Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 07-27-2008, 13:23   #1 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
>>> PSP: IdStorage keys and their uses + regeneration <<<
Info below compiled from various sources, including: adrahil, Chilly Willy, FreePlay, harleyg, jas0nuk, l_oliveira, Mathieulh, Saben, SilverSpring, Squirrel, vb_master
The following keys are backed up separately from the IdStorage, non-indexed: 4, 5, 6, F, 30-3F, 40-46, 50, 140
NOTE: Slim v1 = TA-085 baryon 22B200, Slim v1.1 = TA-085 baryon 234000, Slim v2 = TA-088, Fat v4 = TA-086
* = key is the same per model, but not necessarily the same in every PSP
* = key is unique to each PSP
* = key is partially unique (e.g. WLAN region are all similar but with a few bytes changed for different regions)
General info on each key
* 0x4 - Baryon settings/information - extra data added since Slim v1
* 0x5 - Clockgen/I2C setup commands - invalidating the first four bytes enables 1.50 to boot on TA-082+ by preventing an IPL crash due to unsupported hardware
* 0x6 - Battery, CPU frequency and general power settings - extra data added since Slim v1
* 0x7 - Unknown usage (exists since Fat v4/Slim v1) - changed in Slim v2
* 0x8 - Brightness hardware control (exists since Fat v4/Slim v1) - changed in Slim v1.1 and again in Slim v2 - if this is detected, the data in them is used to control the brightness levels. If not, the board acts as a TA-079 which causes brightness level issues with the new hardware.
* 0x10 - MagicGate
* 0x11 - MagicGate
* 0x12 - MagicGate
* 0x13 - MagicGate
* 0x40 - Contains the 0x5 bytes at 0x88 from key 0x10
All of the above are required for MagicGate to work
* 0x41 - USB (Driver type identifier) - slightly different since Slim v1
* 0x43 - USB (Device ID) - slightly different since Slim v1
* 0x44 - WLAN MAC Address (can be rebuilt using Noobz MAC Address Fixer)
* 0x45 - WLAN Region (can be rebuilt using KeyCleaner)
* 0x47 - Default parental lock level (first byte is 0x09, rest is empty)
* 0x50 - Serial number (not used since TA-082)
* 0x51 - Firmware the PSP shipped with, and unknown unique data (exists since Fat v4/Slim v1)
* 0x52 - Unused by PSP - Mostly the same per PSP except for slight variations - could be manufacturing info (exists since Slim v1)
* 0x54 - Default XMB background colour - first 3 bytes: 02 00 02 in PSP-200X IS, 02 00 00 in PSP-200X PB (exists since Slim v1)
* 0x100 - DNAS, VSH & Internet browser region, ad-hoc region (if missing, official updaters cannot run - error CTA80000025)
* 0x101 - OpenPSID (non-indexed duplicate at [location of original + 0x8000])
* 0x102 - UMD (non-indexed duplicate at [location of original + 0x8000])
* 0x103 - UMD (non-indexed duplicate at [location of original + 0x8000])
* 0x104 - UMD (non-indexed duplicate at [location of original + 0x8000])
* 0x105 - UMD (non-indexed duplicate at [location of original + 0x8000])
* 0x106 - UMD (non-indexed duplicate at [location of original + 0x8000])
102-106 is a continuous key which the UMD drive uses. Any invalid ones (missing, edited, or from another PSP) will prevent the UMD sectors being decrypted, resulting in a Disc Read Error
* 0x120-0x126 - backup of respective 0x0100-106 key
* 0x140 - Unknown unique data
More info on keys 4-8
Keys 4-8 are setup data for various devices. Their structure is as follows:
typedef struct {
        u32 signature;      // "Clkg", "Bryn", etc
        int type;           // always 00000001 so far
        int datalen;        // length of data starting at 0x10
        u32 hash;           // hash of data from 0x10 to 0x10+datalen
        u8 databuf[0x1F0];  // data used for hardware init/control
} SceIdStorageLeaf;
Since official updater 3.30, every updater has a hidden module called sceChkDegeneration which checks the signatures of these keys and produces an error if the signature is incorrect:
DRNFFFFFFD8 = key 0x4 missing
DRNFFFFFFD7 = key 0x4 header is not "n y r B" (in hex: 6E 79 72 42)
DRNFFFFFFCE = key 0x5 missing
DRNFFFFFFCD = key 0x5 header is not "g k l C" (in hex: 67 6B 6C 43)
DRNFFFFFFC4 = key 0x6 missing
DRNFFFFFFC3 = key 0x6 header is not "r d D M" (in hex: 72 64 44 4D)
Additional checks in TA-086:
DRNFFFFFFB9 = key 0x7 header is not "D a P A" (in hex: 44 61 50 41)
DRNFFFFFFB0 = key 0x8 missing
DRNFFFFFFAF = key 0x8 header is not "p D C L" (in hex: 70 44 43 4C) - for this error, creating a fake key 8 is not enough as this will result in the brightness not working at all, a real key must be used.
