Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 04-14-2009, 13:38   #1 (permalink)
Member: 11288
Thanks Meter: 23
how to create loader.bat file for BB
please i need help how to create loader.bat file for a blackberry using sfi file
( what is dos commande )
thanks
The Following 2 Users Say Thank You to zata222 For This Useful Post:
Old 04-14-2009, 18:07   #2 (permalink)
Member: 956117
Thanks Meter: 66
  1. Locate the sfi file you wish to use. This will already be on your computer at "c:\Program Files\Common Files\Research In Motion\Shared\Loader Files\8100-v4.2.0.64_P2.2.0.37\GPRS\rim8100g.sfi" if your device is an 8100 running software version 4.2.0.64, platform version 2.2.0.37 and if you have installed that version of device software to your computer. To find out what if any device software versions you have installed, look in the folder C:\Program Files\Common Files\Research In Motion\Shared\Loader Files. If you see a folder that matches your BlackBerry model and software version then open that folder and inside you will see some files and two folders. The cod files (which you don't need to worry about) are in the Java folder and your sfi file is inside the other folder which is probably named CDMA, GPRS, UMTS, or IDEN. If you didn't find your sfi file then you can locate, download, and install your device software. Possibly the easiest way to find this is by typing your model number into a google search along with site:blackberry.com/Downloads. At least one of the search results should take you to a download page that has the version of software that is on your phone. Once you install it to your computer, repeat step number 1 to find your sfi file.
  2. Create a folder to hold your sfi file and the loader.bat file. Create this folder anywhere you like...on the Desktop, My Documents, c:\BlackBerryStuff, or wherever.
  3. Copy your sfi file into the folder. You can have one or many sfi files and loader batch files in this folder. Even if you only have one sfi file and one loader file, I recommend renaming your sfi file to the name of the folder inside c:\Program Files\Common Files\Research In Motion\Shared\Loader Files\. For example, after copying my rim8100g.sfi file to my loader folder I would rename it to 8100-v4.2.0.64_P2.2.0.37.sfi. Copy the name of your renamed sfi file to the clipboard for use in the next step.
  4. Create the loader batch file. Open notepad or your favorite text editor with an empty document. Type
    cfp -u load
    making sure there is a space after load. Paste the sfi file name after the space after the word "load". For my example, the document would contain the text
    cfp -u load 8100-v4.2.0.64_P2.2.0.37.sfi
    Now we need to save the file in the loader folder. I recommend naming it by typing load_ and then pasting the sfi file name (which should still be in the clipboard) making sure to change the extension from .sfi to .bat. For my example, the loader batch file is named load_8100-v4.2.0.64_P2.2.0.37.bat. When saving from notepad, make sure to change the "Save as type" from "Text Documents (*.txt)" to "All Files". This will make sure your batch file doesn't end up named something like load_8100-v4.2.0.64_P2.2.0.37.bat.txt
  5. Finally, you need to copy cfp.exe into the loader folder. Searching google for cfp.exe hahanew.exe should give you a place to download cfp.exe or at least a torrent link for it.
The Following 6 Users Say Thank You to elseWestcott For This Useful Post:
Old 05-13-2009, 07:31   #3 (permalink)
Member: 164316
Thanks Meter: 6
hai can u more explain how to create .bat ?
Old 05-13-2009, 08:15   #4 (permalink)
Member: 164316
Thanks Meter: 6
Hai , can u more explain how to create this? with picture maybe and the needed files... thx before
Old 05-10-2011, 14:39   #5 (permalink)
Member: 974164
Thanks Meter: 25
sir can u explain more easy last 2 steps.. or any video..........
thanks in advanced.............
Old 05-10-2011, 15:05   #6 (permalink)
Member: 125632
Thanks Meter: 229
Talking
just use notpad,,
then "saveas"(not save)
window open,,at the bottom,there is "whateverUcalledIT.txt"
along side the name of file is little arrow pointing down click that..
select "all files"
then change the name to (.bat) so u av "whateverUcalledIT.bat"
then save...
or open a diff .bat file edit it in notepad,and click saveas,
same as above
Old 05-10-2011, 15:34   #7 (permalink)
JAVAZ's Avatar
Member: 726032
Sonork: ....Ssstt....
Thanks Meter: 13
Originally Posted by bcatlock1 View Post
just use notpad,,
select "all files"
then save...
same as above
Old 05-10-2011, 18:11   #8 (permalink)
Member: 742060
Thanks Meter: 15
  4. Create the loader batch file. Open notepad or your favorite text editor with an empty document. Type making sure there is a space after load. Paste the sfi file name after the space after the word "load". For my example, the document would contain the text Now we need to save the file in the loader folder. I recommend naming it by typing load_ and then pasting the sfi file name (which should still be in the clipboard) making sure to change the extension from .sfi to .bat. For my example, the loader batch file is named load_8100-v4.2.0.64_P2.2.0.37.bat. When saving from notepad, make sure to change the "Save as type" from "Text Documents (*.txt)" to "All Files". This will make sure your batch file doesn't end up named something like load_8100-v4.2.0.64_P2.2.0.37.bat.txt
you describe the old version to new versions such as os 6 like where do I make
The Following User Says Thank You to 69_9000 For This Useful Post:
Old 05-11-2011, 08:41   #9 (permalink)
ameerali19's Avatar
Member: 884639
Sonork: 100.1597105
Thanks Meter: 265
i didnt get whats the benefit or use if the file????
pls share here
How to create/read PM file for 5310? medyo Nokia Base Band 5 ( BB-5 ) 0 01-08-2008 22:57
How to create full erase file ? Henry14 Nokia Digital Core Technology 4 ( DCT-4 ) 0 09-07-2004 09:58
how to create installer sis file x3w Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-24-2004 19:27
how to create a sbn file? melyse Sony Ericsson 0 10-01-2003 11:19
Page generated in 0.34708 seconds with 8 queries
