Go Back   GSM-Forum > Non GSM/Mobile Related Forums > Game Consoles & Mp3/4 , HD players
Game Consoles & Mp3/4 , HD players Repairing and servicing Mp4, Mp3 devices, HD players.. you may also find here any threads related to Game Consoles devices like Wii, PlayStation, Xbox, Nintendo .. etc
Old 08-07-2008, 10:51   #1 (permalink)
RNC_EBM's Avatar
Member: 101860
Sonork: 100.1582168 100.77603
Thanks Meter: 6,036
■Θ■ PSP: Universal Unbricker To Unbrick/Downgrade/ Restore Any PSP To 4.01m33-2 ■Θ■
This tutorial will guide you through the process of creating a "Pandora's Battery" and a "magic memory stick," which when used in conjunction can unbrick, restore, and downgrade any PSP firmware. Apart from TA-088 v3 units, the process works on all previous "Phat" and Slim PSP hardware revisions to date.
Requirements
* A working, homebrew-capable PSP running at least 3.X OE / M33
* Memory Stick Pro Duo with at least 128MB of space
* PSP Battery
Known compatible batteries:
* Sony PSP 1800mAh Battery Pack
* Datel PSP Battery 3600mAh 2X
* Datel PSP Battery 1800 MaxPower
* Sony PSP-280 2200mAh
* Atomic Battery Pack 3.6v 1800 mAh
Installation: Creating the Magic Memory Stick
1. First boot up the PSP into recovery mode (hold R during boot) and make sure the GAME folder homebrew setting is set to 3.X Kernel. Exit recovery mode.
2. Insert the memory stick into the PSP.
3. Navigate to System Settings -> Format Memory Stick on your PSP. Format the memory stick.
4. Connect your PSP in USB mode.
5. Download Hellcat's Pandora Installer for 3.XX Rev 3b
6. Extact the Pandora Installer using WinRAR or any similar utility. Inside, look for a "pan3xx" folder. Copy this folder to "X:/PSP/GAME" on the memory stick.
7. Exit USB mode. Now navigate to the Game menu on your PSP and execute Hellcat's Pandora Installer.
8. Once successfully loaded, you should see a screen similar to the one pictured below.
9. Warning: this will delete all data from the memory stick. Backup any files before proceeding. Press R+X, and confirm with R+L+X to repartition and format the memory stick for Pandora.
10. Restart the PSP and connect it in USB mode once again.
11. All folders and files from your memory stick should be wiped, so create a "PSP" folder and then create a "GAME" folder inside of the "PSP" folder.
12. Once again, copy the "pan3xx" folder to "X:/PSP/GAME" on the memory stick.
13. Download the 1.50 update and save it as "UPDATE.PBP" without the quotes.
14. Copy the 1.50 update to the root of your memory stick (X:\UPDATE.PBP, if X is the drive letter of your PSP).
15. Exit USB mode. Now navigate to the Game menu on your PSP and execute Hellcat's Pandora Installer.
16. Press X to install a 1.50 firmware, containing Pandora, to the memory stick.
17. When the process is finished, press L+X to install the IPL. Now exit the application.
18. Connect the PSP in USB mode.
19. Download Time Machine 0.1
20. Extract the RAR using WinRAR or similar utility. Inside, you should see a "TIMEMACHINE" folder. Copy this to "X:/PSP/GAME" on the memory stick.
21. Exit USB mode. Now navigate to the Game menu on PSP and execute the application "Time Machine"
22. You should now be presented with the following screen:
From here, first choose "Install IPL loader on PSP MS boot sector," then select "Convert Pandora/DC1-DC4 IPL into TM format." Now exit the application.
23. Connect the PSP in USB mode.
24. Download Despertar del Cementerio v6
25. Extract the ZIP using WinRAR or similar utility. Inside, you should see a "DC6" folder. Copy this folder to "X:/PSP/GAME" on the memory stick.
26. Download the 4.01 update EBOOT file.
Once finished downloading, the file should already be named as 401.PBP.
If the file name matches, then copy it to the memory stick root (i.e. X:/, if X is the drive letter of your PSP).
27. Exit USB mode. Now navigate to the Game menu on PSP and execute the application "Despertar del Cementerio v6"
28. While installing, the application will ask you which key(s) you would like to bind DC to. Hold UP on the directional pad.
29. After installing the files, the program should exit back to the XMB. That means installation was successful and you are now in possession of a "magic memory stick."
Installation: Converting a Battery to Pandora
Note: If you have just followed the steps above to create a magic memory stick, steps 1 and 2 below can be safely ignored.
1. Download Hellcat's Pandora Installer for 3.XX Rev 3b
2. Extract the Pandora Installer using WinRAR or any similar utility. Inside, look for a "pan3xx" folder. Copy this folder to "X:/PSP/GAME" on the memory stick. Exit USB mode.
3. Navigate to the Game menu on your PSP and execute Hellcat's Pandora Installer.
4. Upon launching the application, take note of these four options:
  • Press O to convert battery to Pandora
  • Press [] to convert battery to normal
  • Press R+O to write battery serial to file
  • Press R+[] to restore battery serial
First, you will want to press R+O to backup your battery serial. If for any reason you'd like to convert your battery back to normal in the future, press R+[] to restore the battery serial. This is the preferred method for restoring your battery back to its previous state.
If by chance you forgot to back up the battery serial and still would like to convert your battery back to normal, choose the second option by pressing [].
Once you're ready, press O to convert your battery to Pandora.
