Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | .: Nokia Unlock :. | Search | Today's Posts | Mark Forums Read |
| BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs. |
| | #1 (permalink) |
| Junior Member Join Date: Apr 2007
Member: 488229 Status: Offline Thanks: 4
| Why 8320 can't be upgrade? Hi all, I have a curve 8320 with firmware 4.2 that can't be upgrade to 4.5 firmware, (always nuked when I'm tryng to upgrade). Need your help how to forcing this one. Reason: doctogo can't run on 4.2 Thanks for advance. |
| | #3 (permalink) |
| Thanks, but I have been trying with many firmware 4.5 (with no vendor.xml), still fail., device just can be upload with 4.2 firmware., In other curve 8320..there is no problem for upgrading. |
| | #8 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: May 2005 Location: CellcomEngineering Age: 31
Member: 147116 Status: Offline Sonork: 100.1578260 Thanks: 221
| delete vendor.xml file first then try again............. work 100% bro.................. |
| | #9 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2008 Location: Philippines Age: 25
Member: 758106 Status: Offline Thanks: 252
| use apploader inside program files/common files/research in motion/apploader connect your blackberry to pc without battery and when it say usb_unknown quickly press next and wait until your blackberry finish restoring/updating OS.. tested by me many times for nuked/bricked blackberry.. because in this method, connecting to bootrom and java will be bypassed.. rg |
| The Following User Says Thank You to jap_line For This Useful Post: |
| | #10 (permalink) |
| many thanks for quick respons, - vendor.xml deleted. - mfi full erase. - use loader /nojvm command tried with and without battery , standard DM upgrade etc. - tried with more than 1 pc/notebook - 99% upgrading firmware without problem (I have done with many & type bb) but I still got a problem with this one, as note item works normally when use firmware 4.2 , firmware 4.5 can't do. several guys says to me, there are some type/item yg can not be upgrade, is that issue right? |
| | #11 (permalink) |
| Junior Member Join Date: Jan 2009
Member: 947476 Status: Offline Thanks: 0
| hi there gartbox I have the same issue with u... got 8320 curve with OS 4.2.2.181 and need to upgrade to 4.5++ with no luck! since the first time I tried to upgrade, it stops on device initialization then the bb just showing blank screen and LED keeps on and off every 3-5 secs then I finally downgrade it back to 4.2.2 and it works like a charm (so glad that I didnt brick my bb) then I found out on Status screen shows IT Policy Enabled when typed BUYR but when I checked the General Security settings, there's no IT Policy there I have been trying many and many methods outthere but none have fixed my problem... I'm suspecting that this IT Policy enabled mode is preventing me to upgrade to 4.5 I've tried the policy.bin solution etc but no luck (since JLwiping can be used only for 4.3++) Do you have the same issue here? Hope anyone can help us on this... thanks! |
| The Following User Says Thank You to m3x For This Useful Post: |
| | #14 (permalink) |
| Junior Member Join Date: Mar 2009
Member: 997749 Status: Offline Thanks: 0
| Hi guys, I have same problem. "Catastrophic assertion failure" --> then "Unable to reconnect to the device during a multi-stage load operation." `-------> using without batt method Still don't have any solution? Please anyone help us |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| so..iphone with 2.2.1 can't be upgrade to 3.0 to unlock anymore? | Cake | iPhone ,iPod & iPad (Apple Inc. Products) | 9 | 09-15-2009 07:02 |
| ERROR - Bad data in dongle, this dongle can't be upgraded! | nonu_don | Easy-Unlocker | 1 | 12-05-2008 10:54 |
| ERROR - Bad data in dongle, this dongle can't be upgraded! | trycktill | Easy-Unlocker | 0 | 12-03-2008 03:34 |
| why THx can't be flashed ???? | chavrotti | VygisToolbox | 1 | 09-28-2005 19:45 |
