BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
05-21-2014, 06:36 | #241 (permalink) | |
Junior Member Join Date: Apr 2013
Member: 1917163 Status: Offline Thanks Meter: 3 | Quote:
Correction: I was able to restore Mobile Network by flashing IMEI. However now there is reception/lost signal/dropped call issues. Also, the red light IS blinking very "dimly/lightly" on every outgoing call, until the call gets connected. Most calls are dropped, disconnected or rejected with fluctuating, weak signal bars. Could anyone help resolve this problem? I may attempt to flash stock firmware in the hopes of resolving this issue. What makes things difficult is not knowing exactly how to restore a blackberry device back to a functional and working order. The few tools available seem very limited in terms of trouble shooting capability, if something was to go wrong. | |
05-30-2014, 14:21 | #242 (permalink) |
Junior Member Join Date: Mar 2014
Member: 2139408 Status: Offline Thanks Meter: 0 | Amigos me podrian asesorar hice todos los pasos y perfecto logre solucionar el problema pero pasa algo que el tlf presenta problemas con la seņal quisiera saber si este proceso afecto la liberacion del equipo 9860? gracias |
06-02-2014, 04:43 | #246 (permalink) | |
I tried this type of version and the program isn't allowing me to connect my device. A message comes up saying either "failed RTAS auth" or "PIN detected, please enter password" I can't connect my phone because RLT isn't recognizing it, this happens even when the phone is in FOS mode. How do I disable the RTAS or get the radio lab tool to link to my device? | |
06-12-2014, 02:50 | #251 (permalink) |
No Life Poster Join Date: Jul 2004
Member: 74258 Status: Offline Thanks Meter: 36 | please help, after i erased 9930/9900 successfully with EFS QUALCOM SOLUTION , it will now ask to load sfi and app same partlist in device. so what next will I do? . because if I use auto loader it will only show white light om the middle button and go off. solution needed please. |
06-26-2014, 11:35 | #252 (permalink) |
Freak Poster Join Date: Oct 2007
Member: 619957 Status: Offline Thanks Meter: 50 | no need this tool for blackberry 9860,9810,9800 etc mobiles for repair red blink or stuck on bb progress bar or after progress bar white lcd i have tested solution if any one need contact me |
07-19-2014, 16:17 | #253 (permalink) |
No Life Poster Join Date: Oct 2004 Location: jamaica Age: 43
Member: 87998 Status: Offline Thanks Meter: 11 | EFS Qualcom Solution i need some help.. i used this program on my 9810 and it changed my imei.. i enter the correct imei and still have the same wrong imei..how do i correct this problem |
