Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc |
11-20-2008, 23:47 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: UNITED KINGDOM Age: 44
Member: 74415 Status: Offline Sonork: gsm.zone Thanks Meter: 339 | Nintendo Wii - Nunchuk LED Modding Tutorial! This tutorial will show you on how to put a LED light in the nunchuck under the stick. Requirpments: one nunchuck A Triwing Screwdriver Needle Nose Pliers one 3mm LED in your choice of colour Soldering Iron and Solder Electrical Tape 3mm LED: Code:http://ledshoppe.com/led3mm.htm Step 1: useing the Triwing Screwdriver carefully unscrew and take off the nunchuck shell. Step 2: This mod will center around two test points. Step 3: You’ll need to use your pliers to bend the leads of the LED as shown wrap a small amount of Electrical tape around the exposed leads Step 4: place the led on the circuit board like shown on pic and solder the leads on to the two test point Keep in mind LED's have polarity Make sure your + and - go to the correct sides of the "test points." The side of the led that is flat is the negative side. Another way to identify the sides is to look at lead length. The shorter lead is the - and the longer lead is the +..make sure the led light does not go past the white analog box leave it alone for five mins to make sure the solder has set properly Step 5: useing the triwing screwdriver again screw the nunchuck back together. Step 6: plug the nunchuck into the wiimote and turn it on if you have done it right your analog stick will now glow. you now have a modded nunchuck! Download Mod Pics: Code:http://games.datadino.com/lednunchuck/ You can use this tutorial to create and sell modded nunchucks! br karim |
Nintendo Wii | porn | Wanted Products | 0 | 03-22-2007 16:40 |
Get a FREE Nintendo Wii ? | ash213 | Off Topic Zone | 0 | 01-01-2007 11:48 |
Get a FREE Nintendo Wii ?? | ash213 | Nokia Multimedia | 0 | 01-01-2007 11:47 |
