BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
12-16-2009, 05:03 | #1 (permalink) |
No Life Poster Join Date: Jul 2006 Location: I.N.D.I.A(PUNJAB)
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | What the Blackberry LED Indicator Lights Mean Here is a quick guide to understanding the LED indicators of your BlackBerry. Blue LED - The Blue LED on a Blackberry is for Blue tooth. A flashing blue light indicates an active connection via Bluetooth. You can Enable/disable this indicator under Applications > Options > Bluetooth > Menu > Options > LED Connection Indicator: On/Off. Green LED- The Green LED on the Blackberry is for coverage indicator. If it is blinking then it means you are in a service area. You can enable/disable this "feature" under Applications > Options > Screen/Keyboard > LED Coverage Indicator On/Off. Red LED- The flashing red LED indicates a new message is waiting. Go to your message folder and check for any unread messages. You can choose to be notified of new messages visually under Applications > Profiles > Advanced > [Select profile you wish to modify] > [Select message type you wish to modify] > Repeat Notification LED Flashing/Off If you are using the Blackberry Storm, Sound is is used in place of Profiles. Yellow LED- The flashing Yellow LED indicates that you are running out of battery. Time to get your Blackberry on the charger. Best Regards vinay_sharma |
The Following 2 Users Say Thank You to vinay_sharma For This Useful Post: |
12-16-2009, 19:53 | #2 (permalink) |
Freak Poster Join Date: Apr 2004
Member: 63988 Status: Offline Thanks Meter: 100 | If you're posting anything that you've not written then write a source. Original at Blackberry-Repair.net. |
What the heck does enter NCK mean? | paulk451 | Philips | 6 | 03-26-2014 10:14 |
LED Indicator Light Bulbs 1156-382 Ba15s - Red | IPMART | ipmart WebShop | 0 | 07-23-2009 22:50 |
Lighting about BB9000 led indicator | ankywong | BlackBerry (RIM) | 4 | 05-13-2009 23:48 |
what is the pm faultage indication ? | kiriazy | Griffin | 0 | 02-25-2005 20:37 |
What the detail meaning of the T28 channel info? | subaru | Old Ericsson Phones & Sony Phones | 2 | 11-15-2003 07:05 |
