Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2009 Location: banglore
Member: 1141761 Status: Offline Sonork: 100.1618159 Thanks: 27
| unknown usb error, 507 error, 513 error 523,restarting loop, connecting jvm, connecti unknown usb error, 507 error, 513 error 523,restarting loop, connecting jvm, connecting arm error, blinking red light for all blackberry AFTER LOTS EFFORT FRIENDS I FOUND THIS METHOD IS VERY USE FULL AND EASY TO FIX ALL BB SOFTWARE BEST THING IS YOU CAN CONTROL ALL BB TOOLS HERE WITH THIS SOFTWARE ALL ABOVE MENTION ERRORS CAN BE SOLVED THROUGH THIS ONE TRICK. YOU CAN TRY AND DO WITH YOUR TRICKS ALSO JUST YOU HAVE TO BE CREATIVE PLEASE WRITE ME ANY TIME IF YOU HAVE ANY BB SOFTWARE ERRORS I WILL TRY TO HELP YOU |
| | #2 (permalink) |
| unknown usb error, 507 error, 513 error 523,restarting loop, connecting jvm, connecting arm error, for all blackberry new and tried on 100s off bb modules success on all download blackberry master control program and install it THERE ARE TWO WAYS ONE IS VIA CFP AND OTHER JAVA LOADER A,JAVA LOADER 4TH ICON AT LEFT HAND SIDE. 1.Start the program, click on Settings icon on the left, type "BrickBerry" in "Enable protected controls" field. 2. Click on Java icon on the left, select "Complete Wipe" in the right panel, check "Confirm" field, then click "Handheld Wipe" button. 3. next "Reload Software" run AppLoader to install OS B. CFP COMMAND HERE YOU CAN DO ANY THINK 1. download blackberry master control program and install it 2. download CFP_3.9.0.175.exe keep on desktop 3. open master control program and click on setting wheel on left hand side and in enable protected control type BrickBerry same as it is here 4. right click on alien face cfp button at left hand side. 5. below in cfp option (rim command-line program (cfp) executable ) select the cfp which you copied on desktop. 6. connect your bb without battery on top command-line interface (CLI) select wipe tick mark the empty box next to execute and press execute it will take 10 to 12 minutes after it finish disconnect your bb install a battery and wait for few minutes let the phone do its job. let the bb master control be open.......... now the trick is to load os 1. In bb master control on right hand side below right click on apploader it will load loader/nojvm connect your phone follow the instruction thats it you have done the job.. try to load os both the ways normal way loading as u do if it trouble then load load/nojvm if gives you error again while loading os go to step 6 select nuke and then wipe after this if says error dont cancel the loading procedure just disconnect the phone remove the battery re insert and wait untill the phone finish then connect the phone and press retry please write me if you have any doubt or error regards nasir DOWNLOAD LINK all bb software solutions by nasir.rarcfp commands.jpg mcp image.jpg |
| The Following 4 Users Say Thank You to R.Nasir.Ali For This Useful Post: |
| | #3 (permalink) |
| becarefull with task manager Many time you will have lots of trouble to fix your set that is because of windows task manager open task manger ( alt +ctrl+del ) go to process there you will find lots blackberry related application running behind like rimdevicemanager , bbsync , cfp 3.0. , ..... Etc etc delete all that and start fresh all your toubleshoot is covered. Thanks |
| | #4 (permalink) |
| solution for all most all blackberry software problems just try this before you post |
| | #5 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: iran-+989154661751
Member: 303488 Status: Offline Thanks: 55
| hai friendes try thies soft very easy Blackberry Easyflasher Beata Edition 2012 - Software Informer. A powerfull flasher tool for Blackberry mobile phones. clear all unknown usb error, 507 error, 513 error 523,restarting loop, connecting jvm, connecti |
| | #6 (permalink) | |
| friend its different Quote:
thank you very much for this help full software friend nasir | |
| | #11 (permalink) | |
| Quote:
bsak with this tool you can even control bsak master control programe controls your hard tools what i have should you here is just controling cfp 3.0.0.175 what ever you are doing here is now doing with cfp wipe nuke load os load load/nojvm load normal contol your dm this is cell phone technicians engineirs tools see this images specially king its for you step 1. mcp a1.jpg step 2. cfp setting.bmp step 3. mcp device pin.bmp step 4. cfp commands 2.bmp step 4. os managenent mcp.bmp this are very usefull images please if it helps push thanks | |
| | #13 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2008 Location: karachi
Member: 726546 Status: Offline Sonork: 100.1578784 Thanks: 82
| Quote:
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| where to find a working program all they have some errors ?? | fondas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 12-12-2012 12:26 |
| My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 24 | 08-11-2006 15:29 |
| Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 12-27-1999 08:36 |
| The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 09-20-1999 19:12 |
| error (1002) simlock3.dll winopen | fondas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 0 | 08-28-1999 15:57 |
