-   BlackBerry (RIM) (http://forum.gsmhosting.com/vbb/f489/)
-   -   What the Blackberry LED Indicator Lights Mean (http://forum.gsmhosting.com/vbb/f489/what-blackberry-led-indicator-lights-mean-881715/)
vinay_sharma 12-16-2009 05:03
http://i201.photobucket.com/albums/a...9f61701f_m.jpg
Here is a quick guide to understanding the LED indicators of your BlackBerry.
Blue LED - The Blue LED on a Blackberry is for Blue tooth. A flashing blue light indicates an active connection via Bluetooth. You can Enable/disable this indicator under Applications > Options > Bluetooth > Menu > Options > LED Connection Indicator: On/Off.
Green LED- The Green LED on the Blackberry is for coverage indicator. If it is blinking then it means you are in a service area. You can enable/disable this "feature" under Applications > Options > Screen/Keyboard > LED Coverage Indicator On/Off.
Red LED- The flashing red LED indicates a new message is waiting. Go to your message folder and check for any unread messages. You can choose to be notified of new messages visually under Applications > Profiles > Advanced > [Select profile you wish to modify] > [Select message type you wish to modify] > Repeat Notification LED Flashing/Off
If you are using the Blackberry Storm, Sound is is used in place of Profiles.
Yellow LED- The flashing Yellow LED indicates that you are running out of battery. Time to get your Blackberry on the charger.
Best Regards
vinay_sharma
alberht 12-16-2009 19:53
If you're posting anything that you've not written then write a source. Original at Blackberry-Repair.net.
Page generated in 0.13541 seconds with 5 queries
