BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
02-23-2010, 12:20 | #4 (permalink) |
Junior Member Join Date: Dec 2006
Member: 418682 Status: Offline Thanks Meter: 9 | white screen solution brother i have rectifed the problem of white screen in black berry this is due to mainly two reasons 1: software 2:hardware > if the phone have a software problem then the phone could not receive the call as well as make the calls > u can also verify it from the led(light emitting diode) of ur phone if it changes the color from red to green during the booting process its mean that your phone have the hardware fault otherwise the software fault > for software fault u have to just flash the mobile phone Hardware >check the physical appearance of LCD connector if rusty the clean it and also resold it. >check the physical apperance of LCD strip if rusty then clean it gently with CTC(carbon tetrachloride) >after above steps if the fault still remain then check the bunch resistor mounted near the processor of phone. also the tracks from these resistors to LCD connector. >if the bunch resistors and tracks are ok then reball the processor. u will 100% rectify the fault. |
The Following 4 Users Say Thank You to muddassar1980 For This Useful Post: |
06-09-2011, 00:11 | #7 (permalink) |
Freak Poster Join Date: Mar 2009 Location: uk
Member: 996052 Status: Offline Thanks Meter: 35 | Bb 8520 head phone sign problem If you are having problem with bb 8520 head phone sign Problem ok this is bit tricky first of all I want you to check head phone socket if thats fine then change the ringer and earpiece this will solve your problem or if you have complete chesy with parts inside change with that that will work 100% I fix more then 7 phone Last edited by i am the master; 06-09-2011 at 00:19. |
06-09-2011, 00:17 | #8 (permalink) | |
Member: 996052 Status: Offline Thanks Meter: 35 | Head phon sign Quote:
is that the problem you having simply change the ringer or complete chesy with parts good luck don't forget thanks ok | |
02-01-2012, 09:48 | #10 (permalink) |
Member: 418682 Status: Offline Thanks Meter: 9 | 8520 display solution as u describe about your phone the rotating clock, its mean u have the software issue. Follow these steps. 1) download JL_cmdr . 2) Download BB desktop Manager. 3) download the software for ur blackberry 8520. first of all run the blackberry desktop manager then connect your blackberry so that your system automatically load the drivers for ur blackberry. then close the bb desktop software. now run the JL-cmdr and select the wipe option from the list. now ur phone will shows the error 507. now close the jl- cmdr and open the blackberry desktop manager. and connect ur device and pull out the battery then click on app loader the phone will connect and automaticaly select its appropiate software after the loading process start insert the battery. when the phone completely updated disconnect ur phone now ur phone is ready with the new software. |
10-31-2012, 13:14 | #13 (permalink) |
Member: 996052 Status: Offline Thanks Meter: 35 | blackberry 8520 sound problem When you make call you can hear disturbance noise ? if is that the problem you having simply change the headphone jack. that will solve your problem. this solution is tested on many hand sets works every time. 100%tsted good luck |
11-26-2012, 16:45 | #14 (permalink) |
Junior Member Join Date: Nov 2012
Member: 1844744 Status: Offline Thanks Meter: 0 | hola soy nuevo en esto tengo una blackberry curve 8520 es para un regalo a mi hijo y quiero flexearla me pueden ayudar este es el imei 357559.04.844659.9 id de proveedor 121 pin 27443326 version de app 4.6.1.272 (--- |
01-05-2013, 18:06 | #15 (permalink) |
Junior Member Join Date: Jan 2013
Member: 1863638 Status: Offline Thanks Meter: 0 | my blackberry phone showing wite screen my blackberry phone 8520 showing white screen the problem is it is going fine when it is charging but when i remove it it wil work for approx 15 min and den when i hve to start again i hve to charge it again den only it will start help plss help |
5130 white screen when play video | fakhraei2000 | Nokia Hardware & Hardware Repair | 13 | 11-15-2010 04:54 |
BlackBerry 8520 unlock help needed | derk | FuriousGold | 3 | 04-08-2010 11:37 |
Refurbished BlackBerry 8520 Phone (unlocked) - White | IPMART | ipmart WebShop | 0 | 12-16-2009 14:30 |
Blackberry 8100 white screen | jcalvette | BlackBerry (RIM) | 6 | 04-27-2009 13:08 |
blackberry 8100 white screen | dust4dust | FuriousGold | 1 | 02-08-2009 15:53 |
