I have looked all over an cannot find how to do this ! I have several Blackberries all CDMA 8703e, 8830, 8330. I use all of them. How can I clone the esn and pin so that all units are identical ? I just want to be able to throw a battery in it and go. Switching devices thru carrier is time consuming and then the issue of having to change pin numbers makes it worse. All units are set identical os versions etc. I DO NOT want to use the units all at the same time I just want to be able to switch between them by powering off unit "A" and powering on unit "B" ! Can this be done HELP !
Thanks!
