Need help for MFI multiloader Hi, I have a problem. When I run MFI multiloader, it always show me a error, said " Update failed: Could not find a part of the path'T:\RMA\MML\Update.xml source:mscorlib And my computer has installed .net framework 3 and 2.0 service pack 1, I can not install .net framework 2.0. I want to know if I need uninstall .net framework 3 and 2.0 service pack 1, then install .net framework 2.0. Thanks |
open configuration.xml file in Notepad from Configuration folder and find the line "T:\RMA\MML\Update.xml" and change it to "C:\MML\Update\Update.xml" and your problem will be solved no more this error. Take Care ENJOY |
Now there's another error q q I get what I put on the forum. vhgsm |
help blackberry software Now there's another error q q I get what I put on the forum. vhgsm --------------------------- Updater --------------------------- Update failed: Could not find a part of the path 'C:\MML\Update\Update.xml\update.xml'. Source: mscorlib --------------------------- Aceptar --------------------------- |
Your Path is: C:\MML\Update\update.xml\update.xml Take Care ENJOY |
close all network................. and internet also..... solve this problem.......... BR. Shohag |
but how can i change "T:\RMA\MML\Update.xml" and change it to "C:\MML\Update\Update.xml" |
Open your configuration file in notepad. whereever you see T:\RMA\MML\Update.xml change it to C:\MML\Update\Update.xml if it still wont work, open your update.xml file in note pad to. and make the same changes. |
Just use the first reply method but only leave "C:\MML\Update" and not include "Update.xml" and it's ready to use with the error fixed. BR |
