BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
03-02-2015, 14:52 | #3 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
This is not normal. Usually it is because of either an application that uses all the memory or an application that corrupts the OS. I suggest you open the application manager and see which one uses too much memory. If your device is second hand, then now you need to proceed with the steps of the seller as well as the steps of the buyer in this article from the public knowledge base: Article ID: KB05099 Steps to take before selling or after buying a previously owned BlackBerry smartphone The device actually does check the security software and makes sure the OS is legit, etc. when that test takes place. It does it at startup, but if you go to Options>Security>Security Status Information and press the menu key, you can actually do the test any time you want. And no, I have never to my knowledge failed it. | |
