Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 05-27-2009, 00:56   #1 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
[PSP] - CFWEnabler for ChickHEN
[ChickHEN Revision 2] - Team Typhoon
[Changelog]
- Now supports homebrew
- Homebrew Support enhanced
- Tiff image blocking in HEN (displays unsupported)
[What it does?]
ChickHEN works as a homebrew enabler for all PSP models (1000, 2000 and 3000) and allows execution of homebrew games and apps on 5.03 Official firmware. It can allow you to play games such as Bugz!, Jellycar or run apps such as pspfiler and PSPTube. Homebrew enhances the experience of a normal PSP without any faulty side-effects.
[What it does not do?]
- Run ISO, CSO or any other form of UMD backup.
- Run PSX Games
- Touch The Flash of your beloved PSP
- Magically allow the use of Custom Firmware (on TA-088v3 or PSP 3000)
- Load plugins
[How do I use it?]
Depending on your PSP Model, you're going to need a specific tiff image. If you have a Phat (1000) PSP, use the tiff image supplied in the "PHAT" folder and copy it to ms0:/PSP/PHOTO. Else copy the tiff image in the "SLIM" folder to ms0:/PSP/PHOTO. After you've copied the image to your PSP, you can copy the h.bin supplied to the root of the memorystick (ms0:/). This should be sufficient for PSP to reboot into ChickHEN.
[Can it break my PSP?]
ChickHEN works differently to all previous HEN's. Instead of flashing to flash0, it resides entirely in RAM to prevent any damage to the system. Sure enough, you can run applications in HEN to flash stuff but I strongly recommend against it. ChickHEN comes with no warrenty, no guanantee and you run this software under your own responsibility. Flashing onto your PSP WILL BRICK IT!!
As stated, HEN comes with no warrenty, and this software should not be used in conjunction with homebrew which can countervent any copyright laws.
ChickHEN Homebrew Enabler (Latest version: R2)
CFWEnabler 1.0 for ChickHEN released
[ Custom Firmware EnAbler 1.0 to 5.03 ChickHEN by Xenogears & Becus25 ]
[ FOR PSP SLIM ONLY ]
"CustomFirmware Enabler 1.0" has just been released on Dark-AleX.org forum, from Xenogears and Becus25.
With this little app, you will be able to enable some of the M33 CFW functions within a PSP Slim with 5.03 Original Firmware and ChickHEN R2 or superior.
And yes, it does works with TA-088v3. With this add-on, you'll have almost a M33 CFW, but the recovery and Pops Games. And yes, you can use your backups.
But no, it doesn't works with 3k models, yet.
How to use it?
1. Download it from the above link.
2. Copy CFWEnabler folder to your ms0:/PSP/GAME/ folder.
3. Once enabled ChickHEN within Photo directory, start the app called "CFW Loader for ChickHEN". First time, it will ask you to install the CFW modules on flash0 pressing circle, and then you will have to press "X" to start the modded CFW.
As well as ChickHEN, once you do a hard reboot, this CFW will be deleted so you will have to restart the process to have it again.
The way this works is the following: ChickHEN starts -> Soft reboot loading systemctrl.prx for homebrew -> M33 modules are flashed -> henctrl.prx is initiated -> Soft reboot loading M33 modules.
This way, as nothing is overwritten, the brick chances are minimum. Enjoy, and good work, Xenogears!
Original Link
CFWEnabler1.0.zip [129.66 KiB]
br
RNC_EBM
The Following 8 Users Say Thank You to RNC_EBM For This Useful Post:
Old 05-27-2009, 02:54   #2 (permalink)
kikikokoki's Avatar
Member: 748785
Sonork: KIKO_GSM
Thanks Meter: 309
working bato boss...........
Old 05-29-2009, 15:22   #3 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
tested and working 100%
Old 05-29-2009, 15:39   #4 (permalink)
Member: 325999
Thanks Meter: 113
Thanx for info ,can upload here pls?
REGARDS
Old 05-29-2009, 16:52   #5 (permalink)
ivanrommel's Avatar
Member: 144777
Sonork: 100.111515
Thanks Meter: 100
hnd ba risky yan boss!!..... pano po pg n break ung psp?
Old 05-29-2009, 17:07   #6 (permalink)
KARIM GSM-ZONE's Avatar
Member: 74415
Sonork: gsm.zone
Thanks Meter: 339
speak english please
br
karim
Old 05-30-2009, 00:07   #7 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
CFWEnabler 2.10 released. (Re-Updated 2)
[ Custom Firmware EnAbler 2.10 to 5.03 ChickHEN by Xenogears & Becus25 ]
[ FOR PSP 200x SLIM ONLY ]
Version 2.0 of this Custom Firmware Enabler has just been released at Dark-AleX.org Forums. Changes?
