Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 03-05-2012, 21:54   #1 (permalink)
Darkensser's Avatar
Member: 1709479
Sonork: Darkensser
Thanks Meter: 90
How To Restore A Dead BlackBerry
If your BlackBerry fails to start there could be three things that are wrong with it; it could be totally dead, it could be trying to restart while giving you LED activity only, or it could have failed to restart giving you a white error screen. You may still be able to restore your BlackBerry back to life…
How you do it?
Step one: Make sure that you have BlackBerry Desktop Manager installed. You can either use the CD that came with your device, or download the latest version.
After BlackBerry Desktop Manager is installed you will need to install a specific OS. This will not be on your device CD. You will need to download the original, or any specific version from the download section at the main BlackBerry site.
After you have the new OS installed, you will then prepare it for your device.
Choose Start
Choose Computer, and then the Drive C: Icon
Next open Program Files
Then Common Files
Then Research In Motion
Finally, AppLoader
Scroll down to the bottom and delete the file named Vendor.xml
Your BlackBerry device should now be ready for restoration. Make sure that Desktop Manager is not running, and plug your device into the USB.
Next we will use the command line interface.
If you are using Windows XP then use the command: Start / Run… / Command
If you are using Windows Vista then use the command: Start / Command (type into start search)
A command prompt in a black screen will then appear.
If you are using Windows XP then use:
CD \
CD PROGRA~1
CD COMMON~1
CD RESEAR~1
CD APPLOA~1
LOADER /NOJVM
If you are using Windows Vista then use:
CD \
CD PROGRAM FILES
CD COMMON FILES
CD RESEARCH IN MOTION
CD APPLOADER
LOADER /NOJVM
A forced rebuild will begin once you hit enter after the final command. Once the rebuild is finished, unplug the USB from the computer and wait for the start up. This should take approximately fif**** minutes, and should not be interrupted.
When your Blackberry device is ready, you can use Desktop Manager Application Loader to restore the back up files, if you saved any, and customize it.
The Following User Says Thank You to Darkensser For This Useful Post:
Old 03-13-2012, 12:28   #2 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
Thanks Meter: 171
not solve for 9800 torch ..riconect jvm error
Old 03-13-2012, 13:00   #3 (permalink)
Member: 125065
Thanks Meter: 35
Try to use rapido flasher, if its software problem than 100% problem solved
Old 03-13-2012, 18:16   #4 (permalink)
NEO-TECH's Avatar
Member: 750498
Thanks Meter: 51
i cant solve this on bb9860, always reconect jvm, and there isnt rapido flasher for bb 9860, what can i do?
Old 03-17-2012, 01:20   #5 (permalink)
Darkensser's Avatar
Member: 1709479
Sonork: Darkensser
Thanks Meter: 90
Download a falid OS for your device... check with this: https://swdownloads.blackberry.com/D...B5072C3D49BD0F
Old 03-22-2012, 09:08   #6 (permalink)
Member: 1543212
Thanks Meter: 10
sir where can i download specific OS SIR if u have specific OS PLZ upload this software it is urgent
Old 03-22-2012, 10:26   #7 (permalink)
Member: 1737827
I did restore.
Thank you for your cooperative..........
Old 03-23-2012, 01:30   #8 (permalink)
Darkensser's Avatar
Member: 1709479
Sonork: Darkensser
Thanks Meter: 90
EASY DOWNLOAD OS... HERE!!!
Old 04-05-2012, 15:32   #9 (permalink)
Hafiz ArslanAli's Avatar
Member: 820592
Sonork: 100.1590378
Thanks Meter: 207
hi team
i have a problem with blckberry 8120.
it detect this phone with AppLoader & flash but when software detect JVM then i insert battery but phone not detect with pc. & show error. but i don't understand why phone is not detecting with computer with battery & power. & it detect without battery with software also computer detect unit & install driver.
Plz help
Old 04-05-2012, 22:48   #10 (permalink)
Darkensser's Avatar
Member: 1709479
Sonork: Darkensser
Thanks Meter: 90
Originally Posted by Hafiz ArslanAli View Post
hi team
Plz help
Is a problem of software... I recommend to you that download a "Quick Install" and put you phone to PC without battery... after reload the software, you need insert the battery in your phone again .....
Regards!!
Old 04-15-2012, 23:04   #11 (permalink)
Marscel_Jr's Avatar
Member: 1121495
Thanks Meter: 28
How you do it?
Choose Start
Then Common Files
Finally, AppLoader
CD \
CD PROGRA~1
CD COMMON~1
CD RESEAR~1
CD APPLOA~1
LOADER /NOJVM
CD \
CD PROGRAM FILES
CD COMMON FILES
CD APPLOADER
LOADER /NOJVM
nice share bro.... problem solved 8520
Old 04-15-2012, 23:56   #12 (permalink)
Member: 1067814
Sonork: 100.1618982
Thanks Meter: 75
Hi Darkensser it works on 9930 verizon??
its goin up but reboot constantly, o constantemente, jejejje
Old 04-28-2012, 01:48   #13 (permalink)
Member: 56946
Thanks Meter: 13
How you do it?
Choose Start
Then Common Files
Finally, AppLoader
CD \
CD PROGRA~1
CD COMMON~1
CD RESEAR~1
CD APPLOA~1
LOADER /NOJVM
CD \
CD PROGRAM FILES
CD COMMON FILES
CD APPLOADER
LOADER /NOJVM
cant solve this on bb9800, always "reconecting to jvm" error
Old 04-28-2012, 09:19   #14 (permalink)
Member: 1753191
these steps are applicable on models?
Please could you mention that?
Old 09-15-2012, 08:30   #15 (permalink)
Member: 1354455
Sonork: 100.1637595
Thanks Meter: 54
Curve 9810
got error reconnecting to jvm
how to resolve it
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 05-22-2016 12:42
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 12:57
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 20:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 19:29
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 23:36
Page generated in 0.45935 seconds with 8 queries
