BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-04-2009, 15:06 | #1 (permalink) |
Freak Poster Join Date: Jun 2005 Age: 46
Member: 154834 Status: Offline Thanks Meter: 20 | help!!! blackberry 9000 dead |
06-05-2009, 09:31 | #2 (permalink) | |
Freak Poster Join Date: Jun 2008 Location: uk. england
Member: 785137 Status: Offline Thanks Meter: 18 | Quote:
Br, Baljitsb. | |
06-05-2009, 10:16 | #3 (permalink) | |
Cheater -Don't Deal with him- Join Date: Apr 2007 Location: Inside of my computer
Member: 490708 Status: Offline Sonork: 100.1587135 Thanks Meter: 569 | Quote:
Do flash without betrry.then when it need attach again load betrry. br | |
06-06-2009, 16:31 | #5 (permalink) |
Freak Poster Join Date: Mar 2006 Location: Ina
Member: 247765 Status: Offline Sonork: 100.1607102 Thanks Meter: 7 | @servisoft there are 2 different problem for "red blink" 1. u'r batt is empty 2. u'r bold is already -nuke- with "-a" option try this to solve u'r problem.... (option 1) "try with other "full batt" or recharge u'r empty batt (option 2) 1. load bold (8....E07) "factory os" 2. load full firmware hope this may help to solved u'r problem. |
09-15-2009, 04:51 | #6 (permalink) |
Freak Poster Join Date: Nov 2008 Location: ina 4 sure
Member: 911645 Status: Offline Thanks Meter: 19 | sir tried already using full battery, still no luck anyway.. will u kindly explain opt. no.2 little bit detailed? here? u know, PC won't even detect phone, there should be some tricks to do those things (esp. opt.2-1) best regards, Last edited by ru_dee; 09-15-2009 at 04:56. |
10-09-2009, 00:10 | #7 (permalink) | |
Insane Poster Join Date: Apr 2007
Member: 495719 Status: Offline Thanks Meter: 8 | Quote:
i have the same probem tried different ways but no luck still dead anyone can help? | |
01-06-2010, 13:37 | #12 (permalink) |
No Life Poster Join Date: Aug 2006
Member: 331337 Status: Offline Thanks Meter: 72 | hi, i had fully working 9000 bold. it was switching on and evrything was fully working until i bought another 9000 bold dead. i thought it might be battery problem in dead phone so i swapped battery from the phone dead phone to working one. now i m trying to switching my working phone with its own old battery which was working fine but its not switching on. there is no red light coming on for some reason. any idea why its doing that. please help |
01-13-2010, 13:08 | #13 (permalink) |
Member: 331337 Status: Offline Thanks Meter: 72 | hi guys.i had 2 phones blackberry bold 9000. both was not switching on and was not charging when i used to connect to charger. i tryied everything but i had no luck with both them. now i tryied something else, i took battery out for 48 hours and didnt do nothing. after 2 days i put battery in the phone and i put it on charge amazing after few min. its start showing charging. both phon working fully now. please try this. make sure you take battery out for 2 days and do not connect to charger. after 2 days put battery in and connect phone with charger. leave for about 10min it should start switch on. |
01-13-2010, 16:50 | #14 (permalink) | |
No Life Poster Join Date: May 2005 Location: GULMI Age: 49
Member: 143007 Status: Offline Thanks Meter: 141 | Quote:
01-14-2010, 23:50 | #15 (permalink) |
Freak Poster Join Date: Jul 2005
Member: 158999 Status: Offline Thanks Meter: 41 | [QUOTE = ejército gemelas; 5255901] Hola guys.i había 2 teléfonos BlackBerry 9000 audaz. tanto no se enciende y no se carga cuando se utiliza para conectar al cargador. todo lo que tryied pero no tuve suerte con los ellos. ahora algo que tryied los demás, me llevó a cabo la batería durante 48 horas y aún no ha hacer nada. después de 2 días me puse la batería en el teléfono y lo puse en la carga sorprendente, después de pocos minutos. empezar a mostrar su carga. tanto phon de trabajo completamente ahora. *Por favor, intente esto. Asegúrese de llevar a cabo la batería durante 2 días y no se conecta al cargador. después de 2 días en poner la batería y conectar el teléfono con el cargador. Deja de unos 10 minutos debería empezar a encender. [/ QUOTE] yes mi friend same problem phone dead y phone new the 8weken help !!! |
blackberry 9000 dead | kadekrudi | BlackBerry (RIM) | 23 | 08-08-2011 21:18 |
Blackberry 9000 dead | alshara | BlackBerry (RIM) | 0 | 03-27-2010 15:14 |
help blackberry 9000 unlocking error....... | rsftronics | Various | 3 | 09-16-2009 05:14 |
help blackberry 9000 unlocking error....... | rsftronics | BlackBerry (RIM) | 1 | 09-10-2009 02:18 |
blackberry 9000 dead | telefan21 | BlackBerry (RIM) | 2 | 05-19-2009 14:37 |
