must instle latest blackberry desktop manager Last edited by ::.::RAMJAN::.::; 12-02-2008 at 06:04. | |
The Following 22 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post: |
12-04-2008, 08:57 | #84 (permalink) |
No Life Poster Join Date: Mar 2005 Location: Pakistan
Member: 123458 Status: Offline Sonork: 100.1594535 Thanks Meter: 3,421 | How To Back-up 3rd Party Applications How To Back-up 3rd Party Applications Ok, so you need to back-up your 3rd Party Apps: a) because you want to or B) because you are about to wipe your device. Well, heres a How-To to get the job done. Here we go: 1) Download & install the newest Desktop Manager Version HERE 2) Connect BB 3) Open DM 4) Select Switch Device Wizard 5) Select Switch BB Devices 6) Select Next 7) Select USB & then your PIN # 8) Select Next. Enter your Password if required 9) Uncheck User Data & Settings and also Include Messages so that only 3rd Party Apps is selected 10) Select Next 11) When it's done backing up leave the screen as is. DO NOT select Next or Cancel 12) Search your computer Folders & Files for a folder with your PIN # as the name. DEFINITELY check System Files & Hidden Files as well 13) After you find it, copy it & SAVE it to a easy accessible place 14) Go back to the Switch Device Wizard page that we left alone & cancel it. ALSO, check and make sure the folder IS saved before Canceling or the folder will be LOST 15) You can now wipe the device with JL_Cmder RESTORATION 1) After you've loaded the OS go back & run the Apploader & Select ADD 2) "Browse" to find the folder we saved with your PIN # and Double click on the file named yourpin.alx. 3) Your 3rd Party Apps should appear in the Apploader screen 4) Select Finish to load Apps to device 5) Now you may restore other data from a previous backup. **NOTE** Some of the time 3rd Party Apps can be the cause for your problems and might be the reason behind you needing to wipe your device. If you are having problems, this MAY not be the wisest thing for you to do. However, if that's not the case, this tutorial is for you. ** EDIT** It has come to my attention that with Desktop Manager 4.5, it seems that some Applications MAY not back up. I myself, have not had this problem but close friends have and it is worth mentioning. It seems that the apps that get left behind on DM 4.5 are not getting left behind on DM 4.2. You may use which ever DM that suites your fancy. |
The Following User Says Thank You to shahzaadbutt For This Useful Post: |
12-04-2008, 09:35 | #85 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Lagos, Nigeria
Member: 152547 Status: Offline Sonork: 100.1586021 Thanks Meter: 143 | i extracted all the 8 part files to drive c/mml now the sw is telling that no files can be found on the hard drive |
The Following User Says Thank You to akkay For This Useful Post: |
12-04-2008, 14:00 | #86 (permalink) |
Member: 152547 Status: Offline Sonork: 100.1586021 Thanks Meter: 143 | the mfi software is not opening. it is saying UPDATE FAILED. COULD NOT FIND A PART TO THE PART 'T:RAM\MML\update.xml. source.ms.corlib |
12-04-2008, 14:56 | #87 (permalink) |
Junior Member Join Date: Dec 2008
Member: 916139 Status: Offline Thanks Meter: 1 | Ever since i unlocked the 8320 with EFI Multiloader it won't enable mass storage mode, it sees/reads/writes 2 different cards a 1GB and a 8GB but no matter what i do it doesn't enable, i wiped the device and reinstalled the OS and i deleted the USB hubs in device manager, the same thing with my other pc, i have enabled it in media card/options, does anyone have any ideas? |
The Following User Says Thank You to davidmcc For This Useful Post: |
12-04-2008, 19:54 | #88 (permalink) |
No Life Poster Join Date: Dec 2000 Location: J.A.U - Just Another Unlocker Age: 44
Member: 2878 Status: Offline Thanks Meter: 9,123 | IF YOU NEED TO WIPE YOUR BLACKBERRY AND DONT HAVE THIS IN MENU: hust select a password and type it 10 times wrong! your bb will wipe after wrong entrys.... br. hari |
The Following User Says Thank You to oOXTCOo For This Useful Post: |
12-05-2008, 19:41 | #90 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 268154 Status: Offline Thanks Meter: 40 | when u submit 10 times wrong code is for unlock security passwor (user lock). the error u r refering in ur anterior post is: the mfi software is not opening. it is saying UPDATE FAILED. COULD NOT FIND A PART TO THE PART 'T:RAM\MML\update.xml. source.ms.corlib u just have to unplug the network/internet cable in your pc while you run the MFI |
The Following User Says Thank You to ybru For This Useful Post: |
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 4 | 03-23-2011 08:03 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | Mohsin-* | FuriousGold | 0 | 11-10-2008 16:00 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 0 | 08-02-2007 20:08 |
