BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
11-18-2011, 22:26 | #1 (permalink) |
Junior Member Join Date: Nov 2011
Member: 1685918 Status: Offline Thanks Meter: 1 | I'm a MML failure I have downloaded the unbranded VSMs from in preperation here: http://forum.gsmhosting.com/vbb/f489...2/index14.html I have read through all the reccomended steps and i had MML working for one execution. I then closed the app and i havnt been able to get it to open since. Here is my setup: Windows XP VM (x86) (Disconnected from the network) Installed .net 2.0, 3.5, 4.0 Installed Blackberry desktop manager Extracted MML to C:\MML and replaced the BBDevMgr.exe with the one found in MML\bin, also downloaded the reccomended configuration Heres what I'm wanting to do: Procedure: 01 - Disconnect your PC from your Internet connection. 02 - Go to the MFI Multiloader instalation folder: C:\MML 03 - Go to folder HHFiles, run the .bat file wich match your device model. 04 - Connect the USB cable to your BB device and power on. 05 - After finish this procedure phone will show on screen "No Application Linked (Factory 05)" 06 - Disconnect device and start MFI Multiloader (MML.exe) 07 - Press the keys CTRL + SHIFT + ALT + F12 (together) so you can see the hidden menu. 08 - Uncheck option "Auto start" if it is checked. 09 - Connect the USB cable to your BB device. 10 - Click on button "Clear MEP" 11 - Click 'Load VSM' and select the new VSM to load When i attempt to open MML nothing happens and in the MMLException.log I see: System.NullReferencEException: Object reference not set to an instance of an object. at MML.frmMain.EnableControlsSafe(Object obj) I have since remade my VM from the ground up following the same steps and cant get it to run. What am I doing wrong? It confuses me even more that it worked (as in it loaded, i never succesfully loaded a VSM or cleared the MEP, kept getting RTAS errors... i'll cross that bridge when i get there, unless anyone wants to tackle that one too) the first try and not again. |
The Following User Says Thank You to hopscotch For This Useful Post: |
11-22-2011, 01:39 | #4 (permalink) |
No Life Poster Join Date: Sep 2008 Location: Space Age: 49
Member: 861795 Status: Offline Thanks Meter: 1,275 | thanks jackass.. we all knew about it... i hate you guys like post fake NEW device hacks, and post old NEWS as NEW... you should all die in hell... |
11-23-2011, 02:19 | #5 (permalink) |
No Life Poster Join Date: Mar 2007 Location: /Fr/Ch\Ro\ Age: 39
Member: 467911 Status: Offline Thanks Meter: 351 | Hy and welcome to gsmhosting forum. First of all you didn't mentioned your phone model and I or others who will to help, simply can't....but Like above ,it's for old models and I'm sure you have unsupported model because of the rtas error. @votran ,mate .He simply ask help, he don't mentioned for a new solution or something else. Stop smoking and (or) drinking ,bad for health . Regards to our neighbors . br, free1600 |
12-09-2011, 15:36 | #6 (permalink) |
Member: 1685918 Status: Offline Thanks Meter: 1 | thanks for responding. Sorry i didn't post the model in the original post, my problem was that I cant even start the software so the device model shouldn't be relevant? The RTAS error is definitely device related but thats a seperate issue. I have access to about 10 different models some old, some new. I am still curious what happened to my MML that made it no longer open and throw exceptions. However to follow up i was able to get it to work again by rebuilding a new VM from the ground up and following the same installation procedure i had done the first time. That VM is still currently working (i basically always suspend the VM with MML open so that I dont have to worry about never being able to re-open it). |
i'm looking for the site about batteries? | ambot | GSM Mobile Links | 1 | 02-06-2002 01:43 |
I'm a newbie - where can I get basic facts about flashing phones ? | The Villan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 01-04-2001 21:45 |
I'm looking for NMP DCT3 Full flasher by saras | Filin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-29-2000 12:30 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