Updated: Version 2.01 has been released on the same thread, as a quick bugfix to prevent errors if v1.0 was already installed on flash, adding a version detector.
Re-Updated: Version 2.02 has been released on the same thread, as a quick bugfix for flashing errors with pops.prx file when using sygcheck with the md5 check.
Re-Updated 2: Version 2.10 has been released on the same thread, as a quick bugfix for some plugins bugs as well some improvements.
* Now you can use POPS. You will need the 5.00 Original Firmware and the latest PSARdumper for getting the needed prx files. Once with the files, copy pops.prx and popsman.prx from the F0 folder that PSARdumper generated (with "X" option, not []) to ms0:/PSP/GAME/CFWEnabler/Pops, and then choose "Enable Pops Support" from the CFWEnabler. Once done, you can delete the files you have just copied.
* You can configure your Custom Firmware like if you had the original recovery mode, once loaded you will see the options.
* New GUI, MD5 checks, more security, etc.
As you can see, the readme is in spanish. However, the main changes are explained in english up here. Good work, guys!
ps. Answering some e-mails, i would just have to say that i am not involved on the development of this app, therefore neither i or AleX will contribute on it. Be patience :-) And, as the readme says, "It's not decided if a 3000 version could be done or not."
NOTE: For people who have downloaded version 2.00, 2.01, 2.02, is necessary to use version 2.10 for optimum performance.
CustomFirmware Enabler 2.10 para 5.03 ChickHen por Xenogears y Becus25. CustomFirmware Enabler 2.10 to 5.03 ChickHen by Xenogears and Becus25.
What is? What is?
A program that activates the functions of the M33 custom firmware using ChickHen. A program that activates the functions of the M33 custom firmware using ChickHen.
What do I need? What do I need?
- A PSP Slim (Slim only works with, regardless of the plate you have) - A PSP Slim (Slim only works with, regardless of the plate you have)
- Firmware version 5.03. - Firmware version 5.03.
- ChickHen R2 (minimum Beware patched versions!). - ChickHen R2 (minimum patched versions Beware!).
Changes 2.10: 2.10 Changes:
- Fixed a problem when you change settings for the plugins. - Fixed a problem when you change settings for the plugins.
- Fixed internal problems. - Fixed internal problems.
- Fixed a problem that caused a crasheo accessing plugins and have no plugin. - Fixed a problem that caused a crasheo accessing plugins and have no plugin.
- Improved detection of release. - Improved detection of release.
Changes 2.02: 2.02 Changes:
- Fixed a bug in the installation of the Pops (The PRX MD5 is different in each PSP, which is why the test works, but not in the other consoles) - Fixed a bug in the installation of the Pops (The PRX MD5 is different in each PSP, which is why the test works, but not in the other consoles)
Changes 2.01: 2.01 Changes:
- Fixed a bug not detect either a previous installation (caused that could not be installed above the new version) - Fixed a bug either not detect a previous installation (cause that could not be installed above the new version)
Changes 2.00: 2.00 Changes:
- System pops native activation. - System pops native activation.
- System configuration Custom Firmware. - System configuration Custom Firmware.
- Verification MD5 of files that are installed in flash, if you have not installed either, re-install. - Verification MD5 of files that are installed in flash, if you have not installed either, re-install.
- Nice interface. - Nice interface.
- Safety flasheos unnecessary. - Safety flasheos unnecessary.
- Protection from ChickHen load the Custom Firmware. - Protection from ChickHen load the Custom Firmware.
(It is necessary that this ChickHen in a folder called "ChickHEN inside Photo or Pictures.) (It is necessary that this ChickHen in a folder called" Photo ChickHEN inside or Pictures.)
- Changed version of the system (now shows 5.03 M33) - Changed version of the system (now shows 5.03 M33)
Installation: Installation:
- Copy the folder to your psp CFWEnabler in X: / PSP / GAME / - Copy the folder to your psp CFWEnabler in X: / PSP / GAME /
To be asaí: X: / PSP / GAME / CFWEnabler / EBOOT.PBP To be asaí: X: / PSP / GAME / CFWEnabler / EBOOT.PBP
IMPORTANT: Do not change the folder name CFWEnabler! IMPORTANT: Do not change the folder name CFWEnabler!
How to use: How to use:
Starts ChickHen from the picture section. Starts ChickHen from the picture section. Then start the homebrew called "CFWLoader 2.00. Then start the homebrew called "CFWLoader 2.00.
