BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
06-02-2011, 12:47 | #4 (permalink) |
No Life Poster Join Date: May 2008 Location: ...::::GUJRAT::::...
Member: 781860 Status: Offline Thanks Meter: 203 | Method One Method 1: IT Policy Removal (Preferred) If you have any 8xxx or 9xxx device the best method for removing IT policy is to update it to OS 4.3 or higher (if possible) and you can use JL_Cmder's "resettofactory" command to remove ALL IT policy, Firewall restrictions and Application Permission settings. After you've upgraded to OS 4.3 or higher, simply backup the device using Desktop Manager, close Desktop Manager, then run JL_Cmder and execute the "resettofactory" command. The device will do a security wipe of the device; (meaning wipe your data but leave the OS, DO NOT use the "Wipe" command in JL_Cmder) then reboot leaving the OS, 3rd party apps but no data AND, best of all, NO IT policy whatsoever. When you're done, simply restore your backup and you're good to go with no policy or locked firewall. You can downgrade back to the old OS if you desire, too. Download JL_Cmder from this link: JL_Cmder - BlackBerry Forums Support Community If your 7xxx or 8xxx device is running OS 4.2 or lower (look in Options >About) and you can't upgrade it to OS 4.3 or higher you will NOT be able to use method 1 above and you will need to use method #2 below: Method Two Step 1 Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. BlackBerry Software Site Step 2 Download the file policy.bin Download Here. and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe (Newer 4.2 OS Devices Goto Options/Security Options/General Settings/Wipe) on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest Desktop Manger Software, then the latest Handheld Software. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 Close the Desktop Manager if it is open. Step 5 From the Windows Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 Open the Desktop Manager. Step 7 Connect the Device. |
The Following User Says Thank You to /FAISAL/ For This Useful Post: |
06-03-2011, 07:55 | #5 (permalink) | |
No Life Poster Join Date: Dec 2010 Location: ..:: GSM-Forum ::..
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | Quote:
phone version v4.5.0.174 i try to Method 1: IT Policy Removal (Preferred) but note complete ...... Any Solution .... | |
06-03-2011, 09:45 | #6 (permalink) |
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | my 2end Blackberry 8310 Success to Method 1 phone v4.5.0.55 Method One Method 1: IT Policy Removal (Preferred) If you have any 8xxx or 9xxx device the best method for removing IT policy is to update it to OS 4.3 or higher (if possible) and you can use JL_Cmder's "resettofactory" command to remove ALL IT policy, Firewall restrictions and Application Permission settings. After you've upgraded to OS 4.3 or higher, simply backup the device using Desktop Manager, close Desktop Manager, then run JL_Cmder and execute the "resettofactory" command. The device will do a security wipe of the device; (meaning wipe your data but leave the OS, DO NOT use the "Wipe" command in JL_Cmder) then reboot leaving the OS, 3rd party apps but no data AND, best of all, NO IT policy whatsoever. When you're done, simply restore your backup and you're good to go with no policy or locked firewall. You can downgrade back to the old OS if you desire, too. Thanks for the Share ..... |
06-03-2011, 11:42 | #8 (permalink) | |
Junior Member Join Date: Jun 2007 Location: Vietnam
Member: 532123 Status: Offline Thanks Meter: 7 | You can try this soft Quote:
already tested ok | |
The Following User Says Thank You to tvdmd75 For This Useful Post: |
06-04-2011, 06:58 | #9 (permalink) | |
This is a 100000000000% Success Solution Thanks for The Share Bro | |
03-22-2013, 15:10 | #11 (permalink) | |
Freak Poster Join Date: Oct 2012 Location: Gsmhosting Forum
Member: 1832100 Status: Offline Thanks Meter: 63 | BlackBerry 8310 How to Disable Security Lock ( IT policy ) Quote:
phone version v4.5.0.174 i try to Method 1: IT Policy Removal (Preferred) but note complete ...... Any Other Solution .... | |
03-22-2013, 22:26 | #13 (permalink) |
Junior Member Join Date: Aug 2009 Location: Dominican Republic
Member: 1096913 Status: Offline Thanks Meter: 1 | You can remove the ITPolicy using CrackUtil Program, its easy!!! Instal it !!!!!!!!! |
The Following User Says Thank You to chelov60 For This Useful Post: |
03-23-2013, 07:01 | #15 (permalink) | |
Member: 1476028 Status: Offline Sonork: 100.1625985 Thanks Meter: 114 | BlackBerry 8310 Success Fully Disable Security Lock ( IT policy ) Quote:
download this - CrackUtil . CrackUtil.zip Then Do This Step : 1000% Tested for Me ..... | |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-10-1999 22:36 |
