BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
11-30-2010, 02:40 | #1 (permalink) |
Junior Member Join Date: Jun 2010
Member: 1335263 Status: Offline Thanks Meter: 4 | VSa - Storm2 v5.0.0.1036 (1.2) ML Info: This is 99% Java from 5.0.0.1036, 1% 5.0.0.1015. Installation: 1. Install base OS to your computer (.973 for 9520, .1015 for 9550), remove any other 2. Install this update Once you click Finish in installation wizard BBHybridsTool will open. Use it to shrink BlackBerry OS. It's recommended to do this before updating your device. It will save some space on your BlackBerry and make it boot and run faster. To update your BB: - Delete Vendor.xml from AppLoader folder, then run AppLoader.exe and follow update instructions. - When setup is complete: Remove battery while your BB is ON, wait for 30 seconds, then put it back AppLoader is found in: 32-bit OS: C:\Program Files\Common Files\Research In Motion\AppLoader 64-bit OS: C:\Program Files (x86)\Common Files\Research In Motion\AppLoader Optional steps: - Security Wipe your BB before upgrade: Options > Security > Security Wipe - Wipe Device before upgrade using BBSAK Don't forget to make backups, and restore only important data if possible. About Screen: Download: Hotfile.com: One click file hosting: VSa_1.2_Storm2_5.0.0.1036_ML.zip Version history: v1.0 - Nov 06 2010. - Added .1015 files v1.1 - Nov 21 2010. - Added .1022 files v1.2 - Nov 30 2010. - Added .1036 files - Improved boot time - No mobile network screen on startup Known bugs: - Player may not open media on first try. Press several times Play/Back to get it working. |
DES key Driver | black | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 02-08-2014 04:50 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
