BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
09-22-2008, 16:16 | #46 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | Quote:
Read again point no : 13. how to read unlock codes with pst carcked ? & here BlackBerryLoggerDriverInstaller | |
09-23-2008, 09:34 | #47 (permalink) |
Freak Poster Join Date: Mar 2006 Location: peshawar,pakistan
Member: 241705 Status: Offline Thanks Meter: 4,294,967,295 | helo mate how can i inter unlock code into blackberry 8310 |
The Following 4,294,967,295 Users Say Thank You to ahmadkhan007 For This Useful Post: |
09-23-2008, 10:16 | #48 (permalink) |
Member: 258172 Status: Offline Thanks Meter: 10,367 | How to enter Unlock Code * Go to settings menu => and then Options * Select Advanced options => and then Sim card * While holding the SHIFT KEY Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD) * Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD) * You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received from vendor and press in the track wheel / jog dial to confirm Your phone is now unlocked |
The Following 3 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post: |
09-24-2008, 07:47 | #50 (permalink) |
Member: 258172 Status: Offline Thanks Meter: 10,367 | The BlackBerry smartphone is detected as a RIM Mass storage device instead of a BlackBerry device in the Windows Device Manager. Cause Summary of Causes This issue may be caused by one of the following: Either incorrect drivers were installed for BlackBerry smartphone, or Windows Update has not been run on the BlackBerry device user's computer since September 1, 2006. RIM Mass Storage Mode or media card is not functioning correctly. The USB port is disabled. The USB adapter is not up to date. The USB controllers are not functioning correctly. Resolution Cause 1 Either incorrect drivers were installed for BlackBerry smartphone, or Windows Update has not been run on the BlackBerry smartphone user's computer since September 1, 2006. Resolution Install on the computer USB Driver 3.x (included with BlackBerry Desktop Software version 4.2). On the computer, click Start > Settings > Control Panel > System. Click the Hardware tab, and then click Device Manager. Open the Device Manager, and then expand Universal Serial Bus controllers. Right click RIM Mass storage device, and then select Update Driver. Windows will search for the drivers using Windows Update. Cause 2 RIM Mass Storage Mode or media card is not functioning correctly. Resolution Perform the following: Set Auto Enable Mass Storage Mode and Mass Storage Mode Support to No. Remove the media card from the BlackBerry smartphone. If the issue still persists, set Media Card Support to Off. Cause 3 The USB port is disabled. Resolution Configure the USB Root Hub settings to prevent the computer from turning off the USB port. To do this, perform the following: On the computer, click Start > Settings > Control Panel > System. Click the Hardware tab, and then click Device Manager. Right-click USB Root Hub, and then select Properties. Click the Power Management tab. Clear the Allow the computer to turn off this device to save power option, and then click OK. Cause 4 The USB adapter is not up to date. Resolution Install the latest version of the USB adapter on the computer. Cause 5 The USB controllers are not functioning correctly. Resolution Remove and reinstall the USB controllers. Note: Verify that the original drivers software that came with the computer is readily available before removing USB controllers. In all instances, contact the computer manufacturer for guidance with the exact steps involved in completing this procedure. On the computer, click Start > Settings > Control Panel > System. Click the Hardware tab, and then click Device Manager. Expand Universal Serial Bus controllers. Uninstall all available instances of USB Root Hub. Restart the computer. Windows should automatically reinstall the USB controllers. br |
The Following 12 Users Say Thank You to ::.::RAMJAN::.:: For This Useful Post: |
09-25-2008, 21:45 | #52 (permalink) |
Junior Member Join Date: Mar 2008
Member: 732612 Status: Offline Thanks Meter: 5 | Can i upload an app to my 7230. when i tried doing dat the desktop manager says the software does not support the phone connected. |
The Following User Says Thank You to phlash For This Useful Post: |
09-26-2008, 09:59 | #53 (permalink) | |
you are welcome | |
09-27-2008, 07:15 | #55 (permalink) |
Member: 258172 Status: Offline Thanks Meter: 10,367 | @srkhan You should have SIM card installed to apply unlock code. If you have SIM card installed, you should see ID for SIM card under "SIM Card" screen by Options -> Advanced Options -> SIM Card. To apply unlock code to your BB8830 Options -> Advanced Options -> SIM Card -> type "mepd" , then type "mep2" It will ask for "Enter Network MEP Code (10 left):" From this field , now you can type "unlock" code. |
09-28-2008, 06:08 | #56 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Quote:
any way r u from BD ? Thanks srkhan | |
The Following User Says Thank You to srkhan For This Useful Post: |
09-28-2008, 21:14 | #57 (permalink) | |
Member: 732612 Status: Offline Thanks Meter: 5 | Quote:
http://i15.photobucket.com/albums/a358/phlash115/bb.jpg the media manger does bot detect my blackberry and i cannot upload jar files to my blackberry | |
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 4 | 03-23-2011 08:03 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | Mohsin-* | FuriousGold | 0 | 11-10-2008 16:00 |
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! | .:hack3r2k:. | FuriousGold | 0 | 08-02-2007 20:08 |
