Anybody know x-box 360 game hack Does anyone know to download full games on xbox 360 without pay or jtag use If i helped you press thanks button ↓ |
first off you have to flash your drive with Special firmware.. in Order to play them.. you can also copy any game as long as you have a certain burner inyour Pc...(ie) liteon revision B.. |
No, you cannot download full games and play completely without the disc without a JTAG'd system. DVD drive f/w flashing only gets you halfway....You can play burned (backups) and also copy to hard drive, as long as you have the space and the disc. But you have to input the disc first so the xbox knows you actually own the disc you copied to the HDD. |
whats this jtag you are going on about.... ***ck3i***. you dont need it, but it makes the process simpler with out going in to Full detail ,,,i anit time. to explain... right you download an iso that some kind person uploads of the game you want... then you need a software called * agbx* which stelth patches the iso... Now you burn this to DVD,,, WITH a compatable Burner,, NOT any old burner, Certain liteons,, revision b, is what i used.... Now your Xbox will Play this game, as long as your Xbox is Flashed with a certain firmware... if you want more contact me in private/sonork. |
Oh yeah...one thing I forgot. Search for Xbox 360 ODD emulator.....that's would be the easiest (not cheapest) way The Clash: he said download to the Xbox, which I assumes means he wants to copy the game to hard drive and play without disc.......if you just firmware flash, you only can play a game installed on hard drive WITH the disc everytime...it just momentarily spins before starting the game if done this way. JTAG and an ODD emu will both allow you to copy any game in the right format to the Xbox hard drive or external hard drive...disc free |
sorry yes, i did slightly miss read the download bit.. i used to be into this stuff in a big way a couple of years back, flashing xboxs and burning games... seems technology has moved on a bit... |
I just recently "got back in" really....but not much has changed too much. |
not all xbox can be hacked new versions of the xbox got unhackable drive . so you do need to rgh you xbox to get your drive key and replace it with flashable drive with your correct key. if you got fat xbox then you can flash your drive if you got slim xbox , then you need to check the menufacture date , if its after 9/11 then you can flash your drive , only rgh your xbox |
Yeah...I've never dealt with the slims. The slims need PCB replacement....whether to rgh is based on which drive you have. |
If anyone has been Following this, and would like to flash their Xbox, here is the Tutorial. http://bazicenter.com/tutorial/Downl....FINAL%203.pdf and here is a link for the software to be able to Do the Job.... JungleFlasher.0.1.96.Beta(323)! here you will find the firmwares to flash to your Xbox.. http://www.mediafire.com/download/bv...ware_Pack.rar#! Here is a great site do get more great stuff regarding how to backup your Games..ect.. http://jungleflasher.net/downloads.html |
Guess I'll add to the resources a bit. The xbox-scene forums. This is a good base, pretty much where I started. Now xboxpirate.eu forums is where I frequent, as it's thriving pretty good. |
Thnx all for replay in will try this at sunday and will replay if i stock somewhere or have a question cause now i'm busy at work with phones If i helped you press thanks button ↓ |
Does not take long to write the new firmware.. One other thing, I dont think it mentions.. you have to strip your xbox. . Also you need an internal sata card on the motherboard.. |
It would help if you really tell us exactly what your doing. We are generalizing, but each console is specific basically. The more you tell us, the more we can tell you. Are you trying to flash your dvd drive and just play burned backups and maybe play online? And what xbox do you have...then we have to know which dvd drive you have. |
