How to enter Unlock Code on BlackBerry Phones? [ONLY HERE] How to enter Unlock Code on BlackBerry Phones, ONLY HERE All other threads about same topic will be deleted without warning ! Model : BlackBerry 8700 Go to the Menu -> Options -> Advanced Options -> Sim card press select, while holding the Shift key (bottom right corner CAPS), type mepd. You should now see the five locking categories listed, while holding the alt key, type mep2. Release the alt key. You are now prompted to enter the Network MEP code. Enter the code, enter Return/Enter, the device should then be unlocked. Model : BlackBerry 8800 You must have a SIM card in your phone to complete these steps ( Can be active or inactive ) 1 - Go to settings menu => and then Options 2 - Select Advanced options => and then Sim card 3 - Type MEPD using your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD) 4 - Hold the ALT Key while typing in MEPE on your Blackberry keyboard (NOTE: You will not see any text appear on the screen while typing MEPD) 5 - You should be presented with a prompt "Enter Network MEP Code". Type in the 16 digit unlock code received from UnlockBase.com and press in the track wheel / jog dial to confirm 6 - Your phone is now unlocked Model : 9500/9530 Series Ensure the SIM Card that came pre-installed in the 9530 is inserted. Go to 'Manage Connections' Click on 'Turn All Connections Off' Go to 'Options' Click on 'Status' Go back to 'Options' Click on 'Advanced Options' Click on 'SIM Card' Type 'MEPD' (letters will not appear on-screen but a menu will pop up) Type 'MEP2' (user will be prompted to enter MEP code) Enter the unlock code Reboot device Go to 'Manage Connections' Click on 'Restore Connections' Device is now unlocked Please note when entering MEPD, ETC. You need to use caps. Model : BlackBerry 8220 1. Insert any sim card 2. Turn off all of the wireless connections 3. Go to Options 4. Select Advanced Options 5. Select SIM Card 6. Hit menu select show keyboard (where needed) 7. Type MEPPD or MEPD (you will not be able to see the typed info) 8. Enter MEP2 or MEPP2 9. Now it will say enter network mep code Model : BlackBerry 8100 Pearl 1 - Go to Options Menu => Advanced Options 2 - In the SIM Card menu, hold down the shift (right of the zero, cap) press meppd 3 - You'll see the unlocking level screen there you hold the ALT key (left side below @) type mepp2 4 - Enter the unlock code. Model : BlackBerry 8100 (Vodafone Australia) PLEASE READ THE INSTRUCTIONS CAREFULLY BEFORE YOU ATTEMPT ANY UNLOCK PROCESS This procedure unlocks the handset from being network restricted from only using SIM cards from Vodafone Australia. In case of difficulties, please refer to the FAQ listed below 1. Take note of the unlocking code shown above 2. Insert a Non-Vodafone Australia working SIM card. 3. Ensure the phone is charged and then switch the phone on. 4. Optional Step: If the SIM card has a PIN, enter your PIN number. (See FAQ below) 5. The phone will then display a message. The most common is ?nvalid SIM card? (Different message? See FAQ below) 6. Select ?urn Wireless Off? 7. Select ?ettings?Menu , then go to Advanced Options > SIM Card 8. Type alt-MEPT by holding the ALT-key and typing the letters MEPT with multitap i.e. type hold ALT, type {M}{ER}{OP}{OP}{TY} 9. When prompted with ?nter Network MEP code (255 left)?on the screen, enter the 16-digit network unlock code provided for your phone, then press Enter. (Unlocking code is shown above) 10. Reset the phone by pulling the battery 11. Switch the phone on and the handset will be unlocked automatically. This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) FAQ: Question: My phone asks to enter a PIN number Answer: For SIM cards with PIN ENBLED you will be required to enter a PIN. This is not the unlocking code that has just been provided. For information concerning the PIN, PIN2, PUK and PUK2 codes for a SIM card please read the manual that came with your phone. This is not a handset unlocking difficulty. Question: My handset displays a different message then what is shown in this procedure when I insert a Non Vodafone Australia SIM card. Answer: The most common message the phone will display is ?nvalid SIM card? Because each handset may have a different variation in software there is no common message. If your handset displays a different message it is recommended to move onto the next step. Note: Faulty SIM Cards - The handset may also display messages indicating the SIM you are using to unlock the handset is faulty, it could display ?nsert SIM??ad Card? ?ard Error?or ?ard Rejected? confirm the SIM card is inserted correctly ?Gold area downwards and the cut of the corner matches correctly. You will need a working Non Vodafone SIM card to unlock the handset, Vodafone can not assists with other networks faulty SIMs. Question: I am outside of Australia and experiencing difficulties unlocking the phone that I purchased from a Vodafone Australia outlet Answer: Clearly note this in the difficulties description. Vodafone Australia can only send a reply to the difficulty by email. -------------------- Model : All BlackBerry 1 - Using the menu go to Settings Menu -> SIM card pressselect. 2 - While holding the SHIFT key, type mepd 3 - You should now see the five locking categories listed. 4 - While holding the SHIFT KEY, type mep2. 5 - Release the shift key. 6 - You are now prompted to enter the Network MEP code (it will also state how many attempts left) 7 - Enter the code 8 - Enter Return/Enter 9 - The device should then be unlocked NOTE : please keep this thread clean out of thanks posts & good work posts , only for How to enter Unlock Code on BlackBerry. Thread started as to clean mess from BB Faq;) Best Regards ::.::RAMJAN::.:: |
and if it has " Enter network MEP code (0 left):" then?? what will,be the sol? how do v reset it? regards |
and its not work on 8XXX and higher BR Delower |
its blackberry 8900 javelin |
BR Delower |
blackberry 9530 unlock broblem help i have balckberry 9530 unlock but i tried so many time it is not become enter mep code because personalization sim disabled ok then netwok inactive it is my problem for not become enter mep code |
I have bb 8310( reset password tried 10 time set automatically formated all data delete ) now when I open its searching long time .( vodafone uk) how to solve this problem |
when i run mfi multiloader , a message shows something like this ,cant load boot images can anyone help me 4 this |
how about 8300 cannot go to mep2 |
how about 8520 ? |
How do i remove activation required on black berry screen and put my phone number on it? |
