05-02-2010, 19:26 | #1 (permalink) |
No Life Poster Join Date: Jun 2006 Location: ..::SL3 Unlock Source::.. Age: 38
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | ..:: Android devices hard reset ::.. Android hard reset Android devices hard reset HTC HD2 Leo hard reset Solved: How to hard reset HTC HD2 Leo: With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then... HTC HD2 Leo Soft reset Resetting Your HTC HD2 Phone Performing a HTC HD2 Leo soft reset Perform a soft (normal) reset to clear all active program memory and shut down all active programs. This is useful when your phone is running slower than normal, or a program is not performing properly. If a soft reset is performed when programs are running, unsaved work is lost. 1. With your thumb or finger, open the back cover by lifting up from the left side of the cover. 2. The RESET button is located at the bottom left below the battery compartment and SIM card slot. Use a small object with an unsharp, pointed tip such as a toothpick to press the RESET button. Your phone restarts and displays the Home screen. 3. To replace the back cover, secure the right side of the back cover first and then press down the cover into place.Performing a HTC HD2 Leo factory reset HTC HD2 hard reset If a normal reset does not solve a system problem, you can perform a factory reset. After a factory reset, the phone is restored to its default settings—the way it was when you first purchased it and turned it on. You will lose any programs you installed, data you entered, and settings you customized on your phone, and only Windows Mobile software and other pre-installed programs will remain. There are two ways to do a factory reset. One way is perform a clear storage process through the phone settings. The other way is to perform a hard reset by pressing certain buttons on your phone, in cases when you are unable to start up your phone and enter the phone settings. Warning! Your phone will be set back to factory default settings. Make sure that any additional installed programs and important data on your phone have been backed up before you perform a factory reset. Important If Encrypt files when placed on a storage card is enabled, back up all files from the storage card before performing a factory reset (Clear Storage or hard reset) or updating the operating system. Otherwise, you will no longer be able to access the encrypted files on the storage card. Use ActiveSync or Windows Mobile Device Center to transfer files between your storage card and computer. After the procedure, copy your files back to the storage card. To perform a HTC HD2 Leo hard reset with buttons 1. With the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it. You will then see this message on the screen. 2. Release the VOLUME UP and VOLUME DOWN buttons. 3. Press the VOLUME UP button to perform the hard reset, or press any other button to cancel the reset. To perform a clear storage 1. On the Home screen, slide to the Settings tab and then tap Security > Factory reset. 2. Enter “1234 ” and then tap Yes. |
The Following 5 Users Say Thank You to kushol For This Useful Post: |
05-02-2010, 20:10 | #3 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | Google Nexus ONE hard reset Solved: How to hard reset Google Nexus ONE: Hold down VOLUME DOWN and push POWER ON button for Google Nexus ONE hard reset You can do a hard reset from the menu here or with buttons see below Applications SETTINGS > PRIVACY > FACTORY DATA RESET. This will ERASE ALL DATA on GOOGLE NEXUS ONE! TAP RESET Phone than EREASE EVERYTHING. NEXUS 1 WILL REBOOT! Google Nexus ONE hard reset with buttons / keys Google Nexus ONE hard reset with buttons / keys Howto reset Android 2.1 - hard reset htc nexus one Wipe data format nexus one IF YOUR NEXUS ONE SCREEN FROZEN Power off Nexus ONE remove/reinsert battery if power button not responding. Hold down VOLUME DOWN and push POWER ON button for one sec. Release buttons. You will see a boot menu HBOOT with various options. NEXUS ONE FASTBOOT, RECOVERY, CLEAR STORAGE and SIMLOCK menu options. Select with Volume up / down keys and Enter option with POWER button. IF you choose nexus one Recovery and you see a yellow exclamation point and green droid E:Can't open /cache/recovery/command just press volume down +power key and you will see android system recovery <2e> with the track ball highlight an item and click to select from the blue menu android reboot system now apply sdcard:update.zip android wipe data / factory reset android wipe cache partition |
The Following 2 Users Say Thank You to kushol For This Useful Post: |
05-02-2010, 20:21 | #4 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | HTC Hero hard reset Solved: How to hard reset HTC Hero Resetting the Phone Resetting the phone deletes all data, including downloaded applications, and resets the phone back to its initial state—the state before you turned on the phone for the first time. Important Make sure to back up important data you have on the phone before you reset your phone. To reset the phone 1. Press HOME > MENU, then tap Settings > Security > Factory data reset. 2. On the Factory data reset screen, tap Reset phone and then tap Erase everything. To reset the phone using phone buttons 1. With the phone turned off, press and hold the HOME and BACK buttons, and then briefly press the END CALL/POWER button. The reset process will start after a few seconds. 2. Wait for the phone to finish the reset process and then press MENU. Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. |
05-02-2010, 20:28 | #5 (permalink) |
Member: 293662 Status: Offline Sonork: 100.1622609 Thanks Meter: 317 | HTC Magic hard reset Solved: How to hard reset HTC Magic HTC Magic Soft reset Resetting the HTC Magic Android phone Resetting the phone deletes all data, including downloaded applications, and the phone back to its initial stateâ�the state before you turned on the phone for the first time. Important Make sure to back up important data you have on the phone before you perform a factory data reset. To reset the phone 1. Press HOME > MENU, then touch Settings. 2. Scroll down the screen, then touch SD card & phone storage. 3. Navigate to the Internal phone storage section, then touch Factory data reset. 4. On the Factory data reset screen, touch Reset phone and then touch Erase everything. ( To reset the HTC Magic phone using phone buttons scroll down) HTC Magic hard reset Factory reset To reset the HTC Magic phone using phone buttons 1. With the phone turned off, press and hold the HOME and BACK buttons. 2. Briefly press the END CALL/POWER button while continuing to press the HOME and BACK buttons. 3. When you see the screen with the 3 Android images, release the HOME and BACK buttons, and then press the TRACKBALL. Tip If your phone hangs or freezes, remove the battery then wait for a few seconds, and then re-install it. After re-installing the battery, turn on the phone. |
The Following User Says Thank You to kushol For This Useful Post: |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
My 5110 v5.11 have a strange error.., it resets it self every 60second | luuk | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 24 | 08-11-2006 15:29 |
how can you reset the life timer without using a data cable for a 5125 TDMA phone? | PiNoY_bOy204 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 08-23-2001 12:46 |
HOW TO RESET SECURITY CODE IN NOKIA 6210 | ed2k_7 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 05-26-2001 05:33 |
5190 patial flashes - why are they so hard to find? | Bads | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 04-14-2001 03:18 |
