BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
04-03-2014, 12:58 | #6 (permalink) |
Insane Poster Join Date: Jan 2011 Location: Philippines
Member: 1505144 Status: Offline Thanks Meter: 2 | Solved! calculate the MEP CODE using Blackberry ToollBlack Berry Tool - Download - 4shared - louise john cacot you can find your IMEI in the back of your phone(remove battery) same with PRD -Insert a SIM card to your BlackBerry 8520 curve -Make sure all the connections are off(WIFI and Radio signal), Go to "Manage Connections" > "Turn All Connections Off" -Go to "Options" (or "Settings" > "Options") and then select and press the "Advanced Options" -From the "Advanced Options" menu select and press the "SIM Card" selection. -On the SIM Card screen type "MEPD" (you will not see what you are typing). -Then, type"MEP2" ("MEP4" for some networks). hold the "ALT" key for the number while typing it like this: MEP-hold ALT-2. (it will not show on screen) -A screen will show, then type the unlocking code for your BlackBerry 8520 curve and Press "Enter".repeat steps 5-6 if you dont see the unlocking code on screen when you type it. You will see a message: "Code Accepted", in case you get error message try to use other code in the same way. Restart your BlackBerry 8520 curve, turn the connctions back on. ("Manage Connections" > "Restore Connections") - Your BlackBerry 8520 curve is now unlocked! |
