BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
05-24-2011, 09:37 | #1 (permalink) |
Junior Member Join Date: Mar 2008
Member: 725182 Status: Offline Thanks Meter: 0 | Strom 2 9550 GPS not working in GSM network I have a unlocked Verizon Strom 2 9550 . Currently in GSM network in INDIA , everything is running OK including BIS except GPS . I cannot lock GPS satelite signal or agps through google map . blackberry map can lock AGPS sometimes but not GPS satellite signal . To activate GPS I did lot of thing like OS reloading from verious vendor from asia . GPSone activation through QPST , fixing GPS at clear sky ( timeout error )etc . But still it not working . Also refresh option is not present in GPS settings option . Please help how can I activate GPS in my Strom 2 9550 . Thanks All Shiladitya |
05-25-2011, 07:11 | #2 (permalink) |
Junior Member Join Date: Jul 2010
Member: 1352024 Status: Offline Thanks Meter: 0 | 9550's GPS is work well! If it not work in google map. you can fix it as follows: 1.first, you goto option->status, on the screen,you type 'test', then you will enter a test screen. 2. you start the test, just check the 'gps' item in all test items. What you next to do is waitting... wait it got the satelites,it will be last for minutes. If you see the possition, your gps is activated. Otherwise you see timeout, do not lose you heart , try it several times, it can be fixed. 3.NOTE: you should try it outside, NOT in the house, IT IS VERY IMPORTANT!!!! |
I neeeeed NCDS 2.0!!!! plzz!!!! | ratzfatz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 02-27-2022 22:12 |
