Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 09-01-2008, 09:29   #1 (permalink)
vlmobiles's Avatar
Member: 560942
Thanks Meter: 74
Smile How to flash PEARL 8100
How To Flash Blackberry Pearl 8100
Where Vfind Flash File
Plz Help Me
Old 09-01-2008, 10:00   #2 (permalink)
Nonoyxp's Avatar
Member: 141973
Sonork: 100.1579084
Thanks Meter: 4,009
just send me the phone..!!i have software for it.
Old 09-01-2008, 10:46   #3 (permalink)
nnaeem11's Avatar
Member: 144640
Sonork: nnaeem11
Thanks Meter: 238
u can do it by ur self very easy as unlock 3310
NAEEM FAROOQUI.
search button is there
Old 09-01-2008, 10:50   #4 (permalink)
nnaeem11's Avatar
Member: 144640
Sonork: nnaeem11
Thanks Meter: 238
Updateservice
Scroll down to Blackberry Firmware and find the 8100.
Instructions for installing on ANY carrier's 8100:
1. Make sure you have the latest version of Desktop Manager installed.
https://www.blackberry.com/Downloads...93E4F3BB068C22
2. Download the above file to the PC then install it to the PC by running the file you downloaded.
3. Locate the vendor.xml file and delete it. It's located in c:\program files\common files\research in motion\apploader
4. Plug in BB and Open Desktop Manager. You should be prompted to upgrade.
The process takes about 45 minutes to an hour depending on how much data you have to backup and restore during the process. Once it's done loading the new OS it will reboot (it may do this twice during the entire process.) You will see a white screen with an hourglass for up to 20 minutes at a time while the DM says "waiting for initialization."
If you end up with a white screen with small icons and the number 507, simply connect to DM again and run application loader again and it should load the OS to the device.
To find previous versions of the OS for this device, click NEW VERSION
Note: Preloaded wallpapers and custom folder icons are not included in this release.
Note: ColorPearl application is NOT compatible with OS 4.5. Please remove any trackball color applications you have installed if you load OS 4.5. Failure to remove ColorPearl will cause the notification LED come on and stay on steady until a battery pull.
how to flash blackbrry 8100 arushar1 BlackBerry (RIM) 13 10-14-2013 14:57
how to flash a52? fuadgsm E-Gold Based Phones 1 03-29-2010 18:48
how to flash e250i adda2004 Samsung Flashers, Software, Firmware. 0 03-29-2010 12:26
requesting unlock code to Blackberry pearl 8100 Mruthunjaya BlackBerry (RIM) 1 09-09-2009 23:53
[DOUBT] How to flash Blackberry 8100? WeBoXGT BlackBerry (RIM) 1 03-15-2008 06:06
Page generated in 0.26702 seconds with 8 queries
