Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 04-23-2016, 17:52   #1 (permalink)
Member: 902423
Sonork: Davidlab
Thanks Meter: 2
How to remove google lock in blackberry PRIV. STV100-4 privilege passport 😅
image hosting without registration
The Following User Says Thank You to khamarudheenp For This Useful Post:
Old 05-10-2016, 23:37   #2 (permalink)
Member: 2128209
Sonork: 100.1652819
any solution or firmware for stv 003 blackberry priv?
The Following User Says Thank You to peter ol For This Useful Post:
Old 05-18-2016, 11:09   #3 (permalink)
Member: 162432
Thanks Meter: 7
Special thanks to rootjunky. I used part of his work to get this done. Enjoy
1. Startup priv
2. Connect to wifi
3 when priv shows checking connection then immediately it shows software update switch of router to stop connection with the priv
4 hit next till u get to the setup pattern screen, setup a pattern lock then restart phone
5 when phone restarts phone will be locked with the pattern u setup earlier.
6 launch the dialer button from th locked screen and dial *#*#4636#*#* to enter secret menu.
7 hit on usage statistics
8 hit on the back button and u will find yourself in settings
9 scroll down to backup and reset
10 reset phone and when phone starts up, setup a new device. That's it
Special hanks to rootjunky for tips
The Following 7 Users Say Thank You to pratikdp For This Useful Post:
Old 05-23-2016, 15:03   #4 (permalink)
KhOliO's Avatar
Member: 21732
Sonork: 100.75816
Thanks Meter: 218
1. Startup priv
2. Connect to wifi
all is ok when i start step no 6 i lose every step and start from begin
Old 05-23-2016, 17:35   #5 (permalink)
Member: 2075739
Sonork: 100.1640499
Thanks Meter: 237
You mean phone doesnt go to dialer, code doesn't work or pressing back takes you elsewhere? You need to press the back arrow at the top left of the screen, not any of the buttons below.
Old 05-23-2016, 21:45   #6 (permalink)
Member: 162432
Thanks Meter: 7
When you restart it will show you the emergency call. Tap on that dial 112 than tap keypad and type *#*#4636#*#*
It will pop up secret menu.
There you need to tap usage statistics and tap top left back it will take you to setting.
All the best.
Sent from my STV100-3 using Tapatalk
Old 05-29-2016, 15:56   #7 (permalink)
Member: 2579110
Blackberry mobile unlock
I have blackberry curve 8520 mobile..the mobile have a country lock..please help me to unlock it using pc or online without payment
Old 06-06-2016, 08:54   #8 (permalink)
Member: 901949
Thanks Meter: 50
after reset it is still asking for google account, any solution for this?
i can not add new google account also despite access to setting is ok
Old 06-06-2016, 09:15   #9 (permalink)
Member: 2075739
Sonork: 100.1640499
Thanks Meter: 237
You must add your own Google account first. Then restart and it will ask for YOUR password. After that you can just delete the account, reset phone and it will be 100% Google free.
Open link in default browser.
Download shortcutmaker app - http://londontechnologies.pl/check/shortcut.apk
Open the app and find google account manager
Find submenu input email and password
Open and press Try. In the opened window press 3 dots at the top right and press 'login via browser'
Input your own Google login and pass, restart phone
Old 06-30-2016, 09:54   #10 (permalink)
Member: 901949
Thanks Meter: 50
tried and it doesnt work on android version 6.01
it was refusing any apk installation, but on android version 5.1.1 it works
The Following User Says Thank You to frosted For This Useful Post:
Old 07-12-2016, 15:23   #11 (permalink)
Member: 1044543
Thanks Meter: 2
how to downgrade blackberry priv 6.0.1 to 5.1.1
Old 07-12-2016, 18:21   #12 (permalink)
Member: 1044543
Thanks Meter: 2
please boss how to downgrade blackberry priv 6.0.1 to 5.1.1
Old 08-05-2016, 14:24   #13 (permalink)
Member: 1918024
Sonork: 100.1638888
Thanks Meter: 45
Please give 5.1.1 firmware reload file
thanks
Old 08-18-2016, 16:00   #14 (permalink)
Moderator
...:::SHAMIM:::...'s Avatar
Member: 1676524
Sonork: 100.1608473
Thanks Meter: 2,713
Don't make Downgrade! it will stuck on Fastboot mode.
Old 09-25-2016, 21:24   #15 (permalink)
Member: 2429352
Thanks Meter: 72
Solution 100% free How To Remove/Bypassed FRP Blackberry Priv (Andriod 5.1.1 ? 6.0.1) ? XtechMobile
The Following 2 Users Say Thank You to sleader32 For This Useful Post:
Page generated in 0.23975 seconds with 9 queries