KIRK commands
IdStorage keys are created by one of the KIRK commands, so we need to get as much information as we can about KIRK (aka semaphore hardware decryption)
0x01 - PRX decryption
0x02 - ???
0x03 - ???
0x04 - Scramble, savedata (chnnlsv) [paired with 0x7]
0x05 - Unsigcheck, savedata (chnnlsv) [paired with 0x8]
0x06 - ??? [paired with 0x9]
0x07 - Descramble [paired with 0x4]
0x08 - Sigcheck, savedata (chnnlsv) [paired with 0x5]
0x09 - ??? [paired with 0x6]
0x0A - ???
0x0B - SHA-1
0x0C - ??? (memab)
0x0D - ??? (memab)
0x0E - savedata (chnnlsv), memab, semawm, DbsvrGetData
0x0F - ???
0x10 - ??? (memab)
0x11 - ??? (memab)
0x12 - IdStorage checks
GetPsCode (0x100 region key) return codes
List compiled by harleyg/Slash
Region code is returned from sceChkregGetPsCode, in the format 01 00 XX 00 01
Model         Country                Region   GetPsCode  Comments
PSP-1000      Japan                  2        0x03       Standard Pack
PSP-1000CW    Japan                  2        0x03       White Giga Pack
PSP-1000K     Japan                  2        0x03       Value Pack
PSP-1000KCW   Japan                  2        0x03       White Value Pack
PSP-1000G1    Japan                  2        0x03       Giga Pack
PSP-1000G1CW  Japan                  2        0x03       White Giga Pack
PSP-1001K     North America          1        0x04       Value Pack
PSP-1001G1    North America          1        0x04       Giga Pack
PSP-1002K     Australia/New Zealand  4        0x09       Value Pack
PSP-1002G1    Australia/New Zealand  4        0x09       Giga Pack
PSP-1003K     UK                     2        0x05       Value Pack
PSP-1003G1    UK                     2        0x05       Giga Pack
PSP-1004K     Europe                 2        0x05       Value Pack
PSP-1004G1    Europe                 2        0x05       Giga Pack
PSP-1005K     Korea                  5        0x06       Value Pack
PSP-1005G1    Korea                  5        0x06       Giga Pack
PSP-1006CW    Hong Kong/Singapore    5        0x0A       White Giga Pack
PSP-1006K     Hong Kong/Singapore    3        0x0A       Value Pack
PSP-1006G1    Hong Kong/Singapore    3        0x0A       Giga Pack
PSP-1007K     Taiwan                 3        0x0B       Value Pack
PSP-1007G1    Taiwan                 3        0x0B       Giga Pack
PSP-1008K     Russia                 5        0x0C       Value Pack
PSP-1008G1    Russia                 5        0x0C       Giga Pack
PSP-1009K     China                  6        0x0D       Value Pack
PSP-1009G1    China                  6        0x0D       Giga Pack
br
RNC_EBM
>>> PSP: RainMotorsports - Simple MMS Maker UPDATE HERE <<< RNC_EBM Game Consoles & Mp3/4 , HD players 2 11-05-2010 19:57
>>> PSP: TORCH - Lockdown XMB Style UPDATE HERE <<< RNC_EBM Game Consoles & Mp3/4 , HD players 0 11-16-2008 23:51
>>> PSP: PSP4noobz - Ultra Pandoras Tool UPDATE HERE <<< RNC_EBM Game Consoles & Mp3/4 , HD players 0 10-20-2008 22:44
>>> PSP: GAMES - Recent and Upcoming Releases <<< RNC_EBM Game Consoles & Mp3/4 , HD players 0 10-04-2008 00:34
>>> PSP: Red Squirrel - Alternative VSHMenu UPDATE HERE <<< RNC_EBM Game Consoles & Mp3/4 , HD players 1 09-21-2008 12:33
Page generated in 0.17617 seconds with 9 queries
