BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
09-22-2008, 07:29 | #1 (permalink) |
Freak Poster Join Date: May 2008
Member: 777756 Status: Offline Thanks Meter: 44 | call failed blackberry 8700 |
09-22-2008, 07:34 | #2 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Quote:
Its not about firmware upgrade, its about change policy. You have to change its call policy, upload a black policy. which comes as a binary file. P.S. Dont upgrade firmware again and again. | |
09-22-2008, 08:08 | #3 (permalink) |
Member: 777756 Status: Offline Thanks Meter: 44 | i onlly updated once i dont understand wts black policy can u explainl from where to get and how to upload i will be thankful i read something it policy i tried that also to remove from handset bot it remaims same |
09-22-2008, 08:32 | #4 (permalink) |
No Life Poster Join Date: May 2005 Location: MIND MAKING COMPANY Age: 44
Member: 144640 Status: Offline Sonork: nnaeem11 Thanks Meter: 238 | This is the latest operating system for 8700 4.5.0.92/4.50.69(Multilanguage)4.5.0.92/4.50.69 If you have any 8xxx device the best method for removing IT policy is to update it to OS 4.5 and you can use JL_Cmder's "resettofactory" command to remove ALL IT policy, Firewall restrictions and Application Permission settings. After you've upgraded to OS 4.5, simply backup the device using Desktop Manager, close Desktop Manager, then run JL_Cmder and execute the "resettofactory" command. The device will wipe, then reboot leaving the OS, 3rd party apps but no data AND, best of all, NO IT policy whatsoever. When you're done, simply restore your backup and you're good to go with no policy or locked firewall. You can downgrade back to the old OS if you desire, too. ------------------------------------------------------------------------- usage: To install JL_Cmder just extract the files and run Install.cmd. Or, download the single file installer package. Note: The screenshot command will only work if your BlackBerry is running OS 4.0.2 or higher. If anyone has any suggestions you can leave a note in this message. software attached to restore the Black Berry 8xxx. |
The Following User Says Thank You to nnaeem11 For This Useful Post: |
09-22-2008, 15:41 | #5 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Hong Kong | USA Age: 35
Member: 258172 Status: Offline Thanks Meter: 10,367 | Quote:
09-25-2008, 15:14 | #9 (permalink) |
Member: 777756 Status: Offline Thanks Meter: 44 | hi dear i updated it 4.5 then i used jl-cmdr and reset fectory setting as u said but problem is remaining call failed it is showing network bars with gsm any help thans in adv |
09-25-2008, 15:29 | #10 (permalink) | |||
09-25-2008, 17:27 | #11 (permalink) | |
anyway take a look here http:///vbb/showthread.php?t=601298 | |
09-26-2008, 07:50 | #12 (permalink) |
Member: 777756 Status: Offline Thanks Meter: 44 | hi, i tried every thing , i read step 19 to see there is it policy in it or not but i dont think there is any it policy in it. i run jlcmd wiped handset reset and all things but it is on callfailed .it could be hardware problem because after some times it says sos only .any comments on it i will apricate . thanks to all of u for ur support and sharing knowledge |
09-26-2008, 09:19 | #13 (permalink) |
Member: 258172 Status: Offline Thanks Meter: 10,367 | @bombayteji some time its heppen for low battery , make sure your battery have full charge then try turning off the radio and back on , if not solve chack phone hardware |
The Following User Says Thank You to ::.::RAMJAN::.:: For This Useful Post: |
07-17-2012, 08:34 | #14 (permalink) |
Junior Member Join Date: Jan 2012
Member: 1713330 Status: Offline Thanks Meter: 2 | @nnaeem11 ... hello there i have (2) BB-8520 and (1) BB-9700 having same kind of problem about sos call failed ... i upgraded all of them by the latest operating system & did the reset factory from JL_Cmder also , but still the problem is same ... initially signals appear but when i try to make any call it say's "call failed" & then mobile goes to sos & signals vanishes i tried as u instructed ... but the problem is still the same with all of them ... what do u think ? |
07-17-2012, 08:39 | #15 (permalink) | |
Member: 1713330 Status: Offline Thanks Meter: 2 | Quote:
hello there i have (2) BB-8520 and (1) BB-9700 having same kind of problem about sos call failed ... i upgraded all of them by the latest operating system & did the reset factory from JL_Cmder also , but still the problem is same ... initially signals appear but when i try to make any call it say's "call failed" & then mobile goes to sos & signals vanishes i tried as u instructed ... but the problem is still the same with all of them ... what do u think ? | |
Call failed - blackberry 8310 curve | guzo | BlackBerry (RIM) | 2 | 02-02-2013 17:04 |
BlackBerry 8700 - Call Failed error. | mostwantedkiss | BlackBerry (RIM) | 5 | 07-14-2011 10:22 |
BlackBerry 8700 - Call Failed error.. help needed | mostwantedkiss | BlackBerry (RIM) | 4 | 06-12-2009 12:59 |
BlackBerry 8700 Call Barring Password? | dmitrik | FuriousGold | 5 | 01-20-2009 12:51 |
hi blackberry 8100 tower showing but call fail | unlock_solution | BlackBerry (RIM) | 1 | 11-30-2008 09:49 |
