BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
07-28-2011, 17:03 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Location: pakistan
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | urgent help needed from all problem now is to unlock,when i try to read mep it says disable password,,, i have furious gold,mxkey,ub box, to read mep,,,, share info here all,,,,,thanx, |
07-28-2011, 17:11 | #2 (permalink) |
Insane Poster Join Date: May 2008
Member: 777865 Status: Offline Thanks Meter: 15 | for read imei and mep you must disable password if you can't , try this: Go to your Options : Security >> Security Options (the same page where you can enable/disable passwords) & scroll to the bottom. If there's an IT policy attached, it will be mentioned there. Remove the IT policy using these instructions Procedure Step 1 : Ensure the Blackberry Desktop Manager is installed using Blackberry Internet Service, and not Blackberry Enterprise Server. If you are unsure, it would probably be a good idea to uninstall the Desktop Manager and start again. If you don't have the CD that came with your Blackberry, the Software can be downloaded here. Step 2 : Download the file policy.bin and save it in your Blackberry installation directory (C:\Program Files\Research In Motion\BlackBerry). Step 3 : Wipe your Blackberry, creating a backup if necessary. Select Options/Security/Wipe on the Device. If this option is unavailable, you may have to install the latest software on your Blackberry. You need to Download and install the latest OS for your device. Connect your device, open the Desktop Manager, select Application Loader, and follow the prompts. Step 4 : Close the Desktop Manager if it is open. Step 5 : From the Windows XP Start Menu select Run..., and at the prompt type regedit. In the tree on the left hand side, navigate to: HKEY_Current_Users\Software\Research In Motion\BlackBerry\PolicyManager Right-Click the Policy Manager Folder and select New/String Value. Name the value Path. Now, Double-Click the Path Subkey and set Value Data to: C:\Program Files\Research In Motion\BlackBerry\policy.bin Step 6 : Open the Desktop Manager. Step 7 : Connect the Device. Verification Once complete, the Options/Security screen on your Blackberry should not contain references to an IT Policy, you should now be able to change all settings (including password prompts), and install Third Party Applications. BB FAQ |
07-28-2011, 17:24 | #3 (permalink) |
No Life Poster Join Date: Jul 2011 Location: ۞_ KERALA__۞_INDIA
Member: 1619462 Status: Offline Sonork: 100.1606509 Thanks Meter: 1,517 | use this links http://forum.gsmhosting.com/vbb/f489...lution-864692/ http://forum.gsmhosting.com/vbb/f413...0-left-532234/ hope you will be happy.... just click on thanks button!!!! |
The Following User Says Thank You to .::EXTREME::. For This Useful Post: |
07-30-2011, 07:00 | #4 (permalink) | |
Member: 828294 Status: Offline Sonork: 100.1615866 Thanks Meter: 124 | Quote:
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
need eeprom photo???? | mobileinfo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-26-1999 11:35 |
