Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc |
06-19-2010, 23:44 | #1 (permalink) |
Freak Poster Join Date: Jun 2009 Location: Georgia, Tbilisi.
Member: 1057286 Status: Offline Thanks Meter: 14 | the game could not be started(80020321) psp |
06-20-2010, 00:15 | #2 (permalink) |
Freak Poster Join Date: Oct 2007 Location: @GsmHosting.com Age: 39
Member: 601608 Status: Offline Sonork: 100.1590021 Thanks Meter: 150 | did you tried this This error is appearing because there is a setting in the hidden configuration menu that is set to require a UMD game disc to be in the PSP when it attempts to load. Turn off the PSP, then hold the R button down while turning on the system. You will be in the Recovery mode/Configuration menu. Choose configuration, then go to the 5th option, and press X once. This will switch it to "NO UMD". Then press X on "Back", then "Exit". Once you restart you should be able to load the ISOs, CSOs etc. without getting the 80020321 error. |
The Following User Says Thank You to The_Killer For This Useful Post: |
06-20-2010, 00:20 | #3 (permalink) |
Member: 601608 Status: Offline Sonork: 100.1590021 Thanks Meter: 150 | i don't have experience with psp but i have repaired this problem before in ma psp 5.03GEN-A its too hard but you will do it if you have some patient finally in this SITE you will find all what you need to hack your PSP Good Luck Br Ahmed |
01-30-2011, 01:15 | #5 (permalink) |
Junior Member Join Date: Oct 2008
Member: 885772 Status: Offline Thanks Meter: 0 | hey people iv got the solution : This is what you do : when you are on the main menu (xmb) press select and this menu will open change teh things on the menu to this : CPU CLOCK XMB - 333/166 CPU CLOCK GAME - 333/166 USB DEVICE - MEMORY STICK UMD ISO MODE - SONY NP9660 ISO VIDEO MOUNT - NONE USE DIRECTION PAD TO CHANGE THE OPTIONS LEFT/RIGHT |
02-13-2011, 15:03 | #6 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Greatwall Center™ Age: 43
Member: 325816 Status: Offline Thanks Meter: 31 | Quote:
CPU CLOCK GAME - Default USB DEVICE - MEMORY STICK UMD ISO MODE - SONY NP9660 / M33 Driver ISO VIDEO MOUNT - NONE U may get error on others game if u do not use the following rules. and try install ******* firmware promethus-4. it can run require f/w 6.35 | |
"Deskey Device driver not found" ?? Please help | DivAdonis | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 06-08-2017 13:21 |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
Ringtones from the charts and new Links | GM | GSM Mobile Links | 0 | 09-26-1999 13:54 |
The multiple errors of Winlock ... ??? | Genata | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 09-20-1999 19:12 |
how the **** do i make wintesla 6.03 work | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-16-1999 08:41 |
