Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 10-16-2008, 15:30   #61 (permalink)
Member: 4600
i have 8110 for unlock. when i try to unlock using code. but no mep2 or mepp2 work.
thx.
The Following User Says Thank You to GSM RAJ For This Useful Post:
Old 10-24-2008, 06:48   #62 (permalink)
linekbp's Avatar
Member: 81697
if i have a 8830 world phone can i use, reliance in india and rempve the card and put airtel card and use airtel in that same phone?
The Following User Says Thank You to linekbp For This Useful Post:
Old 10-26-2008, 16:58   #63 (permalink)
::.::RAMJAN::.::'s Avatar
Member: 258172
Originally Posted by rubeltelecom View Post
How to repiare 7290 IMIE . my phone IMIE 000000000000000000000 what can i do?
i want to make a try you can send me
thx.
hold down the shift (right of the zero, cap) press meppd
You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2
Enter the unlock code.
8830 world edition phone has both cdma and GSM , you need unlock after you can use any Operator
The Following User Says Thank You to ::.::RAMJAN::.:: For This Useful Post:
Old 10-29-2008, 06:55   #64 (permalink)
Member: 595342
Any idea about unlock Blackberry pearl 8100 just flashing the phone?. It can be possible because here in Mexico it's a fact. Unlock made in minutes.
The Following User Says Thank You to zeppelin79 For This Useful Post:
Old 10-30-2008, 15:29   #65 (permalink)
Member: 883297
blackberry 7130G
there's somebody out there can help me. Pls my blacberry 7130G cant turn on. it said abort instruction, restart. I already restart, open the batt it cant work. pls help me. thanks
The Following User Says Thank You to aerio For This Useful Post:
Old 11-01-2008, 02:32   #66 (permalink)
Member: 884421
Sonork: recoscp
Tankyou ranjam
Great work big men! Best regards from Portugal!!
Originally Posted by ::.::RAMJAN::.:: View Post
Some Information About All BlackBerry phones
I Hope This Will Help Every one & No Need To Search Forum Because We Make All In One Here.
1. How To Check firmware Version ?
To check the firmware version of your Blackberry simply navigate it? menu:-
Goto SETTINGS or OPTIONS then ABOUT
Images of firmware version
2. How To Connect blackberry With Pc.?
connect your blackberry to pc with data cable (same motorola v3 usb cable)
3. how To update/ReInstall BlackBerry Operating System ?
Connect your device to your computer.
Open the BlackBerry® Desktop Manager.
Click Application Loader.
Click Start in Add/Remove Applications or Update Applications.
If necessary, perform the following actions:
If the Device Security Password dialog box appears, type your device password. Click Next.
If the Communication Port Selection dialog box appears, specify a communications port. Click Next.
Click Next.
Perform any of the following actions:
To add an application that appears in the list, select the check box beside the application.
To add an application that does not appear in the list, click Browse. Double-click an application loader (.alx or .ali) file.
Click Next.
Click Finish.
4. from where we get BlackBerry desktop software ?
official download link
Latest Blackberry Desktopmanager version 4.6.0.12 > rapidshare link
5. from where we get BlackBerry Operating System ?
download link here
and dont forget to Delete the vendor.xml file located in c:\program files\common files\research in motion\apploader
6. how to check Vendor ID (operator) ?
7. how to reset blackberry password ?
enter wrong code 10 times your phone will reset code after enter (blackberry) in case of code that's all
8. How do I determine if my BlackBerry is "unlocked" ?
Images of Locked Device
Images of Unlocked Device
9. To obtain an unlock code for your BlackBerry
You will need to know your IMEI number for your BB. Look at Options, Status. The IMEI may also be found on the white sticker under the battery (sometimes hard to read--make sure you read it right!). or need to know Vendor ID (operator)
You can purchase the unlock code from various vendors. These listed below are reputable vendors with good feedback from us/user
>>Software or online Server Products
OR
>>Main Sales Section
10. How to enter my Unlock Code on BlackBerry ?
11. When we get code error specially with 8 digit unlock code ?
solution here
12. Images of Alt/Shift key
13. how many way to unlock BlackBerry phones ?
A. Use Service Tools or free tool (pst carcked for blackberry read code)
B. no key sim / u sim
C. unlock by imei
14. which BlackBerry phones supported by Service Tools or free tool (pst carcked for blackberry read code) ?
