Member: 101860
Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | CFWEnabler 2.10 released. (Re-Updated 2)
[ Custom Firmware EnAbler 2.10 to 5.03 ChickHEN by Xenogears & Becus25 ]
[ FOR PSP 200x SLIM ONLY ] Quote:
Version 2.0 of this Custom Firmware Enabler has just been released at Dark-AleX.org Forums. Changes?
Updated: Version 2.01 has been released on the same thread, as a quick bugfix to prevent errors if v1.0 was already installed on flash, adding a version detector.
Re-Updated: Version 2.02 has been released on the same thread, as a quick bugfix for flashing errors with pops.prx file when using sygcheck with the md5 check.
Re-Updated 2: Version 2.10 has been released on the same thread, as a quick bugfix for some plugins bugs as well some improvements.
* Now you can use POPS. You will need the 5.00 Original Firmware and the latest PSARdumper for getting the needed prx files. Once with the files, copy pops.prx and popsman.prx from the F0 folder that PSARdumper generated (with "X" option, not []) to ms0:/PSP/GAME/CFWEnabler/Pops, and then choose "Enable Pops Support" from the CFWEnabler. Once done, you can delete the files you have just copied.
* You can configure your Custom Firmware like if you had the original recovery mode, once loaded you will see the options.
* New GUI, MD5 checks, more security, etc.
As you can see, the readme is in spanish. However, the main changes are explained in english up here. Good work, guys!
ps. Answering some e-mails, i would just have to say that i am not involved on the development of this app, therefore neither i or AleX will contribute on it. Be patience :-) And, as the readme says, "It's not decided if a 3000 version could be done or not."
| Quote:
NOTE: For people who have downloaded version 2.00, 2.01, 2.02, is necessary to use version 2.10 for optimum performance.
CustomFirmware Enabler 2.10 para 5.03 ChickHen por Xenogears y Becus25. CustomFirmware Enabler 2.10 to 5.03 ChickHen by Xenogears and Becus25.
What is? What is?
A program that activates the functions of the M33 custom firmware using ChickHen. A program that activates the functions of the M33 custom firmware using ChickHen.
What do I need? What do I need?
- A PSP Slim (Slim only works with, regardless of the plate you have) - A PSP Slim (Slim only works with, regardless of the plate you have)
- Firmware version 5.03. - Firmware version 5.03.
- ChickHen R2 (minimum Beware patched versions!). - ChickHen R2 (minimum patched versions Beware!).
Changes 2.10: 2.10 Changes:
- Fixed a problem when you change settings for the plugins. - Fixed a problem when you change settings for the plugins.
- Fixed internal problems. - Fixed internal problems.
- Fixed a problem that caused a crasheo accessing plugins and have no plugin. - Fixed a problem that caused a crasheo accessing plugins and have no plugin.
- Improved detection of release. - Improved detection of release.
Changes 2.02: 2.02 Changes:
- Fixed a bug in the installation of the Pops (The PRX MD5 is different in each PSP, which is why the test works, but not in the other consoles) - Fixed a bug in the installation of the Pops (The PRX MD5 is different in each PSP, which is why the test works, but not in the other consoles)
Changes 2.01: 2.01 Changes:
- Fixed a bug not detect either a previous installation (caused that could not be installed above the new version) - Fixed a bug either not detect a previous installation (cause that could not be installed above the new version)
Changes 2.00: 2.00 Changes:
- System pops native activation. - System pops native activation.
- System configuration Custom Firmware. - System configuration Custom Firmware.
- Verification MD5 of files that are installed in flash, if you have not installed either, re-install. - Verification MD5 of files that are installed in flash, if you have not installed either, re-install.
- Nice interface. - Nice interface.
- Safety flasheos unnecessary. - Safety flasheos unnecessary.
- Protection from ChickHen load the Custom Firmware. - Protection from ChickHen load the Custom Firmware.
(It is necessary that this ChickHen in a folder called "ChickHEN inside Photo or Pictures.) (It is necessary that this ChickHen in a folder called" Photo ChickHEN inside or Pictures.)
- Changed version of the system (now shows 5.03 M33) - Changed version of the system (now shows 5.03 M33)
Installation: Installation:
- Copy the folder to your psp CFWEnabler in X: / PSP / GAME / - Copy the folder to your psp CFWEnabler in X: / PSP / GAME /
To be asaí: X: / PSP / GAME / CFWEnabler / EBOOT.PBP To be asaí: X: / PSP / GAME / CFWEnabler / EBOOT.PBP
IMPORTANT: Do not change the folder name CFWEnabler! IMPORTANT: Do not change the folder name CFWEnabler!
How to use: How to use:
Starts ChickHen from the picture section. Starts ChickHen from the picture section. Then start the homebrew called "CFWLoader 2.00. Then start the homebrew called "CFWLoader 2.00.
Follow the instructions that tells you the program. Follow the instructions that tells you the program.
FAQ: FAQ:
- Can load isos? - Yes, yes you can. - Yes, yes you can.
- Do you like my PSP Slim is ****ing plate? - Do you like my PSP Slim is ****ing plate? - Yes, it does not matter. - Yes, it does not matter.
