Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc |
01-01-2009, 20:40 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: on the Moon ;) Age: 47
Member: 21937 Status: Offline Thanks Meter: 279 | psp freezing at psp loading screen ?? i got a psp slim in here , got it freezing while loading any game . i reflashed it with latest 5.00m33 , still while loading iso game psp freezing on the psp white loading screen , every time . it also freez while exiting from recovery/settings menu of the m33. any ideas what and how to fix ? thx psp was working before and from what i asked my friend , it didnt fall or got any damge. thx |
01-01-2009, 23:02 | #2 (permalink) | |
No Life Poster Join Date: Dec 2004 Location: PHILIPPINES
Member: 101860 Status: Offline Sonork: 100.1582168 100.77603 Thanks Meter: 6,036 | Quote:
br RNC_EBM | |
The Following User Says Thank You to RNC_EBM For This Useful Post: |
01-02-2009, 09:29 | #3 (permalink) | |
Member: 21937 Status: Offline Thanks Meter: 279 | Quote: i also played with speeds a little bit , same results , psp also freezing while exiting recovery menu ( all the time) btw , i just notice , psp drive is not working , i will open it now , maybe something lose there . Last edited by TRABEL; 01-02-2009 at 09:35. | |
01-02-2009, 11:45 | #4 (permalink) | |
br RNC_EBM | |
01-02-2009, 12:21 | #7 (permalink) |
Member: 21937 Status: Offline Thanks Meter: 279 | well , this 8gig card looks original , thought i have tested with different card and same problem , also , tested with only umd , and no memory card , psp freez when loading umd on white screen , if i take umd out psp still froze , if i put umd from psp screen its not spining and not see any umd |
01-02-2009, 12:29 | #8 (permalink) | |
i think your umd drive has problem. br RNC_EBM | |
01-02-2009, 12:59 | #10 (permalink) | |
if yes - DISAble it & REStart. if NOT - Maybe your PSP has PROBLEM (HARDWARE) br RNC_EBM | |
01-08-2009, 11:34 | #12 (permalink) |
Junior Member Join Date: Jan 2009
Member: 939217 Status: Offline Thanks Meter: 18 | try formatting your flash1 folder. enter recovery menu, scroll down to advance and press enter. then scroll down to "format flash1 folder" and press enter (don't panic, this will not brick your psp). the psp will then reset itself and you will need to re-enter the time, date etc. to check to see if you have a fake mem card, (with the mem card in the psp) highlight the "memory card" icon in the "game" icon on the psp's xmb (main screen) and press triangle. then select "information". a small list will appear with your mem cards details. look down to where it says "Magicgate". if it reads "supported" next to it, then you have an original mem card. but if it reads "unknown", then you have a fake. did you format your mem card after you install v5.00m33? if not, copy all your game saves and anything you wish to keep and format the mem card using the psp's format utility (found in the "System Settings" icon). replace the game/s and try again. have you enabled the "use no umd" option? you can do this by pressing "select" in the xmb, and the vsh menu will appear. scroll down to "umd iso mode" and press left or right on your d pad until it reads either "m33 driver" or "sony NP9660". then exit the vsh menu and try again. also im not sure if your aware, but there is a new version of v5.00m33 available. if all of the above doesn't work, then you could try and update to v5.00m33-4. that might fix your problem. |
01-08-2009, 22:08 | #13 (permalink) | |
but psp brought to me by a friend with this problem , psp was at 3.71m33 , same state , freezing when runing a game , from memory stick or from original UMD. first thing i did was upgrading to 5m33.... and format the memory stick .. thought problem is the same. psp also freezing when exiting recovery mode. also tested with other memory stick. also tested with no memory stick at all and original umd. i think i have formated flash1 but not sure , i will test this again. i did uses idstorge recovery same problem. | |
01-08-2009, 22:14 | #14 (permalink) |
Member: 939217 Status: Offline Thanks Meter: 18 | if it still doesn't work, you could always try and use a pandora's battery again to reinstall the custom firmware. there is a new version of DC available. and it will install v5.00m33-4. and you can reset your idstorage keys in on dcv8. |
01-08-2009, 22:18 | #15 (permalink) | |
all i did was from a pandora battery latest v5.00m33-4 and resey idstorage from dcv8 | |
The Following User Says Thank You to TRABEL For This Useful Post: |
samsung x210 freezes at the start screen | GSMELECTRO | Samsung Hardware Repair | 7 | 04-17-2011 16:07 |
p800 freezes at the startup screen | chuoi | Sony Ericsson | 5 | 06-27-2009 15:08 |
K800 Freeze At Sony Ericsson Screen Please Help | TAZMAN | Sony Ericsson | 1 | 08-17-2007 20:45 |
SHARP GX25 freez at Vodafone screen ,but | gsmfriend | Sharp | 5 | 11-06-2006 06:17 |
V800.....freeze at startup with Vodafone logo on the screen...need help... | plruzza | Sony Ericsson | 3 | 02-07-2006 13:14 |