Follow the instructions that tells you the program. Follow the instructions that tells you the program.
FAQ: FAQ:
- Can load isos? - Yes, yes you can. - Yes, yes you can.
- Do you like my PSP Slim is ****ing plate? - Do you like my PSP Slim is ****ing plate? - Yes, it does not matter. - Yes, it does not matter.
- Does my PSP3000? - Does my PSP3000? - No, it does not work. - No, it does not work.
- Are you going to get a version for PSP3000? - Are you going to get a version for PSP3000? - It is not known. - It is not known.
- Sure you do not know? - Sure you do not know? - Yeah, sure. - Yeah, sure.
- Really? - Really? - Yes - Yes
- Really good for? - Really good for? - ¬ ¬ - ¬ ¬
- Can you break my console? - Can you break my console? - This version has several checks to verify that everything is installed, it is 99.99% safe - This version has several checks to verify that everything is installed, it is 99.99% safe
- When you turn off the console I have to repeat the procedure? - When you turn off the console I have to repeat the procedure? - Yes, you have to repeat it, but after the first time, no longer flashea anything. - Yes, you have to repeat it, but after the first time, no longer flashea anything.
- And you can not prevent either procedure? - And you can not prevent either procedure? - Could be avoided if we could do an IPL compatible. - Could be avoided if we could do an IPL compatible.
- Is expected to be in the future rectify the current problems? - Is expected to be in the future rectify the current problems? - It is possible, but is not guaranteed anything. - It is possible, but is not guaranteed anything.
- Does the M33 SDK? - Does the M33 SDK? - Yes, it works. - Yes, it works.
- Are the plugins? - Are the plugins? - Yes, they work. - Yes, they work.
Common Errors: Common Errors:
- When you start the program automatically goes to the menu - - When you start the program automatically goes to the menu --
Was unable to assign the flash, make sure you have a PSP Slim (2000), and if you go, make sure your version is correct ChickHen. Was unable to assign the flash, make sure you have a PSP Slim (2000), and if you go, make sure your version is correct ChickHen.
- I do not run the isos - - I do not run the isos --
Make sure that your configuration is correct. Make sure that your configuration is correct.
- I created a folder called SVCPlayer Why? - I created a folder called SVCPlayer Why? - --
You have a plugin that creates nothing to do with CFWEnabler. You have a plugin that creates nothing to do with CFWEnabler.
- Other errors is important to check the plugins that are loaded can cause problems. - Other errors is important to check the plugins that are loaded can cause problems.
Activate Pops: Pops Activate:
To enable compatibility with Native Pops, it is necessary to remove some modules of the firmware 5.00 official. To enable compatibility with Native Pops, it is necessary to remove some modules of the firmware 5.00 official.
- Required - - Required --
- A PSP that enables homebrew loading (PSP 2000 worth CFWEnabler or Hen) - A PSP that enables homebrew loading (or PSP 2000 with voucher CFWEnabler Hen)
- The 5.00 update from Sony. - The 5.00 update from Sony. ( http://rapidshare.com/files/154173870/500.PBP )
- PsarDumper with support for 5.00. - ( http://rapidshare.com/files/16539093...0_3000_too.zip )
1.-The PsarDumper copy of our report. 1.-The PsarDumper copy of our report.
2.-copy the firmware 5.00 to the root of the PSP under the name "EBOOT.PBP" 2.-copy the firmware 5.00 to the root of the PSP under the name "EBOOT.PBP"
3.-execute the PsarDumper. 3.-execute the PsarDumper.
4.-click on "X" and waited. 4.-click on "X" and waited.
5.-When finished, enter usb from pc and have a root folder called F0. 5.-When finished, enter usb from pc and have a root folder called F0.
6.-looking pops.prx files in the folder and popsman.prx kd (in F0) 6.-looking pops.prx files in the folder and popsman.prx kd (in F0)
7.-The Copy To Folder Pops within CFWEnabler (X: / PSP / GAME / CFWEnabler / Pops) 7.-The Copy To Folder Pops within CFWEnabler (X: / PSP / GAME / CFWEnabler / Pops)
8.-Run the CFWEnabler. 8.-Run the CFWEnabler.
9.-click on the option "Enable Support Pops." 9.-click on the option "Enable Support Pops."
10.-We followed the instructions. 10.-We followed the instructions.
11 .- Done, and you can delete the files from the Memory Stick Pops, both the EBOOT.PBP and the F0 folder as the files in the folder CFWEnabler / Pops. 11 .- Done, and you can delete the files from the Memory Stick Pops, both the EBOOT.PBP and the F0 folder as the files in the folder CFWEnabler / Pops.
