01-30-2007, 14:32 | #1 (permalink) |
No Life Poster Join Date: Oct 2004 Location: Holland China Brazil Age: 43
Member: 88016 Status: Offline Thanks Meter: 320 | DB2020 Unlocking Started in Setool How to unlock DB2020 phones with server. (pls note price for DB2020 unlock 12 credits!) Step 1: select USB as interface. that is REQUIRED. Step 2: select K610 as phone model (or any other DB2020 model, they are same) Step 3: |settings - check "use server for csca unlock/flash", "do full unlock instead of user code reset for DB2020", fill your login details. Step 4: back to semc tab, press unlock, attach phone with pressed "C" (or 2+5) buttons. Step 5: wait for signature calculation, it can took about 2 minute. If calculation will fail, your credits will NOT be deducted. if calculation is success, then signature will be saved in backup\%imei% folder in your setool2 directory. Step 6: next, you will be prompted to detach phone and turn it on. do so. detach phone. turn it on FULLY phone will be on 5 locks, that is normal. Step 7: connect phone to USB. if phone will ask you switch to phone mode - switch to phone mode. it can ask you for drivers,if you not installed them previously. install all drivers (links below) be SURE that you install all drivers correctly. Step 8: press "test point OK" procedure will continue,phone will be switched off and unlocked. !note. DB2020 unlock supported on both servers .196 and .198 remember, if something will go wrong - you have a backup of security units for now price for DB2020 unlock 12 credits (36 usd) BR Kashif Khan Last edited by Kashif Khan; 01-30-2007 at 14:57. |
DB2020 Unlocking starts in SETOOL and MT-BOX | nnaeem11 | GOT SEMC | 4 | 05-13-2007 09:04 |
db2020 unlocking started in india | babbu | Universalbox | 2 | 04-21-2007 13:54 |
DB2020 unlock start again Announcement about DB2020 unlock service | dharmdev | Universalbox | 1 | 04-09-2007 16:51 |
When DB2020 unlock start again | celluniversal | Universalbox | 6 | 04-09-2007 07:47 |
DB2020 Unlocking Started Today. Great | talkways | Universalbox | 40 | 04-01-2007 20:15 |
