Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 06-13-2012, 23:19   #1 (permalink)
Temporary banned !!
Member: 1540810
Sonork: 100.1627394
solution to blackberry 9000 reload software error 507
I try to flash this blackberry but when loading application the final stage the blackberry we restart and complain application loader could not connect to your device
Old 06-13-2012, 23:23   #2 (permalink)
Temporary banned !!
Member: 1540810
Sonork: 100.1627394
I try to change usb cable battery defferent firware but almost thesame when loadind module 'net_rim_framework_api.cod then giving error solution for this pls
Old 06-14-2012, 07:26   #3 (permalink)
Temporary banned !!
Member: 1540810
Sonork: 100.1627394
Pls am waiting for your useful help
Old 06-14-2012, 14:24   #4 (permalink)
Member: 1715073
Wink
Try with a fast installer because your phone is loosing connection when it turns on
Old 06-14-2012, 14:31   #5 (permalink)
gsm_freak's Avatar
Member: 205990
if fast installer will not help.. try reballing the power managament I.C. and flash again via apploader... mostly this issue relates with the power supply disconnection during flashing process... hope it helps..
Old 06-14-2012, 15:02   #6 (permalink)
ARIF GIGANI's Avatar
Member: 890965
Sonork: 100.1605360
flash via apploader..and battery is fully charz
Old 06-16-2012, 07:12   #7 (permalink)
Member: 678070
put off your battery about 1 hour
wipe divice usiing jl.comander twice or more.
put off again your battery 1hour. it's wasted time but done for me
install correct firmware (aka at&t firmware or else , it's mean same firmware inside phone)
uninstall all blackberry firmware on your PC
at least , install higher version OS of blacberry 9000
run app loader, not else
it's work for me as is as like your problem
br: sapari_rockr
Old 06-16-2012, 08:28   #8 (permalink)
Member: 26420
use this fast loader.
here is some InstaladorRapido files
Old 06-16-2012, 09:38   #9 (permalink)
R.Nasir.Ali's Avatar
Member: 1141761
Sonork: 100.1618159
blackberry solution for blinking red light 100% working
blinking red light solution for all blackberry
1. download blackberry master control program and install it
2. download CFP_3.9.0.175.exe keep on desktop
3. open master control program and click on setting wheel on right hand side and
in enable protected control type BrickBerry same as it is here
4. right click on alien face cfp button at right hand side.
5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop.
6. connect your bb without battery on top command-line interface (CLI)
select wipe tick mark the empty box next to and press excute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job.
let the bb master control be open..........
now the trick is to load os
1. In bb master control on right hand side below right click on apploader
it will loader/nojvm connect your phone follow the instruction thats it you have done the job..
please write me if you have any doubt or error
thanks
nasir
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 73 05-15-2013 13:07
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 12-10-2012 04:46
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Page generated in 0.29371 seconds with 11 queries
