BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
09-17-2012, 13:01 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Rome , Italy
Member: 190882 Status: Offline Sonork: BB PIN: 7C83D9CE Thanks Meter: 1,282 | How repair bb 9800 red light (loop connect/disconnect) if i start loader.exe it dont flash phone (also with /nojvm option) , it fails after 1st step i have nuked it with nckdongle and start "auto loader full os bb 9800_os.6.4.0.105.exe" but after it is still died .... any help? thanks |
09-17-2012, 15:35 | #2 (permalink) | |
Freak Poster Join Date: Jan 2008 Location: indonesia-purwokerto
Member: 674113 Status: Offline Sonork: 100.1622255 Thanks Meter: 56 | Quote:
flex broken.replace flexible.if not succes zokus damage | |
09-17-2012, 20:44 | #3 (permalink) |
No Life Poster Join Date: Jan 2011 Location: Honduras
Member: 1488173 Status: Offline Thanks Meter: 194 | That is flex slider problem or vbat ic hardware issue. Try to replace flex and if not work just replace this ic, follow instructions over here: We can Fix your Blackberry: Blackberry 9800 RED BINK...done Best Regards Mr. Frensis !!! |
The Following User Says Thank You to celumaster. For This Useful Post: |
09-18-2012, 09:48 | #4 (permalink) |
No Life Poster Join Date: Apr 2010 Location: NYC/USA
Member: 1283129 Status: Offline Thanks Meter: 135 | It can be the flex cable or the battery or the board or the magnets in the housing. I think best solution is to take a known working 9800, swap motherboards, verify if it is a problem with mainboard or other things in the housing. If board is good then you can isolate problem. This phone often blinking red light caused by bad flex cable or hardware problem in board. Also can be bad battery. Need to isolate the problem with known components. |
