BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
10-17-2014, 00:03 | #76 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2045747 Status: Offline Thanks Meter: 0 | (req) 9800 No red light,No light and No lcd light My 9800 all work fine, and check with DM all fine too like backup,read app,and ect like normal...But the problem is : 1. First Boot ----> No Red Light. 2. No led light at all like keypad and lcd too. i try to another flexible still not working, can you help me PLEEAASEE Thanks Before....!! |
10-23-2014, 14:24 | #77 (permalink) |
Freak Poster Join Date: Jan 2010
Member: 1203369 Status: Offline Thanks Meter: 14 | Hello I have a bold 9900 that fails to boot properly I explain I did an update to version 7.1 later after loading the bar to 3/4 it is stuck. I made several attempts but each time it's the same scenario happens. I tried also with the same 7.0 version, I'm still stuck with a loading bar that locks in three quarters. photo by supporting what option available me? thank you in advance. |
10-24-2014, 05:36 | #78 (permalink) |
Freak Poster Join Date: Nov 2008 Location: toronto, canada
Member: 900685 Status: Offline Thanks Meter: 7 | hi, I have bb Q5 can not power on. when I put it on charging or connect with pc it show me yellow light then red and then try to start up then show a circle line start to run when it reach in middle then bb Q5 restart then show battery charging sign then start the same proses. if I try to load the software with LINK it starts reloading but the show this error message.. (An error has occurred while downloading the BlackBerry® Desktop Software. Please try again.). I have tried loader software too it finish its proses but bb Q5 cant start.. please help me....thanks |
10-24-2014, 05:43 | #79 (permalink) | |
Member: 900685 Status: Offline Thanks Meter: 7 | Quote:
10-24-2014, 06:53 | #80 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: INDIA Age: 56
Member: 25662 Status: Offline Thanks Meter: 190 | Quote:
Does its water damage? Does it heating too while loading?Which portion is too hot.except CPU.repair that portion.Remove doubtful ic like wifi ic,PA,Audio ic one by one. | |
10-24-2014, 08:47 | #81 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2279303 Status: Offline Thanks Meter: 0 | Hi, i have blackberry storm 2 9550. When connected to the laptop it connects and disconnects frequently. Secondly as it turns on a white screen appears and a message shows Device Error: 367 and at bottom it reads Reset. Very important i have installed the Cd i received with the phone on my laptop but it shows Before you begin, verify that your current blackberry device is connected to the computer. Drivers are not recognized and found. When i go to start > Devices and Printers, blackberry device appears when the red light is on and the screen is blank (black) and as the white screen appears the device indication for blackberry disappear. Is there a possibility for this phone to be repaired.... Please help Chris |
10-24-2014, 11:56 | #82 (permalink) |
Member: 900685 Status: Offline Thanks Meter: 7 | thanks for reply. If I hold the BB in my hand while I put it on charging its not heating. later I will disassemble and put on charge then ill check and post the results.. please explain what is HH |
10-24-2014, 12:17 | #83 (permalink) |
Registered User Join Date: Oct 2006 Location: Casanay
Member: 362751 Status: Offline Thanks Meter: 5 | Q10 restarting Friend have a Q10 which failure is constantly restarting, sometimes lasting a couple of minutes to restart and at other occasions to start the ignition, I have placed several software and nothing to correct the problem, hopefully help to solve this fault thanks |
10-24-2014, 19:45 | #84 (permalink) |
Member: 900685 Status: Offline Thanks Meter: 7 | hi< I have check that BB Q5 is not water damaged and nor its getting hot from any where> so what I should do. what is HH let me know ill check that too. |
10-25-2014, 06:12 | #85 (permalink) | |
2.also touch screen problem very rare. | |
10-25-2014, 06:28 | #87 (permalink) | |
1.you said "show a circle line start to run when it reach in middle then bb Q5 restart then show battery charging sign " means during half round your battery get down.so try with new battery.or full charge in another Q5. 2.When it restart how much time it take to reach upto 50%? If take more than 3/4 minutes than software is not complete.For that use autoloader according to Q5 SQR100-1,SQR100-2,SQR100-3. | |
10-25-2014, 06:37 | #88 (permalink) | |
Does it heating too while loading?Which portion is too hot.except CPU.repair that portion.Remove doubtful ic like wifi ic,PA,Audio ic one by one. I had give same reply above bcoz power managment is accurate and secure. 1.battery connector. 2.try another battery. 3.try to pwer on with charger. 4.how much time it take to complete round 100%? | |
