Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 04-22-2010, 20:21   #1 (permalink)
Member: 1239106
Thanks Meter: 2
How to Disable Password
I am trying to disable the password feature on my Bold, but there's a small lock icon next to the word "Enabled" and I'm undable to choose the option.
I need to disable it so that i can read the MEP code to unlock it.
The bold is in vodafone UK n need to unlock to Maxis / Celcom Malaysia.
Please help.
Thanks.
The Following User Says Thank You to xemox For This Useful Post:
Old 04-23-2010, 02:07   #2 (permalink)
Member: 965657
Thanks Meter: 51
remove IT Policy
Removing IT Policy
Unlocking the Blackberry.
First of all, this is not a guide on how to remove carrier information from a Blackberry. If you're unable to use a different SIM card than the one that was originally supplied with your device, look elsewhere. However if, like many others you have a Blackberry that is locked by a BES, meaning you're unable to change certain settings, or install Third Party Applications then read on. Essentially, the problem is that your Blackberry has at some point been connected to a BES (Blackberry Enterprise Server), and this BES has placed a restrictive Security Policy (or IT Policy) on your device. A quick check to see if this is the case can be done by going to Options/Security on your Device. If you see any references to IT Policy whatsoever, then you have a potentially restrictive IT Policy that can be removed.
The Disclaimer/Intended Use. This guide is intended for use by people that own their own Blackberry, and for whatever reason, have inherited a company's IT Policy on their Device. Really, there are two scenarios where this guide is useful. You, like me, bought a Blackberry on EBay and are unable to make changes to the settings or install Third Party Applications. You have a Blackberry that was previously connected to a company's BES and, for whatever reason; you no longer intend to make connections to that BES. If you're still connected to a Company BES, and simply want to install the latest and greatest Third Party Application I wouldn't recommend this approach. Go talk to your administrators and ask them to grant you the appropriate rights. There are two problems in using this guide to bypass your Company's Security Policy. Firstly, whenever you reconnect to the Company Server, your security settings will revert back to how they were. Secondly, and (perhaps) more importantly, you run the risk of getting fired.
Procedure
Method One
Method 1: IT Policy Removal (Preferred)
If you have any 8xxx or 9xxx device the best method for removing IT policy is to update it to OS 4.3 or higher (if possible) and you can use JL_Cmder's "resettofactory" command to remove ALL IT policy, Firewall restrictions and Application Permission settings. After you've upgraded to OS 4.3 or higher, simply backup the device using Desktop Manager, close Desktop Manager, then run JL_Cmder and execute the "resettofactory" command. The device will do a security wipe of the device; (meaning wipe your data but leave the OS, DO NOT use the "Wipe" command in JL_Cmder) then reboot leaving the OS, 3rd party apps but no data AND, best of all, NO IT policy whatsoever. When you're done, simply restore your backup and you're good to go with no policy or locked firewall. You can downgrade back to the old OS if you desire, too.
Download JL_Cmder from this link: JL_Cmder - BlackBerryForums.com : Your Number One BlackBerry Community
If your 7xxx or 8xxx device is running OS 4.2 or lower (look in Options >About) and you can't upgrade it to OS 4.3 or higher you will NOT be able to use method 1 above and you will need to use method #2 below:
Method Two
Step 1
Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again.
If you don't have the CD that came with your Blackberry, the Software can be downloaded here. BlackBerry Software Site
Step 2
Download the file policy.bin Download Here. and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry).
Step 3
Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe (Newer 4.2 OS Devices Goto Options/Security Options/General Settings/Wipe) on the Device.
If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest Desktop Manger Software, then the latest Handheld Software. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts.
Step 4
Close the Desktop Manager if it is open.
Step 5
From the Windows Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to:
HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager
Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to:
C:\Program Files\Research In Motion\BlackBerry\policy.bin
Step 6
Open the Desktop Manager.
Step 7
Connect the Device.
Verification
Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications.
About this Guide.
This guide was born from an amazing amount of frustration shortly after buying a Blackberry 7230 on EBay to test an Application I was working on. It addresses what I consider either a bug or an extremely poorly implemented feature of the Blackberry device, and a problem I'm sure 80 percent of people who buy a Blackberry on EBay face.
The Following User Says Thank You to d1ulove For This Useful Post:
Old 04-23-2010, 03:10   #3 (permalink)
GSMman187's Avatar
Member: 917893
Sonork: 100.1584763
Thanks Meter: 3,137
Please help.
Thanks.
You Need to remove IT policy , here is the working solution how to remove IT policy tested many times
Go to your Options : Security >> Security Options (the same page where you can enable/disable passwords) & scroll to the bottom. If there's an IT policy attached, it will be mentioned there. Remove the IT policy using these instructions
Procedure
Step 1 : Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here.
Step 2 : Download the file policy.bin (attached at bottom) and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry).
Step 3 : Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts.
Step 4 : Close the Desktop Manager if it is open.
Step 5 : From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to:
Step 6 : Open the Desktop Manager.
Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications.
Things should be back to ok
GSM FORUM AUSGSM Australia COMMUNITY FILE here.
Old 04-23-2010, 03:37   #4 (permalink)
srkhan's Avatar
Member: 153695
Sonork: srkhan
Thanks Meter: 729
What is the deference with d1ulove and GSMman187 given solution
Old 04-23-2010, 09:52   #5 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,418
Arrow deference
Deference Here
Only wipe ur device using BBSAK It will remove the policy
Its easy way !
Delower
The Following User Says Thank You to delower10 For This Useful Post:
Old 04-24-2010, 05:50   #6 (permalink)
ami_ridho's Avatar
Member: 396831
Thanks Meter: 19
Arrow
Originally Posted by delower10 View Post
Deference Here
Its easy way !
Delower
yes that right just use BBSAK or JL_Cmder ......
The Following User Says Thank You to ami_ridho For This Useful Post:
Old 04-24-2010, 21:44   #7 (permalink)
Member: 338069
we would really appreciate it if any mate could tell us how to use BBSAK to remove IT policy from a BB Bold 9000.
Thanks in advance.
Old 04-24-2010, 22:11   #8 (permalink)
Member: 1264911
Thanks Meter: 4
srry bro don't have experience with that product.
Old 04-25-2010, 07:27   #9 (permalink)
delower10's Avatar
Member: 890592
Sonork: 100.1581951
Thanks Meter: 4,418
Arrow
Thanks in advance.
Download BBSAK From Here !
Procedure :
Open BBSAK > type device password > then u will see the BB Pin > & Make wipe device
That's all
Delower
Old 10-06-2010, 21:27   #10 (permalink)
Member: 141164
Thanks Meter: 35
Procedure :
That's all
Delower
I Did Follow ur Instruction Now Fone Shows 505 error at fone screen. i got blackberry 7230
Now Wat Shall I Do Help me Plz
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Page generated in 0.41497 seconds with 8 queries
