How to remove google lock in blackberry PRIV. STV100-4 privilege passport 😅 How to remove google lock in blackberry PRIV. STV100-4 privilege passport 😅 http://s31.postimg.org/3prn35lu3/20160423094054.jpg image hosting without registration |
any solution or firmware for stv 003 blackberry priv? |
Special thanks to rootjunky. I used part of his work to get this done. Enjoy 1. Startup priv 2. Connect to wifi 3 when priv shows checking connection then immediately it shows software update switch of router to stop connection with the priv 4 hit next till u get to the setup pattern screen, setup a pattern lock then restart phone 5 when phone restarts phone will be locked with the pattern u setup earlier. 6 launch the dialer button from th locked screen and dial *#*#4636#*#* to enter secret menu. 7 hit on usage statistics 8 hit on the back button and u will find yourself in settings 9 scroll down to backup and reset 10 reset phone and when phone starts up, setup a new device. That's it Special hanks to rootjunky for tips |
You mean phone doesnt go to dialer, code doesn't work or pressing back takes you elsewhere? You need to press the back arrow at the top left of the screen, not any of the buttons below. |
When you restart it will show you the emergency call. Tap on that dial 112 than tap keypad and type *#*#4636#*#* It will pop up secret menu. There you need to tap usage statistics and tap top left back it will take you to setting. All the best. Sent from my STV100-3 using Tapatalk |
Blackberry mobile unlock I have blackberry curve 8520 mobile..the mobile have a country lock..please help me to unlock it using pc or online without payment |
after reset it is still asking for google account, any solution for this? i can not add new google account also despite access to setting is ok |
Open link in default browser. Download shortcutmaker app - http://londontechnologies.pl/check/shortcut.apk Open the app and find google account manager Find submenu input email and password Open and press Try. In the opened window press 3 dots at the top right and press 'login via browser' Input your own Google login and pass, restart phone |
tried and it doesnt work on android version 6.01 it was refusing any apk installation, but on android version 5.1.1 it works |
how to downgrade blackberry priv 6.0.1 to 5.1.1 |
please boss how to downgrade blackberry priv 6.0.1 to 5.1.1 |
thanks |