- Does my PSP3000? - Does my PSP3000? - No, it does not work. - No, it does not work.
- Are you going to get a version for PSP3000? - Are you going to get a version for PSP3000? - It is not known. - It is not known.
- Sure you do not know? - Sure you do not know? - Yeah, sure. - Yeah, sure.
- Really? - Really? - Yes - Yes
- Really good for? - Really good for? - ¬ ¬ - ¬ ¬
- Can you break my console? - Can you break my console? - This version has several checks to verify that everything is installed, it is 99.99% safe - This version has several checks to verify that everything is installed, it is 99.99% safe
- When you turn off the console I have to repeat the procedure? - When you turn off the console I have to repeat the procedure? - Yes, you have to repeat it, but after the first time, no longer flashea anything. - Yes, you have to repeat it, but after the first time, no longer flashea anything.
- And you can not prevent either procedure? - And you can not prevent either procedure? - Could be avoided if we could do an IPL compatible. - Could be avoided if we could do an IPL compatible.
- Is expected to be in the future rectify the current problems? - Is expected to be in the future rectify the current problems? - It is possible, but is not guaranteed anything. - It is possible, but is not guaranteed anything.
- Does the M33 SDK? - Does the M33 SDK? - Yes, it works. - Yes, it works.
- Are the plugins? - Are the plugins? - Yes, they work. - Yes, they work.
Common Errors: Common Errors:
- When you start the program automatically goes to the menu - - When you start the program automatically goes to the menu --
Was unable to assign the flash, make sure you have a PSP Slim (2000), and if you go, make sure your version is correct ChickHen. Was unable to assign the flash, make sure you have a PSP Slim (2000), and if you go, make sure your version is correct ChickHen.
- I do not run the isos - - I do not run the isos --
Make sure that your configuration is correct. Make sure that your configuration is correct.
- I created a folder called SVCPlayer Why? - I created a folder called SVCPlayer Why? - --
You have a plugin that creates nothing to do with CFWEnabler. You have a plugin that creates nothing to do with CFWEnabler.
- Other errors is important to check the plugins that are loaded can cause problems. - Other errors is important to check the plugins that are loaded can cause problems.
Activate Pops: Pops Activate:
To enable compatibility with Native Pops, it is necessary to remove some modules of the firmware 5.00 official. To enable compatibility with Native Pops, it is necessary to remove some modules of the firmware 5.00 official.
- Required - - Required --
- A PSP that enables homebrew loading (PSP 2000 worth CFWEnabler or Hen) - A PSP that enables homebrew loading (or PSP 2000 with voucher CFWEnabler Hen)
- The 5.00 update from Sony. - The 5.00 update from Sony. ( http://rapidshare.com/files/154173870/500.PBP )
- PsarDumper with support for 5.00. - ( http://rapidshare.com/files/16539093...0_3000_too.zip )
1.-The PsarDumper copy of our report. 1.-The PsarDumper copy of our report.
2.-copy the firmware 5.00 to the root of the PSP under the name "EBOOT.PBP" 2.-copy the firmware 5.00 to the root of the PSP under the name "EBOOT.PBP"
3.-execute the PsarDumper. 3.-execute the PsarDumper.
4.-click on "X" and waited. 4.-click on "X" and waited.
5.-When finished, enter usb from pc and have a root folder called F0. 5.-When finished, enter usb from pc and have a root folder called F0.
6.-looking pops.prx files in the folder and popsman.prx kd (in F0) 6.-looking pops.prx files in the folder and popsman.prx kd (in F0)
7.-The Copy To Folder Pops within CFWEnabler (X: / PSP / GAME / CFWEnabler / Pops) 7.-The Copy To Folder Pops within CFWEnabler (X: / PSP / GAME / CFWEnabler / Pops)
8.-Run the CFWEnabler. 8.-Run the CFWEnabler.
9.-click on the option "Enable Support Pops." 9.-click on the option "Enable Support Pops."
10.-We followed the instructions. 10.-We followed the instructions.
11 .- Done, and you can delete the files from the Memory Stick Pops, both the EBOOT.PBP and the F0 folder as the files in the folder CFWEnabler / Pops. 11 .- Done, and you can delete the files from the Memory Stick Pops, both the EBOOT.PBP and the F0 folder as the files in the folder CFWEnabler / Pops.
Warning: Using the Firmware M33 can be accessed freely by the USB Flash0 care because you can cause a brick, you are advised not to change anything to the internal memory. Warning: Using the Firmware M33 can be accessed freely by the USB Flash0 care because you can cause a brick, you are advised not to change anything to the internal memory.
Acknowledgments: Acknowledgments:
- A Dark_AleX for the M33 modules. - A Dark_AleX for the M33 modules.
- Especially him, who knows who he is, and that is part of the credit for helping him. - Especially him, who knows who he is, and that is part of the credit for helping him.
Un Saludo. Un Saludo.
Mirror: http://rapidshare.com/files/238471979/CFWEnabler210.zip | CFWEnabler 2.10 (Only for PSP SLIM 2000)
br
RNC_EBM
