BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
11-16-2012, 12:36 | #1 (permalink) |
Registered User Join Date: Jul 2012
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | Please, How to detect BlackBerry Types ? Load Flash Image Failed (rim0x0D001404.sfi)! This OS does not match this device! i see on label BlackBerry 9520 but cant detect all installed firmware (based 9520) now the condition is red blinking // 11 (desimal = 3) There is no OS installed, reload OS with MFI. This is 9520 or other type? reloading using rapido, it closed for seconds. here information that i can give to you Code: Microsoft Windows XP [Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp. G:\CFP>cfp -u info Connecting to Bootrom: Connected [ Uploading RAM Image 0x1001F77C ] [############## 100 ##############] Device Info: PIN: 31758e93 Bootrom Version: 5.6.0.37 Hardware ID: 0x0D001404 RIM BlackBerry Device HW ID Override: 0x0E001404 Metrics Version: 6.12 Build Date: Sep 30 2009 Build Time: 13:26:48 Build User: absadmin Security: Enabled Supported Options: 0x00000005 Drivers: 0x00000004 Processor: 0x00040002 LDR Blocks: 0x0C00B030 Bootrom Size: 0x00020000 External MCT/HWV: Enabled Boot Mode: N/A Boot OS Count: N/A HWV: Board Revision 0001 - 0x0B CPU Version 0002 - 0x93 SW Compatibility 0003 - 0x02 POP Revision 0004 - 0x0E Power Mgt Hardware 0007 - 0x30 POP Security 000B - 0x01 Mem Config Table (ver 1.16): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1919 Modem EFS: blocks 1920-1983, total = 64 OS NV: blocks 1984-2000, total 17 CRC: 0x75AD64FD Mem Config Table (ver 1.16) (actual): Flash Chip: blocks 0-2000, Chip 0, Sub 0 Bootrom: blocks 0-0 OS Dynamic: blocks 2-???? FS Dynamic: blocks ????-1919 Modem EFS: blocks 1920-1983, total = 64 OS NV: blocks 1984-2000, total 17 HWV Entry: 0018 - 0002 CRC: 0x9D4DE325 Flash: Number of chips: 1 Flash ID: NAND blocks 0-2020 Device ID: 68 Vendor ID: 236 Version ID: 33 Total Size: 252.6 MB Memory Map: NAND Blocks: 2021 * 128 Kb RAM Base: 0x10000000 IRAM Base: 0x0C000000 OS Range: 2 - 1919 Branding: VendorID: 282 OS * Not present * Done. |
11-16-2012, 13:10 | #2 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | when reload with rim0x0D001404.sfi -->> No Application Linked Code: C:\Program Files\Common Files\Research In Motion\Shared\Loader Files\9520M_v5.0.0.973_P4.2.0.423\CDMA\rim0x0D001404.sfi Code: ESN : 0 PIN : 31xxxxxxxxxx BSN : 103xxxxxxxxxx Main Processor : 0D001404_P0 Device Type : 218108932 OS Version : Platform Version : 4.3.0.66 GSM Radio Version : 4.0.8.7 OS Type : Factory OS Platform ID : 0x0D001404 Network : CDMA |
11-17-2012, 10:35 | #4 (permalink) |
Junior Member Join Date: Dec 2005
Member: 210379 Status: Offline Thanks Meter: 2 | 9520, but 9550 seems to be the devices need you to take it Download Link Write the first 10 digits of the IMEI number you want to download verizon number BlackBerry® Software Updates |
The Following User Says Thank You to osmanyalcin1984 For This Useful Post: |
11-17-2012, 10:37 | #5 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | @osmanyalcin1984 my program only recognize 9520 with rim0x0D001404.sfi inside. i have install 9550 at C:\Program Files\Common Files\Research In Motion\Shared\Loader Files. __________________________________________________ _________________ 9520_omanodrmjAllLang_PBr5.0.0_rel1611_PL4.2.0.423 _A5.0.0.973_Taiwan_Mobile.exe Still error Code: at BBCFPCOMLib.CFPGRSCOMClass.ReloadPlantImage(String bstrFileName) at GSPBB.GSPBBMain.CFPFlash() at System.Threading.ThreadHelper.ThreadStart_Context(Object state) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean ignoreSyncCtx) at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state) at System.Threading.ThreadHelper.ThreadStart() Load Flash Image Failed (rim0x0D001404.sfi)! This OS does not match this device! Code: ESN : 0 PIN : 31xxxxxx BSN : 1035338753 Main Processor : 0D001404_P0 Device Type : 218108932 OS Version : FFFFFFFF Platform Version : 4.3.0.66 GSM Radio Version : 4.0.8.7 OS Type : Factory OS Platform ID : 0x0D001404 Network : CDMA Software Part List : BIN-29421-001 HWV-24568-006-1C SVP-26236-001_1 SVP-26237-001_1 SVP-30201-001_A ASY-24765-001 MEP-04103-001 VSM-26027-001 CFG-14679-008 NVC-26584-001 SFI-29518-022 APP-29993-018 PRD-20973-093 SWM-28433-001 Last edited by viewprofile; 11-17-2012 at 10:43. |
11-19-2012, 05:07 | #8 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | now im still update this phone using online update (desktop manager) after write 9520_0x0D001404_MFI-29032-013 using cfp as your instruction. hope this will be fix the problem... thanks |
11-19-2012, 05:30 | #9 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | i dunno this solution fix the problem or this is the right ways because i didn't test update with DM before. i just update using DM after write 9520_0x0D001404_MFI-29032-013. thanks to you Apploader and other tool cant update. this package already installed. DM do some fews update on core, maybe C:\Program Files\Common Files\Research In Motion\Shared\Loader Files\9520AllLang_v5.0.0.973_P4.2.0.423 |
11-19-2012, 06:01 | #10 (permalink) |
Freak Poster Join Date: Aug 2010
Member: 1360950 Status: Offline Thanks Meter: 78 | - Uninstall 9520 device software and Desktop Manager. - Delete Research in motion folder from "C:\Program Files\Common Files" and "C:\Documents and Settings\All Users\Application Data". - Reinstall Desktop Manager and 9520 device software. - Delete vendor.xml from "C:\Program Files\Common Files\Research In Motion\AppLoader" - RUN Loader.exe from "C:\Program Files\Common Files\Research In Motion\AppLoader" Summary: Issue will be solved by deleting "Research in motion" folder. |
The Following User Says Thank You to D4Denzil For This Useful Post: |
11-19-2012, 06:22 | #11 (permalink) |
Member: 1784151 Status: Offline Sonork: 0 Thanks Meter: 75 | @ D4Denzil i dunno if this caused by folder and files and just for your info, im install DM5 nd DM6 because some older phone not detected by DM6. btw, problem already solved by follow zelon. thanks for other suggestion, maybe i need it in future days thanks |
The Following User Says Thank You to viewprofile For This Useful Post: |
11-19-2012, 06:34 | #12 (permalink) | |
Junior Member Join Date: Nov 2005 Location: 78_RUS
Member: 196377 Status: Offline Sonork: BB PIN 313E7Cxx Thanks Meter: 10 | Quote:
but not in this case | |