Warning: Using the Firmware M33 can be accessed freely by the USB Flash0 care because you can cause a brick, you are advised not to change anything to the internal memory. Warning: Using the Firmware M33 can be accessed freely by the USB Flash0 care because you can cause a brick, you are advised not to change anything to the internal memory.
Acknowledgments: Acknowledgments:
- A Dark_AleX for the M33 modules. - A Dark_AleX for the M33 modules.
- Especially him, who knows who he is, and that is part of the credit for helping him. - Especially him, who knows who he is, and that is part of the credit for helping him.
Un Saludo. Un Saludo.
Mirror: http://rapidshare.com/files/238471979/CFWEnabler210.zip
CFWEnabler 2.10 (Only for PSP SLIM 2000)
br
RNC_EBM
The Following User Says Thank You to RNC_EBM For This Useful Post:
Old 05-30-2009, 00:23   #8 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
100% TRIED, TESTED & PROVEN
Read Carefuly WHAT IS WRITTEN.
NEXT TIME SPEAK IN ENGLISH.
br
RNC_EBM
Old 06-02-2009, 00:33   #9 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
CFWEnabler 2.50 (PSP SLIM 2000)
CustomFirmware Enabler 2.50 to 5.03 ChickHen by Xenogears and Becus25.
What is?
- A program that activates the functions of the M33 custom firmware using ChickHen.
What do I need?
- A PSP (Model 2000)
- ChickHen R2 (at least, look out with the patched versions may cause errors!).
2.50 Changes:
- Fixed bug that prevented version and patching of the hen to leave a game.
- Improved system pops, now you can install a flash version (whatever that is 5.00)
- Fixed a bug that prevented either activate the plugins.
- Improved detection system version, you can install over previous versions (not recommended).
- Improved detection system model, no longer crashes with modified versions of the hen (original versions are recommended to avoid problems.)
- Fixed a bug that crashed into the setup menu randomly.
- Improved the patching system ChickHEN.
- It is not necessary that the folder is called CFWEnabler.
2.10 Changes:
2.02 Changes:
- Fixed a bug in the installation of the Pops (The PRX MD5 is different on each console, so the test worked, but then not)
2.01 Changes:
2.00 Changes:
- Nice interface.
Installation:
Example X: / PSP / GAME / CFWEnabler / EBOOT.PBP
How to use:
Starts ChickHen from the picture section. Then start the homebrew called "CFWLoader 2.50.
FAQ:
- Can load isos? - Yes, yes, you can.
- Really? - Yes
Common Errors:
It has not been able to reallocate the flash, make sure your version is correct ChickHen and you do not have a PSP 3000.
- I created a folder called SVCPlayer Why? --
- Other errors is important to check the plugins that are loaded can cause problems. Also, check your version of ChickHen is correct, but may fail.
Activate Pops:
To enable compatibility with Native Pops, it is necessary to remove some modules of an Official Firmware.
In this version you can flash any version of the Pops, but only 5.00 is recommended, other versions have not been tested.
- Required --
- A PSP that enables homebrew loading.
- An update Sony.
- PsarDumper. (http://rapidshare.com/files/165390935/p ... 00_too.zip)
2.-copy the firmware to the root of the PSP under the name "EBOOT.PBP"
9.-click on the option "Flash Modules Pops."
11.-Done, and you can delete the files from the Memory Stick Pops, both the EBOOT.PBP and the F0 folder as the files in the folder within CFWEnabler Pops.
Acknowledgments:
Mirror: http://rapidshare.com/files/23977640...er250.zip.html
br
RNC_EBM
Old 06-03-2009, 23:17   #10 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
CFWEnabler 2.51 (PSP SLIM 2000)
CustomFirmware Enabler 2.51 to 5.03 ChickHen by Xenogears and Becus25.
What is?
What do I need?
2.51 Changes:
- Fixed bug that prevented either activate the plugins.
2.50 Changes:
2.10 Changes:
2.02 Changes:
2.01 Changes:
2.00 Changes:
- Nice interface.
Installation:
How to use:
Starts ChickHen from the picture section. Then start the homebrew called "CFWLoader 2.51.
FAQ:
- Really? - Yes
- Do I have to reflashear the modules in this version? - If it is necessary to rewrite the program will tell you.
Common Errors:
Activate Pops:
- Required --
- An update Sony.
Acknowledgments:
Mirror: http://rapidshare.com/files/240517003/CFWEnabler251.zip
br
RNC_EBM
Old 06-07-2009, 22:14   #11 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
CFWEnabler 3.00 (PSP SLIM 2000 & PSP 3000)
CustomFirmware Enabler 3.00 to 5.03 ChickHen by Xenogears and Becus25.
