PS4 5.05 Exploit Offline (PS4 Jailbreak) Download PS4 5.05
you can install exploit directly from here
from Your PS4 browser
Steps are pretty simple Select 5.05 and select Mira+HEN and you are good to go
and as precaution Select Disable updates to prevent Ps4 from updating accidentally
After testing and research i found offline way that you will have to do onetime
Follow this video
Notes after testing : Jailbreak isn't Permanent which means if you shutdown your PS4 you will lose jailbreak that's why i added offline way so you will repeat single step
After you are Done you will need to install the games
-Make Sure You formatted you usb HDD or drive as Exfat and put PKG Games files in Root
-Go to DEBUG in settings menu and select GAME and Select install packages and simply select PKG and install and that's it
if you have any question please ask and i will try to update guide with any updates
i will post Another way for PS3 Unhackable slim and super slim by games injection later |
