Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 12-07-2008, 17:46   #1 (permalink)
Member: 296765
Problem with mfi multiloader
Hi friend I have a problem with this soft I tried to work a BB pearl 8100 but the soft said this error please help me
Old 12-07-2008, 23:39   #2 (permalink)
Member: 919193
You need to dl and install the MML-Setup.msi, which is not included in the 8files.
Old 12-07-2008, 23:45   #3 (permalink)
Member: 296765
thank man and posible solution what is? or where can i copy this dll
Old 12-08-2008, 03:40   #4 (permalink)
Member: 916320
The MFI file was not found on the local drive. cannot download from server without an active network connection
can someone please help!
Old 12-08-2008, 13:11   #5 (permalink)
Member: 919193
MML Setup is available here http://www.mediafire.com/?y2vmtmjhjmj
Please Note that this version don't enable latest storm 95xx versions to be unlocked.
Kezzinchh => You must dl the 8files and extract them in the same directory as the installer. (default C:\MML)
Search for your mfi file in this directory.
What BB do you want to unlock ?
The Following 2 Users Say Thank You to corwin76 For This Useful Post:
Old 12-08-2008, 15:06   #6 (permalink)
Member: 91579
Sonork: 100.1585710
help me
i want unlock 8220 but give me error
thanks
Old 12-08-2008, 16:50   #7 (permalink)
Member: 296765
I Want Unlock BB pearl 8100 friend Not problem with this mll
thank for the response
Old 12-08-2008, 18:21   #8 (permalink)
Member: 296765
Problem Ready thank to comwin76
Old 12-09-2008, 20:22   #9 (permalink)
Member: 695229
anyone get the oracle client sw ver. 8.1.7 or higher required message?
Old 12-10-2008, 05:51   #10 (permalink)
Member: 818209
i have this error with BB 8700 Tmobile you can help me Vandal337?
Old 12-10-2008, 05:52   #11 (permalink)
Member: 818209
this my error message: "The MFI file was not found on the local drive. cannot download from server without an active network connection"
Old 12-10-2008, 06:53   #12 (permalink)
Member: 919193
Guys, please read the faq's and the other posts before posting ^^
Vandal337, you must disable your network connection so as to avoid this message.
Old 12-10-2008, 07:17   #13 (permalink)
Member: 695229
sorry could you direct me to the proper link?
Old 12-12-2008, 14:58   #14 (permalink)
Member: 202611
@corwin76
hello i try to use ur solution but still i get the same error what can i do to solve this its bb8800
Old 12-13-2008, 10:33   #15 (permalink)
Member: 202611
the mfi was not found on the local drive . cannot downloud from server without an active network connection any one with solution to this pls
Blackberry problems with MFI MultiLoader aej2k BlackBerry (RIM) 135 03-18-2011 19:30
Problem connecting 8310 with MFI Multiloader supermatrix BlackBerry (RIM) 6 10-19-2009 19:46
Problem with MFI Multiloader to unlock Blackberry 9500 - HELP PLEASE! LuxLondon BlackBerry (RIM) 5 02-08-2009 12:07
connect blackberry 8100 with mfi multiloader and showing erer harkishan singh BlackBerry (RIM) 7 12-10-2008 04:46
Page generated in 0.82961 seconds with 11 queries