What is?
What do I need?
- A PSP (Model 2000 or 3000)
3.00 Changes:
- Added support for PSP 3000.
- Improvements in GUI.
- Added update system over the Internet (Wanted host).
- Added system to block the official updates.
- Added new configuration options
- Free UMD Region.
- CFWEnabler Online Update.
- Hide Pic0.png & Pic1.png.
- Use version.txt.
- Fixed a problem that crashed into the console when plugin is not detected.
- Added registry Hacks (Change buttons, Enable WMA, Enable Flash Player)
- Added a menu to set the version.txt.
- Added a menu to set the speed of the CPU (VSH and Games).
2.51 Changes:
2.50 Changes:
- Improved the patching ChickHEN system, you no longer need this in a folder called "ChickHEN.
2.10 Changes:
2.02 Changes:
2.01 Changes:
2.00 Changes:
- Nice interface.
Installation:
How to use:
Starts ChickHen from the picture section. Then start the homebrew called "CFWLoader 3.00.
Internet Update:
Time of this release, this option is disabled by lack of a server.
If you have a server and are interested in helping, please contact [email protected]
FAQ:
- Can I install LEDA? - Yes, it works perfectly.
Common Errors:
It has not been able to reallocate the flash, make sure your version is correct ChickHen.
You have a plugin that creates the so-called "capture" nothing to do with CFWEnabler.
Activate Pops:
- Required --
- An update Sony.
Acknowledgments:
- A GENyUS for his A-GEN
Mirror: http://rapidshare.com/files/241976509/CFWEnabler300.zip
br
RNC_EBM
Old 06-07-2009, 23:49   #12 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
CFWEnabler 3.01 (PSP SLIM 2000 & PSP 3000)
CustomFirmware Enabler 3.01 to 5.03 ChickHen by Xenogears and Becus25.
What is?
What do I need?
3.01 Changes:
- Fixed a bug that prevented loading plugins VSH.
3.00 Changes:
- Free UMD Region.
- Use version.txt.
2.51 Changes:
2.50 Changes:
2.10 Changes:
2.02 Changes:
2.01 Changes:
2.00 Changes:
- Nice interface.
Installation:
How to use:
Starts ChickHen from the picture section. Then start the homebrew called "CFWLoader 3.01.
Internet Update:
FAQ:
Common Errors:
Activate Pops:
- Required --
- An update Sony.
Acknowledgments:
Mirror: http://rapidshare.com/files/242029189/CFWEnabler301.zip
br
RNC_EBM
Old 06-08-2009, 02:45   #13 (permalink)
Member: 130895
Thanks Meter: 3
thank you... 100% TRIED, TESTED & PROVEN
Old 06-11-2009, 00:12   #14 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
CFWEnabler 3.10 (PSP SLIM 2000 & PSP 3000)
CustomFirmware Enabler 3.10 to 5.03 ChickHen by Xenogears and Becus25.
[email protected]
What is?
What do I need?
Spoiler: Show
3.10 Changes:
- Improved system flasheo is now much safer.
- Improved uninstalling system, it is now much safer.
- Added Spanish language.
- Added Internet Update.
- Improved startup (now a little faster)
- The Eboot.pbp now occupies less.
3.01 Changes:
3.00 Changes:
- Free UMD Region.
- Use version.txt.
2.51 Changes:
2.50 Changes:
2.10 Changes:
2.02 Changes:
2.01 Changes:
2.00 Changes:
- Nice interface.
Installation:
How to use:
Starts ChickHen from the picture section. Then start the homebrew called "CFWLoader 3.10.
FAQ:
Common Errors:
Activate Pops:
- Required --
- An update Sony.
Acknowledgments:
- A PSPStation.org for letting your server.
Mirror 1 : http://cfwenabler.pspstation.org/fil...Enabler310.zip
Mirror 2 : http://rapidshare.com/files/243002870/CFWEnabler310.zip
br
RNC_EBM
Old 06-11-2009, 01:11   #15 (permalink)
ashlocked's Avatar
Member: 715333
Thanks Meter: 19
latest update means it simplifies the procedure....hope there will be more easier and stable someday...tnx
Component AV Cable for PSP GO (SY-PSP-A08) IPMART ipmart WebShop 0 12-31-2009 07:10
Compatible 17 In 1 Starter Kit for PSP/PSP Slim (DGPSPS-1806) IPMART ipmart WebShop 0 06-17-2009 13:10
Page generated in 0.40813 seconds with 9 queries
