Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-12-2013, 08:50   #1 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
bb z10 update success thanks I sumo
detected with PC but not with BBlink SW updater
solution
To recover the BlackBerry 10 smartphone complete the following steps:
1. Shutdown BlackBerry Link (and BlackBerry Desktop Software if installed).
2. Detach all BlackBerry smartphones, including the BlackBerry 10 smartphone that cannot be booted up.
3. Using Internet Explorer navigate to BlackBerry Software Updates, scroll down the page and select the Check for Updates button.
4. Connect the BlackBerry 10 smartphone that cannot be booted up.
5. Hold the power button for 10 seconds until it turns off, then press the power button again so it turns on. A prompt will appear and the BlackBerry smartphone will show in the drop down list shortly after the LED lights up as red (it could show up as USB: UNKNOWN or USB: BlackBerry (PIN) – both are normal/fine). Click the OK Button as soon as it becomes enabled. NOTE: there is only 15 seconds to do this.
Note: Once the above steps are completed successfully a dialog will be displayed stating Checking for BlackBerry Device Software updates.
6. The BlackBerry 10 smartphone will now power itself off after 120 seconds. Shortly after the 120 seconds, the BlackBerry smartphone LED should turn green. Continue to wait after the LED turns green and you will be prompted to install BlackBerry Device Software. Follow the prompts to install the BlackBerry Software and once the installation is complete the smartphone will boot up and is now recovered.
Note: If neither BlackBerry Link nor BlackBerry Desktop Software is installed please start at Step 2.
link
http://forum.gsmhosting.com/vbb/f489...mware-1610968/
The Following User Says Thank You to aiyon_861 For This Useful Post:
Old 02-12-2013, 10:41   #2 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
tested BBz10 update ...not using BB sw link
Old 02-12-2013, 11:51   #3 (permalink)
I_sumo's Avatar
Member: 38103
Sonork: 100.100782
Thanks Meter: 165
oh wow that's great - just saw this thread !
Happy ending
Blackberry is now using a new system for web based update method.
HERE one quick note:
IF you close the particular BROWSER then the files downloaded in CACHE (sizes more than 1GB approx) would be deleted automatically. So until process gets completed it is not advisable to close the browser through which you have launched the update client.
Thanks for the credits given to me.
br
The Following 2 Users Say Thank You to I_sumo For This Useful Post:
Old 02-16-2013, 09:37   #4 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
Happy ending
br
tested solution for new z10 SW issue ... i have another one and now its working
Old 02-18-2013, 19:03   #5 (permalink)
aiyon_861's Avatar
Member: 586707
Thanks Meter: 129
i have now more BB-z10 flashing succes nice one ...in 1 day i recieve 5 mobile's with SW problem....
Old 02-19-2013, 10:24   #6 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
that's what i am facing after trying to install updates:
An error has occurred while downloading software for your device. Please verify your Internet connection or try again later, if the problem persists.
Old 02-19-2013, 10:50   #7 (permalink)
Faheem Anjum's Avatar
Member: 399832
Sonork: Faheem Anjum
Thanks Meter: 24,310
so check internet connection as you get msg from software
Old 02-19-2013, 10:56   #8 (permalink)
cellularry's Avatar
Member: 42276
Thanks Meter: 47
it is not internet connection problem i am sure.
i tried it at home and at the office where i have a very good and fast connection.
Old 02-19-2013, 16:26   #9 (permalink)
mogrem.soft's Avatar
Member: 914426
Sonork: 01017474627
Thanks Meter: 235
Thanks bro will Test and post Result :|
Old 02-21-2013, 00:39   #10 (permalink)
Member: 1231029
Sonork: isri
Thanks Meter: 18
Does this allow me to edit APN?
Old 02-21-2013, 04:02   #11 (permalink)
Member: 1231029
Sonork: isri
Thanks Meter: 18
Tried this method but, getting this message after ( downloading software update 12% )
error message " an error has occurred while downloading software for your device.
Please verify your internet connection or try again later,
if the problem persists."
Internet connection is 100% ok, but still unable to update device software.
Old 10-23-2013, 13:03   #12 (permalink)
Moderator
gsm mithun roy's Avatar
Member: 1537689
Sonork: 100.1669550
Thanks Meter: 2,219
see this.....try 100% solve
http://forum.gsmhosting.com/vbb/f489...0/#post9815423
Old 11-25-2014, 05:32   #13 (permalink)
Member: 622484
Thanks Meter: 5
thanks ok solution.....
Old 03-03-2016, 08:26   #14 (permalink)
Member: 1353488
Sonork: deepu
Thanks Meter: 3
after flashing blackbery z10 STL100-1
it is dead only red light blink and battery is full charged
Old 06-29-2016, 10:20   #15 (permalink)
silicon brj's Avatar
Member: 622060
Thanks Meter: 37
bb z10 dead after flash
hi
my phone was running in 10.3 version i have downgraded it in 10.3.1.634 flashing finished but red blink only after that i have flashed with
Autoload-STL100-1-10.1.0.1845
Autoload-STL100-1-DevAlphaB-10.3.2.159
but same problem , plz any solution
Page generated in 0.30196 seconds with 8 queries