CodeReader supported BlackBerry 5***, 6***, 7*** series
71xx Series : 7100g,7100g,7100i,7100r,7100t,7100v,7105t,7130e
72xx Series : 7230, 7250, 7280, 7290,
75xx Series : 7520,
77xx Series : 7730, 7750, 7780,
Phones not supported: X700, 7510 (iden), 5810, H700
15. how to read unlock codes with pst carcked ?
Instructions:
16. from where i get free tool (pst carcked for blackberry read code) download ?
download link
17. BlackBerryLoggerDriverInstaller download link
18. How do I Recover a Dead BlackBerry ?
19. How To: ReInstall OS When Computer Won't Recognize The Device Is Connected ??
solution here
20. how to solve if i get this massage (sorry only emergency call are allowed) in call ?
you need to remove IT policy
21. how to remove IT policy ?
Go to your Options : Security >> Security Options (the same page where you can enable/disable passwords) & scroll to the bottom. If there's an IT policy attached, it will be mentioned there. Remove the IT policy using these instructions , link here is the working solution how to remove IT policy tested by me many times
22. how to solve Authorization Failure??
Here is the solution:
Go to Phone Options
Select General Options
Select Restrict My Identityt - NO
Select Show "My Number" - YES
You are all set.
No more Authorization Failure sending / receiving calls and messages.
23. What is 'data connection refused' ?
* If you do not have a BlackBerry Data Plan then you will see this message on the main screen!
* If you have a data plan and are seeing this message then you will need to call your service provider and have them check the provisioning on the account.
* If you do not have a data plan and want to hide this message from showing up then go to:
Options >> Mobile Network and turn Data Services to OFF.
24. What do I need a Data Plan for ?
read from this link
25. How do I wipe/reload the BlackBerry using Jl Cmder ?
link here
26. What to do next if Jl Cmder will not connect and wipe ?
link here
More Come Soon.......
BEST REGARDS
::.::RAMJAN::.::@TRUST_GSM
The Following User Says Thank You to recoscp For This Useful Post:
Old 11-01-2008, 17:42   #67 (permalink)
Member: 258172
may you need to wipe and reload your device
Old 11-07-2008, 19:56   #68 (permalink)
Member: 486756
Update BlackBerry 8100 T-mobile With Lenguage Spanish
How Put Lenguage Spanish in BlackBerry 8100 T-Mobile. i Serching and Found the Donwload Support in T-Mobile Web site, but ask me the Number os Mobile, My client not have the Number. Another solutions for These inconvenience? Thank's in advance.
The Following User Says Thank You to chakita For This Useful Post:
Old 11-08-2008, 04:56   #69 (permalink)
Member: 258172
BlackBerry Firmwares Download Here (All Models)!
Old 11-08-2008, 05:05   #70 (permalink)
Member: 895490
thanks
very very thanks to ::::RAMJAN:::
hi firiend i have blackberry 8700g model having problem after on theme (apple iphone theme for bb) installing my device is restarted every 10 second .....
after i read your solution i do that i resotre my device ....
thanks very very much
my Email id is : notilasgroup@gmail.com
The Following User Says Thank You to notilasgroup For This Useful Post:
Old 11-08-2008, 09:38   #71 (permalink)
rana_'s Avatar
Member: 597570
Sonork: 100.1590733
bro i need blackberry 7290 T-MOBILE flash file.......plz help me.
sir very argent plz......
thnx advance.
BR,rana_
The Following User Says Thank You to rana_ For This Useful Post:
Old 11-08-2008, 09:41   #72 (permalink)
Member: 258172
thnx advance.
BR,rana_
BlackBerry Device Latest Firmware downloads [ONLY HERE]
Old 11-08-2008, 12:18   #73 (permalink)
rana_'s Avatar
Member: 597570
Sonork: 100.1590733
brother here is 7290 t-mobile flash file not found..............
another link plzzzzzzzzzzzz
BR,rana_
Old 11-08-2008, 12:35   #74 (permalink)
Member: 258172
BR,rana_
Old 11-09-2008, 10:51   #75 (permalink)
Member: 293270
i have 8100 imei is... 357840012148662 locked in t-mobile, can you help me unlock the phone...
The Following User Says Thank You to 2net@jay For This Useful Post:
[FAQ] FuriousGold - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! .:hack3r2k:. FuriouS TeaM Products 4 03-23-2011 08:03
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! Mohsin-* FuriouS TeaM Products 0 11-10-2008 15:00
F.A.Q - Frequently Asked Questions !!! READ BEFORE ASKING ANYTHING ! .:hack3r2k:. FuriouS TeaM Products 0 08-02-2007 20:08
Page generated in 0.48939 seconds with 12 queries
