BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
02-16-2013, 17:53 | #1 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Am In Wealth Always!
Member: 576282 Status: Offline Thanks Meter: 145 | How to remove activation required on bb 9930? |
02-16-2013, 19:44 | #2 (permalink) | |
Member: 576282 Status: Offline Thanks Meter: 145 | Quote:
Does it mean that no body have the solution of this? | |
02-16-2013, 21:03 | #6 (permalink) |
Junior Member Join Date: Feb 2013 Location: LAHORE Age: 33
Member: 1884393 Status: Offline Thanks Meter: 0 | how slove this problm help me plzzzzzzzzzzzz Upgrade log: ---------- HWK Update Client v 2.2.0.0 ---------- ---------- HWK upgrade started:2/17/2013 1:01:20 AM ---------- -- Target Id : -- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003. -- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007. -- UFSx S/N : -- Features : 00000001 -- Licence 5 : True -- UFSx Vendor: UFS3 -- HWK ID : A1.04-PRO1-DF0 -- HWK Status : 1, DL: 0 ---------- Locating HWK Upgrade server... HWK Upgrade server found! Preparing connection to server... Connecting to HWKUpgrade server... Server connection successfully established. Authenticating on server... Authentication stage error: Server reported error:No more upgrade logs. Please contact your reseller. |
02-16-2013, 21:37 | #9 (permalink) | |
02-21-2013, 07:59 | #11 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | Simple. Dial ##MSL CODE If it is Verizon you just dial ##000000 If it is another company you need to probably buy a solution. You MAYBE can use some kind of CDMA tool to read it. Or you can contact the original carrier and see if they can get it for you. |
03-14-2018, 11:16 | #14 (permalink) |
Junior Member Join Date: May 2016
Member: 2573174 Status: Offline Thanks Meter: 0 | solution day read msl code with chimera tools and insert the code to the phone by dialing ##msl code and send the menu will show up you will see 000000 and othes number delet 000000 then insert msl code and save the will automatic restart is workin 5n |
