Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 05-04-2011, 07:52   #1 (permalink)
coldGin's Avatar
Member: 1035797
~GUIDE [Downgrading]6.30/6.31/6 .35 psp 1000/2000/3000 and go~
Hi, all this is my first Tutorial in this forum it can be done on ofw 6.30/6.31 and 6.35 for those who want cfws in 6.20 like pro b5x permanent ,6.20 TN E etc
i wanna help some people which they want to downgrade their psp,s i had tested it in only on PSP 3000 (3g and 4g ) and PSP go (5g)
make sure you have PLEASE MAKE SURE YOU HAVE MORE THAN 80% BATTERY REMAINING
FOR THOSE WHO HAVE PSP 3000 3G THEY CAN GO LOW AS 4.21 (MOBO TA090V2)
FOR THOSE WHO HAVE PSP 3000 4G THEY CAN GO LOW HAS 5.70 (MOBO TA093)
FOR THOSE WHO HAVE PSP GO 5G THEY CAN GO LOW AS 6.20
  1. PSP 200X with TA88-V3 ;
  1. Can Downgrading to
    OFW 4.20 Impossible
    Cannot be Downgraded to OFW 4.21 Possible
    Can be Downgraded to OFW 5.00 Possible.
    Can be Downgraded to OFW 5.01 Possible.
    Can be Downgraded to OFW 5.02 Possible.
    Can be Downgraded to OFW 5.03 Possible.
    Can be Downgraded to OFW 5.51 Possible.
    Can be Downgraded to OFW 6.00 Possible.
    Can be Downgraded to OFW 6.10 Possible.
  1. PSP 300X with 03G Module:
  1. Cannot be Downgraded to OFW 4.20 Impossible
    Cannot be Downgraded to OFW 4.21 Impossible
  1. PSP 300X 03G ;
  1. PSP 300X with 04G Module:
    Cannot be Downgraded to OFW 4.21 Impossble to OFW 5.00 Impossible.
    Cannot be Downgraded to OFW 5.01 Impossible.
    Cannot be Downgraded to OFW 5.02 Impossible.
    Cannot be Downgraded to OFW 5.03 Impossible.
    Cannot be Downgraded to OFW 5.51 Impossible.
  1. PSP GO 05 ;
    Cannot be Downgraded to OFW 5.00 Impossible
    Cannot be Downgraded to OFW 6.00 Impossible.
1-A PSP 3000 (3g and 4g ONLY ) 2000/1000 or PSP go (5g)
2-Make sure you have a 3g or 4g PSP 3004 by using pspident http://http://www.psp-hacks.com/file/1725
3-download Daves downgrader _(SIGNED)_
http://www.megaupload.com/?d=ZYNNX15H
4-Unzip it
5-put it in PSP >GAME folder dont RUN IT UNTIL I SAYS
6-then download a fresh copy of any ofw as listed in up i am trying it with ofw 6.20 http://http://www.psp-hacks.com/file/1855FOR PSP GO USERS PLEASE USE THIS LINK FOR OFW 6.20 OR IT WILL BRICK USING FIRST LINK FOR 6.20 WHICH IS FOR PSP 1000/2000/3000
http://http://www.psp-hacks.com/file/2010
7-Unzip it then put it in PSP>GAME>CREATE NEW FOLDER CALLED UPDATE PUT IT THEIR
8-Run the Dave Downgrader follow the onscreen instructions
WARNING:I AM NOT RESPONSIBLE OF ANY BRICK CAUSED BY USING THIS TUTORIAL TO AVOID ANY POSSIBLE BRICK PLEASE READ CARE FULLY AND CO IT CORRECTLY[/SIZE]
I DID NOT TESTED THIS ON PSP 1000 and 2000 because i dont have any AFTER INSTALLING YOU WILL GET A BLUE SCREEN SAYING THAT SYSTEM FILES ARE CORRUPTED O TO CANCEL PRESS O THEN TURN IT OFF THEN TURN IT OWN IT WILL BE IN 6.20 THIS UIS BECAUSE THE NAND THE FLASH MEMORY WHICH STORES THE OFW IS FORMATTED AND OVERWRITES WITH NEW ONE (CORRECT ME IF I AM WRONG )
IT WILL ALSO WORK WITH THEM
I hope every one enjoy this guide
thanks for reading
__________________
PSP 3004 TA - 090 v2 {3g} cfw 6.35 PRO B3
3004 {4g} gt5 edition ofw 5.70
Credits to 101GamZer
The Following User Says Thank You to coldGin For This Useful Post:
Old 05-11-2011, 20:35   #2 (permalink)
Member: 1360855
How to unbrick psp 1001 without recovery menu restore flash0 file pls help
Old 05-26-2011, 08:49   #3 (permalink)
coldGin's Avatar
Member: 1035797
■Θ■ PSP: Universal Unbricker To Unbrick/Downgrade/ Restore Any PSP To 4.01m33-2 ■Θ■
Old 05-28-2011, 09:14   #4 (permalink)
coldGin's Avatar
Member: 1035797
PSP Firmware 6.39 Downgrader 3.1
6.39/6.38/6.35/6.31 -> 6.20/6.35 Downgrader By Davee, ported to 6.38/6.39 by some1
v3.1: Fixed idiot bug for 6.38 I created when adding 6.39
Instructions:
If you have anything lower than an 07g place the 6.20 update in PSP/GAME/UPDATE.
If you have an 07g or an 09g, place the 6.35 update in PSP/GAME/UPDATE.
No screenshots added because it’s only text (splash screen as pic1).
Important note: You run the application at your OWN risk. I am not held accountable if you **** up your PSP.
Another important note: After you downgrade to 6.20, you will get a BSOD (saying that your system information is corrupted), this is OK, just click circle to reset your system information and you will be back to normal.
[What does it do?]
Allows users who are incontent with their firmware to downgrade to 6.20 using the Sony Updater.
[How do I use it?]
Copy the “PSP” folder to your PSP. The downgrader is “signed” and can be launched from OFW XMB. You need to copy the 6.20 update to PSP/GAME/UPDATE/EBOOT.PBP and for PSPgo it must be the eflash it is placed on. After setup run the downgrader and follow the onscreen instructions.
[What does it technically do?]
It uses the utility/power exploit to gain kernel access and reboots into the updater with a special PRX running. This PRX uses the pspdecrypt functionality to decrypt the updater PRX when needed. This allows the updater to boot in the newer firmwares.
6.38/6.39: *add when source is released*
[READ]
You run the application at your OWN risk. I am not help accountable if you PSP ****s up.
VIDEO TUTORIAL
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-16-1999 08:41
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.26429 seconds with 11 queries
