Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc |
11-26-2010, 17:45 | #61 (permalink) |
Junior Member Join Date: Nov 2010
Member: 1452691 Status: Offline Thanks Meter: 0 | Find possible fix SO..... after reading thru this thread i had came up with something..... warning though, i am not a technician or technically an expert on this matter, and carefully read the problems i stated above for it may not work on different situations..... what i did was openned apart my sisters psp, pls read guides on how to dismantle or take apart a psp and take special care when un plugging the lcd cables/ribbons please BE SURE THAT THE BATTERY IS OUT OR ANY POWER INPUT IS OUT before proceeding otherwise you'll electronically mess the backlight circuit (if it happens, you need to bypass/jumper the backlight fuse). after removing the lcd remove the lcd metal holder too so the main motherboard appears then remove the motherboard too... then put a folded square centimeter or less piece of paper or cardboard just above the area where the umd black or gray switch should be popping tape in on the metal umd framing to cover the hole where that switch from the board is about to pop, then place back the board make sure that the switch is over that piece of paper... put all together back and ensure contacts, except for the 2 ribbons from the umd, the orange from the lens reader and the green from the rotator so totally the umd is disabled.... put all together and see if it works... may be possible to skip the putting of paper but i did it only once just to make sure so i did not test it without the paper... im too lazy but hope i can help XD |
01-13-2011, 20:27 | #62 (permalink) |
Junior Member Join Date: Jan 2011
Member: 1492566 Status: Offline Thanks Meter: 0 | Man, can you believe this. I am having the exact same problem of the PSP freezing at the load screen and I came upon this thread. Went to the load screen again where it hangs, then I gave my PSP a twist as someone here suggested and would you believe it? - There it goes past the hanging phase! Unbelievably weird!!! It just doesn't feel right having to twist the thing, is there a more elegant and permanent solution to this problem? |
02-13-2011, 19:02 | #63 (permalink) | |
Freak Poster Join Date: Aug 2006 Location: Greatwall Center™ Age: 43
Member: 325816 Status: Offline Thanks Meter: 31 | Quote:
10-25-2013, 20:41 | #65 (permalink) | |
Junior Member Join Date: Sep 2007
Member: 593857 Status: Offline Thanks Meter: 0 | Quote:
10-26-2013, 04:22 | #67 (permalink) |
Member: 593857 Status: Offline Thanks Meter: 0 | Here again to tell that i was able to update my PSP using this metode, now on 5.5 Gen D3 im able to play all games, the only problem is i need to press the ¨grey stick¨ to make the PSP read the MS card, i dont know what is this, if the game are playing so its not a motherboard problem, maybe a UMD reader problem? Well i think this will be one of the mysteries of PSP. Thanks for all help from this thread, sorry for my BAD english. |
07-26-2014, 03:03 | #71 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | Fixed 1 or 2 I had by heating the chip Others died while heating .... Maybe to heat.... But this days no more psp to fix.... Ppl buy the new street model it's cheaper then fixing |
The Following User Says Thank You to TRABEL For This Useful Post: |
07-26-2014, 15:19 | #72 (permalink) |
Member: 593857 Status: Offline Thanks Meter: 0 | I tried to heat the chip but no deal, i almost toasted this thing and dont worked, so i put a piece of plastic pressing the chip, now if i press the psp its boot the game... Well ill never understand how can this influence the game boot. |
samsung x210 freezes at the start screen | GSMELECTRO | Samsung Hardware Repair | 7 | 04-17-2011 16:07 |
p800 freezes at the startup screen | chuoi | Sony Ericsson | 5 | 06-27-2009 15:08 |
K800 Freeze At Sony Ericsson Screen Please Help | TAZMAN | Sony Ericsson | 1 | 08-17-2007 20:45 |
SHARP GX25 freez at Vodafone screen ,but | gsmfriend | Sharp | 5 | 11-06-2006 06:17 |
V800.....freeze at startup with Vodafone logo on the screen...need help... | plruzza | Sony Ericsson | 3 | 02-07-2006 13:14 |