5. You now are in possession of a Pandora Battery. Booting a PSP with this battery inserted will boot to service mode instead of the normal PSP XMB.
Usage: Unbrick / Downgrade / Restore Any PSP
Note: If you are performing the following steps on the same PSP you used to create the battery with make sure to remove and then reinsert the battery.
1. While holding UP on the directional pad, boot the PSP with a magic memory stick and the Pandora Battery inserted.
2. You will be presented with a menu containing the following options:
  • Install 4.01 M33
  • Install 4.01 OFW
  • NAND operations
  • Hardware Info
  • Test M33
  • Shutdown
  • Reboot Device
Select "Install 4.01 M33" to begin the installation process.
3. Memory stick LED should begin flashing. Wait 2-5 minutes for the install to complete.
4. Now press X to complete the installation - it's imperative that you do this.
5. Boot up the PSP with a regular non-Pandora battery. You may be presented with a BSOD, but just press X or O to restore settings.
6. And that's it. You're now running 4.01 M33-2.
br
RNC_EBM
The Following 30 Users Say Thank You to RNC_EBM For This Useful Post:
Old 08-10-2008, 12:25   #2 (permalink)
yalcin_hacker's Avatar
Member: 390241
Thanks Meter: 18
Yeah We used Pandora For A looong Time In Aus its King for unbricking and Modifiying the psp Gooood Money
Old 08-10-2008, 19:06   #3 (permalink)
Member: 369369
Thanks Meter: 15
please what kind of audeo and video format should i use for psp i have used mp3 but mine did not work all the same i found its having mp3 music it a deferent mp3 for psp?
Old 08-10-2008, 21:31   #4 (permalink)
MED9's Avatar
Member: 87853
Thanks Meter: 1,231
Cool
Great Work Freind Thn***
The Following 2 Users Say Thank You to MED9 For This Useful Post:
Old 08-26-2008, 11:16   #5 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
Despertar del Cementerio v7: IDStorage Regeneration
br
RNC_EBM
The Following User Says Thank You to RNC_EBM For This Useful Post:
Old 09-02-2008, 10:10   #6 (permalink)
korter's Avatar
Member: 171307
Thanks Meter: 140
I have PSP SLim 2008 and its battery 1200mah (model s110). My PSP version is 3.71 official. So is there any way to downgrade my PSP to 1.50, or crack it without having another PSP or pandora battery?
(I am a begginer in this processes)
The Following User Says Thank You to korter For This Useful Post:
Old 09-02-2008, 10:26   #7 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
YELLOW 1 & 3
FIRST
SECOND
NOW YOU HAVE CUSTOM FIRMWARE(CFW)
YELLOW 2
You CAN'T DOWNGRADE SLIM TO 1.50
br
RNC_EBM
The Following 3 Users Say Thank You to RNC_EBM For This Useful Post:
Old 10-04-2008, 10:06   #8 (permalink)
Member: 584832
Sonork: 100.1601217
Thanks Meter: 35
i have fat psp ofw 3.03 updated to ofw 4.05 to play new umd games. is there any chance of downgrading it to play homebrew games and is there any risk of downgrading this ofw 4.05 to any cfw version available?
br...
Old 10-17-2008, 14:53   #9 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
Dark_Alex Custom Firmware 5.00m33 RELEASED
br
RNC_EBM
Old 10-18-2008, 13:04   #10 (permalink)
Member: 796252
Thanks Meter: 30
good job.... i going try it
regards from portugal
Old 10-19-2008, 10:26   #11 (permalink)
Member: 5926
Thanks Meter: 275
br...
if is not a TA-082 or above, no harm will be done.
But use it carrefully (personally I use Pandora batery)
Rak|m
3.90 M33-3 runs smoothly.
Old 10-22-2008, 22:43   #12 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
Dark_Alex Custom Firmware 5.00m33-2 RELEASED
Originally Posted by Dark_AleX
Btw, if anyone has experimented the problems Sony told about 8 GB and 16 GB cards and psn, you may get the file /vsh/module/npinstaller_plugin.prx from 5.01 and replace the one of 5.00, that's the file that had the sony bug.
br
RNC_EBM
Old 10-22-2008, 22:56   #13 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
POPSLOADER for 5.00m33-2
br
RNC_EBM
Old 10-23-2008, 11:34   #14 (permalink)
RNC_EBM's Avatar
Member: 101860
Thanks Meter: 6,036
Dark_Alex Custom Firmware 5.00m33-3 RELEASED
br
RNC_EBM
The Following 2 Users Say Thank You to RNC_EBM For This Useful Post:
Old 11-13-2008, 11:54   #15 (permalink)
Member: 796252
Thanks Meter: 30
hi.... my psp have 4.01 m33-2 ver....
i bought memory stick card and put there some game but it cant detect games....
do i have to creat some case and put file inside????????
sorry bad eng....
■Θ■ PSP: Universal Unbricker To Unbrick/Downgrade/ Restore Any PSP To 5.00m33-4 ■Θ■ RNC_EBM Game Consoles & Mp3/4 , HD players 26 11-13-2017 11:21
how to 2g downgrade 3.1.3 to 1.1.4 turkcellgsm iPhone 2 / iPhone 3G / iPhone 3GS 6 03-14-2010 14:05
>>> Universal Unbricker To Unbrick/Downgrade/Restore Any PSP To 3.90 M33-3 <<< RNC_EBM Game Consoles & Mp3/4 , HD players 0 07-27-2008 12:57
Page generated in 0.24170 seconds with 9 queries
