BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
08-26-2009, 21:26 | #1 (permalink) |
No Life Poster Join Date: Feb 2006
Member: 235703 Status: Offline Thanks Meter: 39 | strange problem on bb bold 9000 |
08-26-2009, 23:12 | #2 (permalink) |
No Life Poster Join Date: Dec 2002 Location: TURKEY Age: 44
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | first java coomander and wipe u device ollow these steps: 1. Download JL_Cmder 2. Connect your phone to your PC using the USB cable that came with it. 3. Run JL_Cmder and select option 2 (event log) 4. Scroll to the bottom of the log and look for "JVM Error 102." The line before it should tell you exactly what file is causing the error. It might look something like this. Save the file name; you will need it later. 5. Go to Start > Run, and type "cmd" then press Enter. 6. Change directory to the JL_Cmder installation folder. e.g., type: cd "C:\Program Files\JL_Cmder\" and press enter 7. Type the following command to remove the of*****ng file: javaloader.exe -u erase -f FILENAME where FILENAME is the name of the .cod file. 8. Disconnect your phone from your PC and restart it. |
The Following User Says Thank You to BesTCooL For This Useful Post: |
08-26-2009, 23:16 | #3 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | if u want new firmware 5.0 download : http://rs105tl2.rapidshare.com/files...A5.0.0.130.rar |
08-28-2009, 02:51 | #4 (permalink) | |
Member: 235703 Status: Offline Thanks Meter: 39 | Quote:
08-28-2009, 12:10 | #5 (permalink) |
Member: 18442 Status: Offline Sonork: 111110 Thanks Meter: 622 | install firmware and delete vendor.xml (search in C reflash firmware with this command start run - cmd after paste this CD \ CD PROGRA~1 CD COMMON~1 CD RESEAR~1 CD APPLOA~1 LOADER /NOJVM |
08-28-2009, 13:18 | #6 (permalink) |
Freak Poster Join Date: Sep 2007 Location: UK
Member: 595700 Status: Offline Sonork: 100.1582336 Thanks Meter: 262 | bro chk ur fone mouse ball black or white if is black(dirty) mean ur fone short so open ur fone remove lcd wait 1 minute put back lcd(screen) close ue fone and flash again if is white then full erase wed mfi and flash again... |
Debranding bb Bold 9000 on windows 7??? | menara | BlackBerry (RIM) | 1 | 05-23-2011 21:39 |
Unlocking problem in BB Bold 9000 | nice.mrkj | BlackBerry (RIM) | 18 | 05-17-2010 05:11 |
Help! BB bold 9000 won't turn on, just flashes led code | Nathan79 | BlackBerry (RIM) | 4 | 12-22-2009 08:31 |
BB Bold 9000 | thirunilavan | FuriousGold | 3 | 05-05-2009 08:38 |
BB Bold 9000 , use slow method for version v4.6.0.162_P4.0.0.155 phone dead | felliciawann | FuriousGold | 7 | 03-06-2009 19:52 |
