BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
05-10-2013, 20:50 | #1 (permalink) |
Major Poster Join Date: May 2010 Location: indonesia Age: 40
Member: 1300946 Status: Offline Thanks Meter: 39 | NUBLINK FX PREMIUM 2013(by timothy gunawan) Improved with the new component CFP V 4.2.0.13 When the bbsak, vnbbutils, bmcp, BB boss, p*tool, s***pro, Z**key, Mr.**l, Jlcommander cannot handle your job!! BlackBerry solution for blinking red light 100% working With "NUBLINK FX PREMIUM" Blinking red light solution for all BlackBerry Symtom: When you receive a new message, your BlackBerry flashes a red light as an alert. If the light does not stop after retrieving the message, it could be the result of several factors including the need to charge your phone or an issue with the device. New and tried on 100s off bb modules success on all • How to do? 1. download NUBLINK FX PREMIUM 2. Open the folder autorun & Double click autorun icon to start the program. • Description of the feature: - Wipe installer partition specifies that only the installer partition should be removed. - Wipe file system specifies that only the filesystem should be wiped. - Wipe file system & OS the filesystem and OS regions of flash to be irreversibly erased - Extreme wipe this will erase all the data & make your bb go zero - Nuke erases all of the user's data off the device including the filesystem and the password. This command is useful if a password is lost and one would like to make the device usable again at the expense of lost data. - Factory Reset This will reset IT policy to factory settings (Wipes all user data) - BB Info This will display information about system,OS,App,address of your BB device in hexadecimal format -Flash Info displaying info about your ICflash -Load SFI, NAL, Full OS this will load SFI, NAL, Full OS in to your device. Note: for this action you must put this file (SFI, NAL, Full OS) in the directory folder X and renamed each file with: 1. rim*****.sfi > os.sfi 2. nal file > nal.exe 3. rapido / PRD > os_installer.exe *for SFI file you can find in the directory for SFI file you can find in the directory C:\Program Files\Common Files\Research In Motion\Shared\Loader Files\***your OS***\UMTS\rim*****.sfi - One click auto complete this will take some time, as we will now first WIPE your device 2 times, next NUKE it, then load NAL file, continue with load SFI, , and finally load full OS into your device in one click Note: for this action you must put this file (SFI, NAL, Full OS) in the directory folder X and renamed each file with: 1. rim*****.sfi > os.sfi 2. nal file > nal.exe 3. rapido / PRD > os_installer.exe *for SFI file you can find in the directory for SFI file you can find in the directory C:\Program Files\Common Files\Research In Motion\Shared\Loader Files\***your OS***\UMTS\rim*****.sfi -Vendel One click delete VENDOR.XML -IP Reseter & Renewer some hosting site not allowed you to download file 2 times or over, that's because the server has detect your IP already use for downloading and blocked your ip, now you can use this utilities to reset and renewing your ip and back to download with the same site without detected by the server *and some additional tools that are already familiar to you that you do not describe Advanced user only ! ~Don't connect your normal BB to pc if the step 2-4 is open, this command will erase all your normal BB data inside!!! Preview ( click to large ) NBFX.jpg Download to your pc:Nublink Fx Premium - Download - 4shared |
The Following 17 Users Say Thank You to aprissandi For This Useful Post: |
05-13-2013, 16:13 | #5 (permalink) |
Member: 1300946 Status: Offline Thanks Meter: 39 | NB : SFI load button on NUBLINK FX PREMIUM can be used for MFIs because the base load SFI and MFI sciptnya same command ... by changing the name of MFIs into OS.SFI .. might as well just not one click by : timothy gunawan |
The Following User Says Thank You to aprissandi For This Useful Post: |
06-06-2013, 06:49 | #12 (permalink) |
Freak Poster Join Date: Dec 2009
Member: 1189245 Status: Offline Sonork: [email protected] Thanks Meter: 13 | 9900 mobile network did not ON any solution to it, another one 9900 hanging before i flash it now load finish but i can not accept term and condition help me please |
02-08-2014, 06:40 | #14 (permalink) | |
Insane Poster Join Date: Mar 2007 Location: SURABAYA
Member: 467371 Status: Offline Thanks Meter: 12 | Quote:
I think...this tool cant fix EFS ..just repair..stuck load..etc all redblink etc maybe yes >>>but for fix or disable efs fix not suport ...btway i hope next update all EFS problem suport with this tooll...IHOPE 'n nomore expensive price | |
02-09-2014, 08:18 | #15 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 57
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
anyone can edit change version/name of cfp.exe so which one or who's one is latest??????????????? pls.... compare command in two windows as I had check. | |
