Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 03-09-2009, 12:23   #1 (permalink)
The Repair Shop's Avatar
Member: 307549
Thanks Meter: 187
PSP Slim dead after pandora battery?
I have just whent to install Pandora in new slim psp, i have dont many before but this one has gone fuuny. after i inserted the battery in the psp nothing happened and now the psp does not work. only the green light comes on and that's it?
Old 03-09-2009, 14:14   #2 (permalink)
.:Tanveer.:'s Avatar
Member: 195957
Thanks Meter: 53
First thing we will do is create the Mem Stick:
than create manualy new pandora batt and reinstall files from mem stick. ur psp will alive again.
I have only found 2 Batteries this works on they are as follows:
PSP-110 (1800mAH) # down on bottom right of sticker: 2-581-225-03
PSP-280 (2200mAh) # down on bottom right of sticker: 2-637-269-11
Step 1:
Take your spare battery, and open it up. BECAREFULL NOT TO PUSH A KNIFE TO FAR INTO BATTERY CASE YOU MIGHT PUNCTURE THE BATTERY CELL!
Step 2:
Once you have it apart, look at the circuit board, and find the word “IC04”, you should see a little micro-controller right next to it. On that micro-controller it will have 8 pins. It will be the pin on the bottom right. Here is a pic of what it should look like. (I got the 1st PIC from the web, it is not my pic, my camera didn't want to work so thanks to whoever took the pic.) 2nd pic, I took.
Step 3:
Tape your battery down to your work area so it doesn’t move, then tape the circuit board to cover all the areas around the micro-controller. Doing this will help prevent any accidental shorting of the battery if you accidentally touch the needle to something else while touching the controller.
Step 4:
Now take your sewing needle and slide it under pin 5, then gently pull up and outward to the right. (you might have to repeat this step a few times to weaken the pin.) It will break free from the circuit board. *NOTE - ensure the tip of needle is not touching pin 6, it will short the battery!
Step 5:
Now un-tape everything, and put the battery back together. You can use very small amount of super glue or, just tape the battery together. *Caution when tapeing, it will create a very tight fit into the PSP Battery Compartment, and you will have to really push it in all the way to make the Battery connect to the receptors on the PSP!)
Step 6:
That’s it, your done! You now have a service battery.
*NOTE – To use these on a PSP, you must first insert the Mem Stick, then the Battery! Then simply follow the on screen instructions, enjoy CFW!
Old 03-09-2009, 15:22   #3 (permalink)
Member: 307549
Thanks Meter: 187
mate thanks for trying to help here but i have all ready got a pandora battery and memory stick.
Old 08-18-2010, 07:11   #4 (permalink)
Member: 1358599
Thanks Meter: 4
Thank you for this wonderful service of connecting us to so many devotees from across the world.
000-669 // 000-966 // 000-973 // 117-101 //
Old 08-18-2010, 07:13   #5 (permalink)
alexlaboratory's Avatar
Member: 771230
Thanks Meter: 773
what model is your psp?? 1000 or 2000 series??
if 3000 series pandora doesn't work and you bricked your psp
X100 when dead after removing battery bassboli Samsung Hardware Repair 1 01-18-2009 10:33
Nokia 6100 dead after change battery connector mm-gsm Nokia Hardware & Hardware Repair 1 09-05-2006 09:59
need help :gd67 dead after remouving battery tazmaniadevil Panasonic 0 04-04-2004 19:19
SL45 dead after off battery. Magic_GSM x1x to x45/x50 0 04-14-2002 20:44
Alc OT Club DB Dead after taking battery off when power-on...>>PLS HELP>>> jsp_m Alcatel & TCL Old Models 19 09-18-2001 22:07
Page generated in 0.23906 seconds with 8 queries
